Missing common ground? - Ford Bronco Forum
  • 1 Post By Ssisson
post #1 of 4 (permalink) Old 05-16-2017, 02:20 PM Thread Starter
Bronco Info: 1992 Bronco 5.0l, E40D, Electric Shift transfer, stock automatic locking hubs. bone stock.
Bought a 1992 bronco with the 5.0 3 months ago and there's a lot of small issues. After fixing quite a few of them I'm down to one of the last, which is my Speedometer doesn't work+rear abs light is on.
I've replaced the rear sensor on the dif. but that didn't fix it, but when I took it to the car wash today the speedometer started working aswell as a few things I didn't know were broke like the switch in the driver side door that tells you if it's open and the seatbelt sensor thing. wondering if maybe it's a ground somewhere?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Ssisson is offline
post #2 of 4 (permalink) Old 05-16-2017, 04:53 PM
Yo Ssisson,
Welcome!
See http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=9229
Go through the year, etc drill
Electrical Distribution
Ground Distribution
G200 serves Programmable Speedometer/Odometer Module (PSOM) aka Speedo, EEC Module, ABS module, Shit on fly transfer case, Speed Control Servo/Amplifier Assembly.
G200 ground is inside passenger side kick panel
Locations in Engine Bay pics: G100 @ LH front of engine compartment on upper radiator support-in front of WS washer/Coolant overflow tank; G101 front of fender apron-between starter relay & headlight; G200 behind RH kick panel; G103 (battery to engine) Lower RH front of engine; Same as Bronco in a 95 F Series
Source: by Ford via subford (Bill K) at Grounds by Bill Kalebaugh | Photobucket
Try the RABS Sekf Test for Codes
RABS Self Test Diagnostic Connector Location pic in a 92; under glove box
Source: by Jeremy M (Big '92, jermil01) @ Brake warning light will not go out.. - Ford Bronco Forum miesk5 note, use Jer's pics.
Also,, Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
The engine temperature must be greater than 50 F for the Key On Engine Off (KOEO) Self-Test and greater than 180 F for the Key On Engine Running (KOER) Self-Test.
miesk5 is online now
post #3 of 4 (permalink) Old 05-16-2017, 05:42 PM Thread Starter
I sprayed down the underside with water, and it works again so I'm just going to thoroughly check all the wires on the underside to make sure they aren't cut anywhere
miesk5 likes this.
Ssisson is offline
post #4 of 4 (permalink) Old 05-16-2017, 06:27 PM
Yo,
Also tap, move, and wiggle the suspect sensor and/or harness/ connector. BEWARE OF FAN, BELTS, PUL,EYS, HOT ENGINE AND a HELPER WHO MAY RUN YOU OVER. Don't ask.... Parking brake on and good to have bumper up against a solid wall or tree trunk.
