Backfiring, shaking idle, and more.. - Ford Bronco Forum
 4Likes
  • 1 Post By jermil01
  • 1 Post By Mikey350
  • 1 Post By Handy_andy_cv64
post #1 of 20 (permalink) Old 05-19-2017, 01:15 PM Thread Starter
CalicoNC's Avatar
Bronco Info: 1992 Bronco XLT NITE 5.0
Having issues with my truck. I ran codes but nothing came up too drastic in KOER test (172,225,632) and with KOEO i got (334, 327,and 539) Im pretty sure some of those codes may come from my badly cracked exhaust manifold, but those codes are not necessarily the issue, because i've had those codes since I've owned the truck, but it has still ran fine, until yesterday.
The idle seems to be shaking alot more now, the rpm needle shakes alot at idle now also. It hunts for a second or two (always did this) but once it settles down i can feel the truck shake and see the rpm needle shake as well.
While driving at slow speeds nothing is noticeable. Around 35-40 mph after a downshift into third I believe, the whole truck shakes and i can hear a faint backfiring or popping noise. At a certain speed this goes away (above 55 maybe), but if i let off the acceleration a bit and pick back up, it starts the shaking and popping cycle starts again.
I was thinking that I may could be the TPS sensor, but im not too sure. Im wondering if these symptoms sound like that would be the problem.
Thanks guys
1992 Ford Bronco XLT Nite
Lifted on 36's
Tonneau soft top.
& whatever the previous 12 owners felt like tinkering with.
CalicoNC is offline
post #2 of 20 (permalink) Old 05-19-2017, 02:30 PM
aka: boilermakerms007
MATCHBOX's Avatar
I'll bet that cracked manifold has grown and is not creating a bigger issue. Every heat and cool down cycle hurts a crack, and all it will do is grow. Otherwise I'd look at your timing. Maybe the hold down for that distributor got loose and it has turned a little on you.
GET DIRTY
MATCHBOX is offline
post #3 of 20 (permalink) Old 05-19-2017, 03:21 PM
Bronco Info: 1993 Bronco Custom Trim - 302 Stock - E4OD Transmission
You know about a progressing large crack in your exhaust manifold and yet you discount it as the source of your running issue because "it's been there a while"? You know how silly that sounds, correct?
A new manifold is less than $70 shipped to your door, depending on the side. Fix a known issue and then decide if you have another.
1993 Ford Bronco Custom Trim w/ 302 V8
pollux is offline
post #4 of 20 (permalink) Old 05-19-2017, 03:42 PM
x2
jermil01 is online now
post #5 of 20 (permalink) Old 05-19-2017, 06:17 PM
mrnewland1's Avatar
codes
172- I'm not sure what priority the O2 has in this vintage of Ford but I do know most cars on the road are controlled by computers that make O2 sensors pretty high on the priority list. In other words, this could very well cause performance issues.
225- Knock sensor. The definition says to ignore if not pinging but it wouldn't hurt to diagnose this code regardless.
632- "E4OD Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test"
I don't even know what the hell this means.
334- 'EVP sensor high..." This seems unlikely.
327- "EGR feedback signal low". EGR issues can absolutely affect performance. Pay special attention to this one. Although, there being a manifold leak (possibly less exhaust going to EGR) may be the reason for this. Just a guess.
539- "System shows voltage at PCM pin 10 Is A/C on ?" Well, is it? I don't know. not familiar with this one.
I agree with MATCHBOX. Take care of known repairs needed first then go from there.
"Oh man, lodged where??"
mrnewland1 is online now
post #6 of 20 (permalink) Old 05-19-2017, 06:20 PM
mrnewland1's Avatar
Update on code 172
code #172- "Oxygen sensor not switching system is or was lean Single, Right or Rear HO2S Fuel control"
Here, read it again...
post #7 of 20 (permalink) Old 05-19-2017, 06:52 PM
It means the KOER test procedure was not completed correctly. It's expecting input from the driver to test signals and sensors and they were not perceived by the EEC module.
http://www.corral.net/tech/maintenan...koer.html#koeo
This test requires up to three inputs from the driver during the test. The first input requires that the brake pedal be depressed, the second requires that the steering wheel be turned at least one-half turn and then released. Finally on cars equipped with an E40D automatic transmission, the Overdrive Cancel Switch (OCS) must be deactivated, then reactivated.
pollux is offline
post #8 of 20 (permalink) Old 05-19-2017, 08:21 PM
mrnewland1's Avatar
Ah ok. i have a similar test (optional test while hooked up to old scan tool) on my '89 that includes turning lights on, pressing brake pedal and turning steering wheel. I don't know, maybe it's the same test but not as advanced. My truck is has a C6 (hopefully not for too much longer).
post #9 of 20 (permalink) Old 05-19-2017, 11:50 PM Thread Starter
CalicoNC's Avatar
thanks or the responses. Im working on getting the manifold replaced but it costs a little more than I can spend at the moment. I was quoted around $450. I rarely drive the truck more than 25 miles a week at the most. Its just not cost effective right now when I have a Mazda that gets 41mpg. lol But, The reason I was asking about the TPS was because this issue just started out of nowhere this week. I remember vaguely about a week ago the check engine light came on, but went off never to come back, so I figured it was nothing. Nothing showed up in the code check other than the same ones above.
Im wondering if it is possible to remove/unplug the TPS from the TB to see if it would run better. All post i've read seem to state that you have to remove the whole assembly to access the TPS. I forgot to mention i'm not mechanically inclined -_-
Lifted on 36's
Tonneau soft top.
CalicoNC is offline
post #10 of 20 (permalink) Old 05-20-2017, 08:57 AM Thread Starter
CalicoNC's Avatar
I think I may have solved the problem. I unplugged the TPS and compared a test run with and without it. With it plugged in, it hunts to idle and the car stutters and backfires after the shift to third. Without it plugged in, the idle dropped , and no backfiring or stutter. Although it does shift late and/or hard but i think thats just a symptom of having the tps unplugged.
About to order a new one, im assumimg the motorcraft one works best? or could I get away with a BWD brand?
Thanks for the help guys
Lifted on 36's
Tonneau soft top.
CalicoNC is offline
post #11 of 20 (permalink) Old 05-20-2017, 10:18 AM
Yo Cal,
Go with the Motorcraft TPS every day.
I buy my Ford parts via AMAZON; they are VG at delvy and esp pricing; A few years ago I bought a $150.00 DPFE Sensor (not incl. sales tax) for $50.00 with free shipping and no state sales tax; same for the IAC sensor.
Some buy from a Ford pn from on-line or local parts stores that list the Ford PN, but the ads show the PN as a reference only and the supplier may be a company off-shore. other than a Ford supplier.
Throttle Position Sensor (TPS) Overview & Testing by Seattle FSB
For no RELEVANT backfire @ idle codes, Ford's usual perpetrators are;
Vacuum Leaks; see my Vacuum leak test in post #11
Check spark plug wires and routing.
miesk5 is online now
post #12 of 20 (permalink) Old 05-24-2017, 12:14 PM Thread Starter
CalicoNC's Avatar
UPDATE:
Ok I replaced the tps seemed to idle better around 650-700 i let the truck run for maybe 5 minutes or so went inside the house came back out to the whole truck smoking. Engine bay and all. I opened the hood and it seems like this one thing is smoking really bad I think it was The AC/Idler. I let it cool down and started to look around the engine bay. I noticed a spark plug not connected to the manifold for some strange reason, so I reconnected it to the appropriate spot. I started her back up and she seemed to be fine, no smoking. I think. Its smoking from the tailpipe more than normal now it seems. Could anything cause the smoking from the idler that is related to me changing the TPS?
Lifted on 36's
Tonneau soft top.
CalicoNC is offline
post #13 of 20 (permalink) Old 05-24-2017, 02:01 PM
smoking from the tailpipe would not be a result of a new TPS. could be bad rings, burning coolant..it there any odor the exhaust? how is your coolant level?
CalicoNC likes this.
post #14 of 20 (permalink) Old 05-24-2017, 05:05 PM
mrnewland1's Avatar
Do a compression test on it.
post #15 of 20 (permalink) Old 05-24-2017, 07:47 PM
Originally Posted by CalicoNC View Post
UPDATE:
When you were idling, was the A/C or Defrosters on? If so, the A/C compressor could have locked up. When that happens, the belt slips and starts to smoke. Not an uncommon problem.
If you have no A/C and just an idler pulley in its place, maybe the bearing is locked up.
Mikey350 is online now
post #16 of 20 (permalink) Old 05-24-2017, 11:53 PM Thread Starter
CalicoNC's Avatar
I just remembered, Yes the AC was on. When the smoke settled and cooled off, I turned the AC off and started it again this time no smoke. it frustrates me that every time something gets repaired/replaced another thing breaks in its place. lol
Any idea why it happened? Did the change in idle affect it somehow?
Lifted on 36's
Tonneau soft top.
CalicoNC is offline
post #17 of 20 (permalink) Old 05-25-2017, 12:18 AM
The TPS and the A/C compressor are not related. You could unplug the A/C compressor clutch and see if you have solved the driveability problem. Then find an A/C place to fix your A/C.
post #18 of 20 (permalink) Old 05-25-2017, 01:57 AM Thread Starter
CalicoNC's Avatar
Im going to try and take a look at it tomorrow/today (after 12am here) to see if the clutch engages with the ac on and if there is any change in idle. Whats the probability that maybe the compressor isn't seized, but maybe its just the clutch or coil. When I noticed the truck smoking, it didn't die like most posts i read, it just smoked..and had a faint fizzle sound coming from the AC Compressor. Im really praying for a miracle that its not the compressor..but i know my odds.
UPDATE:
I checked it out this morning to figure out what happened. I can turn the clutch by hand with the truck off (i'm not sure what this means) I tried turning the ac back on while the truck was running and it engaged and disengaged correctly for a while...until i began to notice it did not disengage for quite some time. I let it run for maybe 3-4 minutes and it didn't disengage. I cut it off out of fear that maybe something would mess up. From my reading the clutch is suppose to disengage and engaged based on the low and high pressure switch and/or the temperature outside. I also checked my coolant reservoir level, and its extremely low for some reason. Im not sure what happened there and why.
Lifted on 36's
Tonneau soft top.
CalicoNC is offline
post #19 of 20 (permalink) Old 05-25-2017, 02:15 PM
House of Windsor 4ever!
Handy_andy_cv64's Avatar
Wow. You have a whole mixed bag of problems. When you came out to find 'smoke' under the hood, was it acrid (like a belt dragging in a stuck pulley) or sickly-sweet? The latter would be coolant, and could explain partly why your cooling system was low. Remember, the computer kicks the idle up when the A/C clutch is engaged to compensate for the extra load to the engine; is the idle staying more or less steady when the compressor does engage? When the A/C stopped cycling, how was the A/C control set? Usually, when it's set on a fresh air setting, the system has to compensate for the extra heat getting pulled in from outside, so the clutch may stay engaged longer than you'd think. Having it on MAX sets the RECIRC door in the closed position, so the inside air is recirculated, the system processes less heat, and the clutch should cycle short, until you get into a high heat situation, such as a hot Summer day, desert driving, etc.
Handy_andy_cv64 is offline
post #20 of 20 (permalink) Old 05-25-2017, 10:37 PM Thread Starter
CalicoNC's Avatar
Im not really sure of the smell, i was so in a rush to cut it off i didnt even raise the hood before I turned it off out of fear. The coolant is really low in the reservoir, when I opened the radiator cap this morning it seems low as well. What could make the coolant disappear like that? The idle seems constant with or without the AC on. I usually always have the AC set to Max AC
Lifted on 36's
Tonneau soft top.
CalicoNC is offline
