94 bronco stereo wiring diagram - Ford Bronco Forum
post #1 of 16 (permalink) Old 09-10-2005, 09:09 PM Thread Starter
gakr2000's Avatar
Bronco Info: 94 Bronco 5.8 EB
Angry 94 bronco stereo wiring diagram
Can anybody help me sort out this mess. Just bought a 94 EB with no stereo and an trying to install one. Problem is i have a big hole and two connectors with no radio? If anybody can clearify the color codes for the speakers etc. i would greatly appreciate it. Thanks in advance.
gakr2000 is offline
post #2 of 16 (permalink) Old 09-10-2005, 09:51 PM
bronkx1's Avatar
Bronco Info: 92 EB 302ci
Dont cut off the plugs.Go to best buy or simular store and ask for a wire harness for your truck.It will connect to the plugs in the dash and all the wires will be marked with what connects to what.Cost under $20
WU Tang Financial
CREAM
"Cash Rulez Everything Around Me"
Under the CREAM methodology,
individuals not only invest in stocks, bonds, commodities,
etc... but also put money into guns, drugs, and ho's. "
bronkx1 is offline
post #3 of 16 (permalink) Old 09-10-2005, 09:54 PM
Southeast Utah Native
Rick3373's Avatar
Bronco Info: 89 XLT
Definitely get the kit to use the existing connectors.
LIFE'S SHORT, PLAY DIRTY!
89 Bronco XLT, 351, C-6.
Understand how your use affects the land.
Adopt minimum impact practices.
Share in the costs of services, education & maintenance.
Rick3373 is offline
post #4 of 16 (permalink) Old 09-11-2005, 12:38 AM
MikE2's Avatar
+3
dont **** up the factory plugs, get the plug ins and do all the connections on that
MikE2 is offline
post #5 of 16 (permalink) Old 09-11-2005, 12:47 AM
Steve83's Avatar
I'll fourth that. You'll be much better off splicing on an aftermarket connector than the factory wires.
BTW MikE2
Your avatar is some animal's muzzle, right? Maybe a kangaroo...
post #6 of 16 (permalink) Old 09-11-2005, 12:50 AM
MikE2's Avatar
lean your head all the way to the right and its a lot clearer
MikE2 is offline
post #7 of 16 (permalink) Old 09-11-2005, 01:18 AM
Steve83's Avatar
Yeah, I got that, but what animal is it? It almost looks like a Taun-taun...
post #8 of 16 (permalink) Old 09-11-2005, 01:37 AM Thread Starter
gakr2000's Avatar
Holy Sh** i guess i m going to go with the aftermarket plugin. I knew it was going to be easier i guess i was just being lazy. Thanks for bringing me back to reality
gakr2000 is offline
post #9 of 16 (permalink) Old 09-11-2005, 07:02 AM
green ones make me horny
imlikeojnow's Avatar
at least you got to go with an aftermarket one. Damn when i got my truck all i had was a bunch of wires and no harness, well harness was there had one wire going to it. I rewired everything took like 5 hours with the dash off and all, big pita. Good luck
imlikeojnow is offline
post #10 of 16 (permalink) Old 09-11-2005, 11:21 AM Thread Starter
gakr2000's Avatar
Ok i am going to give the color code for the sake of people using the search (Which i use just about everyday). I will go get the connector from Bestbuy but for those who have the connectors ripped out this could be for you. I am not sure of the years this will cover i just know it works for my 94 Eb.
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Red or Black
Illumination Blue/Red
Dimmer N/A
antenna Trigger N/A
antenna Right Front
Front Speakers 5X7
Left Front+ Orange Green
Left Front- Black/White
Right Front+ White/Green
Right Front- Black/White
Rear Speakers 6X9 Side Panels
Left Rear+ Pink/Green
Left Rear- Pink/Blue
Right Rear+ Pink/Blue
Right Rear- Green/Orange
Got this info from the12V.com
Dont really understand how some of the wires are the same color like the left rear- and right rear+ but i havent really looked at the connector though plus nothing an ohm meter couldnt solve. I am still getting the connector from bestbuy though. Just thought i would share because i couldnt find anything in the search about it. Thanks for all the help guys. Now time to go to the store and start the fun.
gakr2000 is offline
post #11 of 16 (permalink) Old 09-11-2005, 11:29 AM Thread Starter
gakr2000's Avatar
done
gakr2000 is offline
post #12 of 16 (permalink) Old 09-12-2005, 05:52 PM Thread Starter
gakr2000's Avatar
Ok i am a retard Just got back from best buy with my connectors for the stereo. Anyway, here i have been soooo worried about what color was what trying to ghettofy the install and it ended up taking me more time to splice the wires from the connector then it did to install the damn radio Thanks for the enlightment guys , once again this site rocks
gakr2000 is offline
post #13 of 16 (permalink) Old 12-06-2016, 04:23 PM
nicoteen's Avatar
hey i kinda have the same thing going on here, bought a pioneer avh 7800 bt and have no idea how to install it. before im gonna take apart the original wires from plug, could someone send me a link to what adapter/plug i'll need?
thanks in advance!
1993 Bronco EB
nicoteen is offline
post #14 of 16 (permalink) Old 12-06-2016, 04:44 PM
Thread Killa
jowens1126's Avatar
thanks in advance!
Metra 70-1770
Metra 70-1770 Receiver Wire Harness Connect a new car stereo in select 1986-2006 Ford and other vehicles at Crutchfield.com
Unplug the factory stereo, plug in these adapters, wire them to your aftermarket stereo plugs.
jowens1126 is offline
post #15 of 16 (permalink) Old 12-06-2016, 04:52 PM
nicoteen's Avatar
thank you very much!
since im from germany its easier for me to order off of ebay so i found them there for around 5$ if anybody else is searching for them
1993 Bronco EB
nicoteen is offline
post #16 of 16 (permalink) Old 12-06-2016, 06:54 PM
If your Bronco had the standard radio, here's the schematic: (Click the link under the schematic and then view it "original size" to make it easier to read.)
1996 Ford Bronco '94 EVTM picture | SuperMotors.net
If your Bronco had the premium radio with the factory amplifier, this is the schematic:
Mikey350 is offline
