Bronco Tranny and T-Case Info - Page 4 - Ford Bronco Forum
 2Likes
post #61 of 276 (permalink) Old 08-30-2006, 06:58 PM
Originally Posted by pud
I remember hearing the truck upper off a windsor will fit the 302 lower...not sure if theres even any difference other than the badging on it.
Not unless you are talking a gt-40 or explorer 302 lower and a lightning 5.8 upper in other words, cobra type intakes.
ΜΟΛΩΝ ΛΑβΕ
BlueBronco is offline
post #62 of 276 (permalink) Old 08-30-2006, 07:09 PM
pud
Bronco Info: 87 xlt 5.0L auto beater
something like that...
pud is offline
post #63 of 276 (permalink) Old 08-30-2006, 07:22 PM
mtthwvn73's Avatar
Bronco Info: 1996 F150
Originally Posted by jermil01
Even if it was possible, that 2 wheel drive truck tranny will probably be longer than your bronco tranny, coupled with a tcase you'd need to shorten the rear driveshaft.
So is it possible or not? Wouldn't you have to change the driveshaft anyways if you're changing tranny's, I have a C6 in it right now.
mtthwvn73 is offline
post #64 of 276 (permalink) Old 09-11-2006, 11:16 AM
The Riddler
78CERBERUS's Avatar
Bronco Info: 1979 FSB 351M
C6 top speed....
Great list, well done.
Adrian, I just used a virtual graph chart provided by a member to get the "TOP SPEED" of a truck with a C6.
I didnt want to start a new thread and am thinking this would go in here so someone would know the C6 speed limitations -VS- benefits of an "Over Drive" transmision in a truck ?
I have been having some tech issues with my truck and really didnt take into account the "actual" speed that the 351W + "C6" with no transfer case, and "lower gears in the rear axle" was capable of and may have been over reving it to get more than 80 MPH from it.
If in fact that was even possible without straining the stock engine in a stock truck. I know they are faster in cars. Because of the rear end ratio.
Does this chart look right?
Is 70 MPH @ 4800, 5000 RPM's about all
a 351W eng -C6 trans -No Transfer Case -3.55 rear ratio
and -18" tires going to put out comfortably ?
78CERBERUS is offline
post #65 of 276 (permalink) Old 09-11-2006, 12:28 PM
mtthwvn73's Avatar
Hey, try 28's and see what happens, I'm pretty sure they aren't 18's stock...Mine has the 351 with 235's (I'm pretty sure they're 28's or something like that). Just to help you get some info about it...mine's hitting 35-36 at 4500 rpm's. Check it out and see what you get. Oh and in 3rd at 63-65 I'm cruising at 3K..if that helps any too.
post #66 of 276 (permalink) Old 09-11-2006, 12:46 PM
The Riddler
78CERBERUS's Avatar
Not sure if your reply is for me,
but you have about 65 MPH in 3rd @ 3,000 rpm's ?
I wasnt going to bother installing a tachometer, but my 351W, C6, sounds like its starting to strain ( reached reasonable rev limit) at around 75 MPH.
post #67 of 276 (permalink) Old 09-11-2006, 03:40 PM
mtthwvn73's Avatar
Yeah, I was talking about trying out your top speed calculator with a 28" tire instead of the 18 you put in. You get what I'm saying? A 18" tire is awfully small on a bronco. I've never had mine up to 75, so I don't really know what RPM it's running at that speed.
post #68 of 276 (permalink) Old 09-12-2006, 11:48 AM
The Riddler
78CERBERUS's Avatar
Well honestly its over an F-250, and now I feel bad knowing ive got 15" tires on my bronco.
"But" i did change the gear ratio to that number you put up and .....
"Voila "!....so i should start leaning towards highway gears, i dont need extreme low end pull,or quickness, for the most part, so im googling my options. Thank you. Given that this virtual numbers cruncher is acurate.
post #69 of 276 (permalink) Old 09-16-2006, 03:59 PM
Late Model Man's Avatar
Bronco Info: '95 351, ZF5, Dana 60s
We still need some T-case info...
Please?
SuperFord 95 8-lug Bronco with some stuff...
Late Model Man is offline
post #70 of 276 (permalink) Old 09-28-2006, 08:55 AM
Bronco Info: 1993 EB 5.8L
Thanks for the post, I need a new drive shaft, but wasn't sure which tranny was on my 93 Eddie Bauer full size. One glance and I had my answer.
lewismatt is offline
post #71 of 276 (permalink) Old 10-31-2006, 02:50 PM
I've got a '70 429 in my 79 Bronco, current it has the 4 spd in it. But.. I want to find a 5 spd so that I have the over drive, and can get a little better fuel mileage.
What ZF would I need, and would the efi 460 bell housing bolt to the '70 block. I'm not to sure, but I think I've read someplace that the new ones where different?
78Jimmy is offline
post #72 of 276 (permalink) Old 11-02-2006, 01:05 PM
Bronco Info: 85 Bronco, 5.8 in Black Primer, Edelbrock carb, power windows/ locks and no tailgate..
[QUOTE=78Jimmy;1051558
What ZF would I need, and would the efi 460 bell housing bolt to the '70 block. I'm not to sure, but I think I've read someplace that the new ones where different?[/QUOTE]
Not sure on which Zf. But the 460 will bolt up.All 385's will as matter fact. That is 351m 400 m 429 & 460 That said remember they went hydralic for the clutch. So you will have some mods to so there.
work, work, and more work...
Never fails even when I get out to play seems as if it evens turns from fun to work in less time then it takes to say sh--.
pacer88220 is offline
post #73 of 276 (permalink) Old 11-02-2006, 06:01 PM
What all has to happen to put in a hydraulic clutch? I'm assuming I'd need the peddle, and everything back.. If I find the tranny, it should have the hyrdaulic's attached..
78Jimmy is offline
post #74 of 276 (permalink) Old 11-12-2006, 12:56 AM
Bronco Info: 79 Bronco 351m
hey i was just wondering on this when i am pulling a c6 out of my truck what is the best way to do it? i mean i have it almost out but i cannot get it all the way out. it is hitting the firewall with the top of the bell housing. what do i do??? does the bellhousing come apart from the rest of the tranny? do i need to pull the whole engine to get the tranny out??? i am baffled right now on what to do and i need some help very badly. so please help me out. i am going to go take another stab at it tomorrow.
so far i have the tranny able to come back about 4-6 inches and it will not go any further because it hits on the fire wall. it is a 351m with the c6 tranny. so some ideas would be greatly appreciated.
thanks in advance..
Taylor
skaterdemon69 is offline
post #75 of 276 (permalink) Old 11-12-2006, 01:08 AM
I killed Kenny...again
jrdbronco's Avatar
Bronco Info: '92 bronco 351W E4OD BW1356, D44 SAS, 4.56 r/p f&r, spooled D60, 9" of lift, cutout flares
its gotta go down.
92 bronco with lots o' goodies
Originally Posted by Johnski at RITS
I ABSTAIN FROM ABSTAINANCE
Originally Posted by Ogeechee4x4 at RITS
Hey come here, I've got wood
my superford page
HIT IT ~N~ GIT IT OFFROAD!!!
jrdbronco is offline
post #76 of 276 (permalink) Old 11-27-2006, 10:34 PM
RainGull's Avatar
Bronco Info: '84 XLT 4" lift, I300, 4spd.man w/OD, MSD 6A w/ Blaster 2F coil
I have an 84' with a Tremec RTS (Not SROD)
RTS 4-spd w/OD (Trans code is also B for this transmission)
T170FT-RTS Top loaded 4 speed with 4th being overdrive. Aluminum case and shift tower. 1984-87 Trucks: Aluminum, top loaded case with tower shift. All units have Overdrive. Mainshaft Reverse is located on the outside of the 1st/2nd slider and all synchro rings have 36 teeth. The 3rd gear on the cluster gear is larger than the 4th gear (the front gear). Casting number 260XXXX.
I do not know the ratios.
http://www.drivetrain.com/tremec4sp.html
http://www.alldriveline.com/transmissions/frtscp.html
http://www.drivetrain.com/vartransp27.html
RainGull is offline
post #77 of 276 (permalink) Old 12-01-2006, 08:59 PM
joekiser's Avatar
Bronco Info: '84 inline six holley 390 clifford headers and intake msd 6a igniton w/duraspark
Good info on the Tremec RTS. Trying to figure out what I have in my 84 inline six.
http://www.supermotors.net/vehicles/registry/15588
"We dance like marionettes, swaying, to the symphony of destruction."
joekiser is offline
post #78 of 276 (permalink) Old 12-01-2006, 09:14 PM Thread Starter
USAF C-17 Avionics
adrianspeeder's Avatar
Thanks Raingull, whats your shifter look like so I can add it. And whats your motor?
Adrianspeeder
adrianspeeder is offline
post #79 of 276 (permalink) Old 12-06-2006, 07:06 PM
RainGull's Avatar
The RTS shifter housing comes straight up off of the trans and not the tailshaft housing like the other tremec. It also does not have a side cover on the RTS. The shift pattern is: 13
24R
The RTS has an aluminium case and no drain plug (unless added)
My engine is the Inline 6 (300).
Oh, and you don't have to push it in to shift into reverse either.
RainGull is offline
post #80 of 276 (permalink) Old 12-08-2006, 08:22 AM
deerslayer's Avatar
Bronco Info: 82' F250 466ci/c6 d60's, 37"ss
Hey y'all Im kinda new around here, I got a 82 f250 with a 466/ c6 the only problem is i miss my np435 but i cant find a bell housing to fit any ideas?...
I origanally had a 300 6 in her but she just didnt have the balls i needed i built the 466 myself along with the whole truck you could say its been a life long project and i've loved almost every minute of it. Well if anyone knows of a trick or someplace close by to get one for cheap let me know
deerslayer is offline
