Rims and tires questions - Ford Bronco Forum
  • 1 Post By andrewmp8
post #1 of 20 (permalink) Old 05-17-2017, 08:09 PM Thread Starter
I used the search a bit, but I am creating a thread so I can also get people's opinions and advice. I randomly came across some rims and tires that are unique, and seeing as my bronco is just a toy I like to try different things. For one, would this set even work on my 93 full size bronco? If so, are there any major drawbacks? They fit on old jeeps and from what I've seen on this forum old jeep wheels fit broncos. Any advice or opinions are appreciated. Thanks!
hadenallison is offline
post #2 of 20 (permalink) Old 05-17-2017, 08:14 PM Thread Starter
The numbers on the tire read 7.00-15L M something
post #3 of 20 (permalink) Old 05-17-2017, 08:17 PM Thread Starter
5x5.5 bolt pattern as well
post #4 of 20 (permalink) Old 05-17-2017, 08:30 PM
Those are a skinny, old school traction tire. Most likely 28-30" diameter. Most likely bias ply. Tires were sized p78, q78, etc back then.
They remind me of my 78's co-op grip spurs
You dont want split rim wheels either, but yeah they would fit.
BigBlue 94 is online now
post #5 of 20 (permalink) Old 05-17-2017, 08:37 PM
biggum's Avatar
Those look like old super swamper / buckshot mudders. They are probably bias ply so tough as nails but ride like bags of rocks around your wheels. Back spacing may be an issue. Are the 93s 5x5.5?
biggum is online now
post #6 of 20 (permalink) Old 05-17-2017, 08:46 PM Thread Starter
93s are 5x5.5 and I'm not worried about ride quality because it's mainly just offroad messing around maybe once a week. I think these are old military type wheels. Does back spacing mean how far the axle goes into the rim? And what would be the issue?also, do you think the wheels would look small, or big or normal size on the bronco? Thanks
post #7 of 20 (permalink) Old 05-17-2017, 08:47 PM Thread Starter
What are the issues with split rims? The potential for them to blow apart? Thanks
post #8 of 20 (permalink) Old 05-17-2017, 09:56 PM
That's a big part of it. Most shops that recognize them will refuse to work on them. They're banned for a reason.
Woman Who Ended Split Rim Wheels Passes Away - Tire Review Magazine
They're not just dangerous to people working on them, they're dangerous for anyone in the vicinity of one on a truck and they caused a *lot* of accidents. Hot a pothole just right, shear one or more fasteners, BOOOOOOOOOM.
Spktyr is online now
post #9 of 20 (permalink) Old 05-18-2017, 02:21 AM
Yeah no way id touch those rims let alone use them,The tires are probably dry rotted and worth next to nothing really.
hadenallison likes this.
andrewmp8 is offline
post #10 of 20 (permalink) Old 05-18-2017, 08:33 AM
Foolsize Member
92BroncoXLT's Avatar
This would be my main concern, these 78 series tires (unless repops) are old as the hills by now. Also, split rims are a death trap as stated above.
Save yourself the headache and get some used 33's for your stock wheels if your trying to be thrifty.
Dylan
1992 XLT 300/M5OD
1978 Custom 351M/C6
1991 XLT 351W/Blown Up E4OD
92BroncoXLT is online now
post #11 of 20 (permalink) Old 05-18-2017, 09:17 AM Thread Starter
Thanks for the advice. Even used, the 33s can be pricey but sounds like these aren't worth the headache. (Or literal headache if they blow up.)
post #12 of 20 (permalink) Old 05-18-2017, 10:03 AM
Yup, notice how old the tires are in the pic i posted. They are at least 20 years old. Cracked all to hell, and last time this thing was road worthy, about 10 years ago, we ran tubes in them.
If youre looking for a traction tire, 31" and smaller super swampers arent too pricey
post #13 of 20 (permalink) Old 05-23-2017, 10:13 PM Thread Starter
Does anyone know the biggest possible tire size on a stock 93 ford bronco with 15" rims?
post #14 of 20 (permalink) Old 05-24-2017, 06:24 AM
People have fit 35x12.5x15s on their stock rims, but the stock 8" rims should really only be used for a 33x10.5x15 at the widest.
Tough to kill an old six
I6-Kid is offline
post #15 of 20 (permalink) Old 05-24-2017, 09:45 AM
Any diameter tire will fit in a stock wheel, but anything wider than 10.50 will look and ride like a balloon. The center of the tread pattern will wear out first, leaving you with cupped and extremely loud tires after less than half their life expectancy. A 12.50 needs a 9" wide wheel at the least.
post #16 of 20 (permalink) Old 05-24-2017, 09:53 AM
I have 37 x 14.50's on my rig..
jermil01 is online now
post #17 of 20 (permalink) Old 05-24-2017, 10:14 AM Thread Starter
So I can fit 33's or bigger on a stock bronco with no lift or anything?
Tganks
post #18 of 20 (permalink) Old 05-24-2017, 10:24 AM
Tganks
No. 33s will most likely rub at full turns and under heavy suspension compression. 33s are the biggest guys put on without a lift. You will destroy fenders and tires with no lift and 35" tires. If you want bigger tires and dont want to lift it, find some 33-10.50 tires and be careful when flexing offroad or making tight turns.
post #19 of 20 (permalink) Old 05-24-2017, 10:48 AM Thread Starter
Alright thanks. Might just go with 31s or 32s but the 32s are maybe $100 difference so unfortunately might end up with 31s lol
post #20 of 20 (permalink) Old 05-24-2017, 11:11 AM
I ran 31s on my stock 94 before i lifted it. Worked just fine, and had decent mpg and throttle response.
