Replacement Wheels/Tires, what to get? - Ford Bronco Forum
 2Likes
  • 1 Post By BigBlue 94
  • 1 Post By BikerPepe`
post #1 of 12 (permalink) Old 05-18-2017, 04:55 AM Thread Starter
Lawdog1978's Avatar
Bronco Info: 1978 Ford Bronco Ranger XLT
Hey guys. so I have to address a problem that I have right now. I purchased my Bronco and the tires are well....on the last leg if not more so. Problem I have is what is a good set of wheels and tires that I can or should get? Currently I have the following setup on my Bronco.
Mickey Thompson Baja
18/39-15LT 4 ply Rating
The Bronco has a fairly large lift, I'm thinking it's around 6in suspension and maybe 2-3 in body. I haven't measured anything yet but that's a best guess.
I want to get some tires that are going to be effective for on and off road fun. Is there anything you would guys would think I should get? I can work a budget but just wanted to get as many options as possible and then narrow it down from there.
Any help would be greatly appreciated, I use to run BFG A/T 33/35's on 15in Steel rims on my previous vehicles. With this lift setup I don't want to have something that looks way off or very under rated so to speak. I.e looks like tiny wheels on a giant Bronco.
On the long trail
Lawdog1978 is offline
post #2 of 12 (permalink) Old 05-18-2017, 06:24 AM
If you take out the body lift, you could run 35s and have them look pretty good
Tough to kill an old six
I6-Kid is online now
post #3 of 12 (permalink) Old 05-18-2017, 08:35 AM
panabax's Avatar
If you are thinking of changing wheels as well, you might consider a larger rim. I went from 15" to 17" and run 35s. I went to a 17" wheel just because there were a lot more tire options in 17" than in 15". My daughter's Mazda CX5 (super small cross over SUV) came from the factory with 19" rims. No one makes a truck with 15" rims anymore and the tires are really drying up. It will only get worse.
Baxter
My family came to this country from Texas!
panabax is offline
post #4 of 12 (permalink) Old 05-18-2017, 10:14 AM
I went to 16" wheels, for heavier ranged tires, but tire choices are fewer than 15" versions.
Im running 10 ply 37-12.50R-16 swamper irok non-directionals on my bronco with 4" lift and cutouts. They have superb traction in forward and reverse (thanks to the non directional tread) and are not overly loud on the road.
biggum likes this.
BigBlue 94 is online now
post #5 of 12 (permalink) Old 05-18-2017, 03:14 PM
huck2080's Avatar
Bronco Info: 79 bronco 460 c6
those old mickeys were horrible .. depends on if you wanna take off lift or do just tires or rims and tires ?
huck2080 is offline
post #6 of 12 (permalink) Old 05-18-2017, 03:20 PM
What gears are in it?
My most recent 4 sets of tires between the Raptor and the Broncos have been
MT Deegan 38,
Cooper STT Pro,
MT MTZ,
Maxxis Buckshot, and
Firestone Destination M/T
The Deegan 38 and STT Pro have been my favorites of them. I hated the Buckshots. My opinion is Deegan 38 or STT Pro in a 35-37" size, depending on gears (and with the body lift removed).
I had a 78 with 39.5 MT Baja Belted and 4.56 gears. I hated the tires, but the size with the gears was awesome for me. It was daily driven and had a 429.
the Son is online now
post #7 of 12 (permalink) Old 05-18-2017, 04:03 PM Thread Starter
Lawdog1978's Avatar
Thanks guys, the idea is to currently keep the lift if I can. I can ditch the 15's but wanted to see what everyone was thinking on that.
Is the lift just way to much? Normally I would say yeah but maybe it's because I had a Honda accord for so long that I want a different extreme again lol.
post #8 of 12 (permalink) Old 05-18-2017, 06:27 PM
panabax's Avatar
I guess too much is in the eye of the beholder. It is your truck after all, but I think the consensus would be that 8-9" of total lift puts you at the "high end" of what people do. I'm sure there are others even higher. I think the average lift is probably 4". I have what I estimate is a 4" lift running 35s. I don't think I would consider going any higher without also going wider. I'm already almost too old and too fat to climb into it as it is. So your lift is too much for me but that doesn't mean its too much for you.
As for ditching the 15s, I would look for tires first and see where the sweet spot is in rim size for the tires you want. When I did mine, it seemed like 17" was the sweet spot. I like a lot of sidewall on a truck so I did not want to use a bigger wheel than necessary to get me into good tire choices. IIRC, the 17" tires I was looking at were also quite a bit cheaper than similar 15" tires. Of course, YMMV.
Baxter
panabax is offline
post #9 of 12 (permalink) Old 05-18-2017, 06:40 PM
Harley's & Bronco's FTW!
I think you should buy one of these sets. http://www.fullsizebronco.com/forum/...ml#post6599425
oh yea... there is this whole section: http://www.fullsizebronco.com/forum/62-wheels-tires/
BigBlue 94 likes this.
BikerPepe` is online now
post #10 of 12 (permalink) Old 05-18-2017, 07:02 PM
huck2080's Avatar
got any pics of the suspension or a side view.. are the fenders cut .. what you gonna use it for .. if you wanna be close to what you are now look at 40in toyos or 41in irok .. now if your asking how i would set it up i would take off about 2in of lift . be it body lift or different coils and run 37 14.50 15 toys mts
huck2080 is offline
post #11 of 12 (permalink) Old 05-18-2017, 08:04 PM
TexasAxMan's Avatar
Bronco Info: 95 Bronco, Auto, Auto Hubs, Stock
Cheapest AT's in 33/12.5 at the Discount Tire near me:
17" rim - $238.00
15" rim - $140.00
In addition, they have the 15" tires in stock but have to order the 17" tires.
People have continually told me that 15" were more expensive/harder to get, but that continues to be false. Check your local stores.
1995 Bronco XLT
351, Auto
Auto Hubs, Stock TC
Stock Height w/ Leveling Springs
TexasAxMan is offline
post #12 of 12 (permalink) Old 05-19-2017, 09:15 AM
In that case, stay with something in the 39-40 range, but not so wide.
