Bronco Tranny and T-Case Info - Page 5 - Ford Bronco Forum
post #81 of 276 (permalink) Old 12-08-2006, 08:28 AM
deerslayer's Avatar
Bronco Info: 82' F250 466ci/c6 d60's, 37"ss
Hey y'all im kinda ne around here, I got a 82 F250 with a 466/ c6 (busted) but i got a problem i miss my np435 from the original 300 it had in it, But i cant find a bell housing anywhere that will bolt up any ideas on where else to look?... Now i built this truck from the ground up you could say its been a life long project
" THE Deerslayer"
deerslayer is offline
post #82 of 276 (permalink) Old 12-27-2006, 10:57 PM Thread Starter
USAF C-17 Avionics
adrianspeeder's Avatar
" THE Deerslayer"
Junkyard, keep callin'...
Added some more updates. Ya'll keep the info comin'.
Adrianspeeder
adrianspeeder is offline
post #83 of 276 (permalink) Old 12-30-2006, 03:33 AM
mengbar's Avatar
Bronco Info: 1978 Bronco Ranger XLT, 1989 EB Bronco
Nice job Adrian...I just added your info to my hardcopy notebook. I really get tired of digging through the chiltons and Haynes and still wondering.
You da man.lol
mengbar is offline
post #84 of 276 (permalink) Old 01-01-2007, 11:19 PM
Bronco Info: 1996 XLT
ANYONE EVER USE THE B&M SHIFT IMPROVER KIT THAT WIRES TO YOUR MODULE, IT HAS A BUTTON THAT ALLOWS YOU TO SHIFT FROM FIRM TO HARD OR OFF???
1996 XLT BRONCO 5.8 W/4" LIFT
1991 NOTCH MUSTANG
2006 SS TRAILBLAZER
BRONCOJOHNSON is offline
post #85 of 276 (permalink) Old 01-02-2007, 06:24 AM
SnowTom's Avatar
Bronco Info: 90 EB 5.8 e4od
Question Help reading trans chart
This is my 1st post so please forgive me if I mess up. I read the chart at the beginning of the thread and i'm not sure if I'm reading corrrectly. On the
e4od list it lists years 89-99 and engines 5.0 to diesels, Does this mean the same transmission is compatible in all those combinations? Or, we're different variations of the transmission made for them?
Would a e40d from a 1995 F-250 w/Diesel power install on my 1990 5.8L EB w/e4od? Where the electrical connections the same?
SnowTom is offline
post #86 of 276 (permalink) Old 01-02-2007, 03:54 PM
pud
Bronco Info: 87 xlt 5.0L auto beater
no, different bellhousings. The diesel has beefier internals also I would think.
pud is offline
post #87 of 276 (permalink) Old 01-03-2007, 04:48 PM
SnowTom's Avatar
Thanks Pud; I went back to the list and finally realized what the {} marks meant. I'm still no sure on which years are compatible. In quite a few posts that I've read, the years 89-92 are grouped together as are 93-95 while 96 is by itself. Is this because the major upgrades were done between 92 and 93, and again beween 95 and 96? Or, did they change something else like say the electrical connector?
If I find a low mileage 95 or 96 Bronco or F250 with the same engine and trans as my 90 Bronco, will it fit without any modifcations?
SnowTom is offline
post #88 of 276 (permalink) Old 02-11-2007, 07:04 PM
jackedupbronco's Avatar
Bronco Info: 1986 Ford Bronco, 300 6 cyl, work in progress
How do you identify transfer cases?
jackedupbronco is offline
post #89 of 276 (permalink) Old 02-12-2007, 08:27 PM
Originally Posted by BlueBronco View Post
Vulcan Mind Meld
j/k Look for metal tags on it.
Cool thanks
2001 Dodge Ram 2500: 5.9L 360 4x4 Daily Driver / Tow rig
1986 Ford Bronco : 300 6 cyl, work in progress
1992 Ranger:2.3L Turbo
Lifes a b!tch sometimes, get over it and move on.
post #90 of 276 (permalink) Old 02-12-2007, 09:23 PM
Wrenching for a Livin'
magnumpi's Avatar
Wheres the t-case info?
My SuperFord
'85 Bronco......
magnumpi is offline
post #91 of 276 (permalink) Old 02-22-2007, 10:29 PM Thread Starter
USAF C-17 Avionics
You didn't write it yet?
I don't know the transfer cases as well as the trannys, shoot, still tweakin' the info for the sticks. Anyone is welcome to put together something for transfer cases and I'll edit right into the first page.
Adrianspeeder
post #92 of 276 (permalink) Old 02-22-2007, 10:38 PM
I started working on that (tcase info) but havent finished it yet.
reptillikus is offline
post #93 of 276 (permalink) Old 02-25-2007, 08:00 PM
What tranny would fit?
I have a 1989 full size Bronco, with a 351W. It currently has a C6. Is it possible to swap to a tranny with a overdrive? And is so, which one?
Thanks
Clay7212 is offline
post #94 of 276 (permalink) Old 02-26-2007, 12:00 AM
Thanks
The AOD would be the easiest. You would need a flexplate out of a Crown Vic with a 351W. There are a couple of threads on here if you search AOD 351W.
Edit: This is a good place to start 351w to AOD flexplate?
ΜΟΛΩΝ ΛΑβΕ
BlueBronco is offline
post #95 of 276 (permalink) Old 02-27-2007, 09:07 AM
goof008's Avatar
Bronco Info: 1992 Bronco XLT 351/auto
Here's one I haven't seen asked yet. I am looking at buying a Bronco...probably a 91 or newer. I am only finding automatics, but would prefer a stick for performance and gas mileage. Would I be messing up the computer or anything by putting a ZF 5-speed inplace of the auto in it? Can anyone say if the gas mileage would be much better with the manual?
goof008 is offline
post #96 of 276 (permalink) Old 02-27-2007, 09:12 AM Thread Starter
USAF C-17 Avionics
For city stop and go driving a stick gets the better mileage. Search ZF swap
E4OD to ZF-5 Swap
post #97 of 276 (permalink) Old 03-04-2007, 02:02 PM
RockJeep's Avatar
Bronco Info: 85
1989 5spd no reverse
My dad's 89 bronco 302 5spd will not go into reverse or 5th gears. Grinds when trying to go into reverse but no grinding when trying to go into 5th. Any idea what this could be
Thanks
Bobby
AA is for quiters.
RockJeep is offline
post #98 of 276 (permalink) Old 03-04-2007, 02:06 PM
Late Model Man's Avatar
Bronco Info: '95 351, ZF5, Dana 60s
Thanks
Bobby
Not trying to be an ass but I'd start a new thread. this one is just for info. you'll get more replies in your own thread.
SuperFord 95 8-lug Bronco with some stuff...
Late Model Man is offline
post #99 of 276 (permalink) Old 03-04-2007, 02:58 PM
magnumpi's Avatar
Question...what tranny did ford use for their "three on the tree" manuals? Just didn't see it mention. I saw one in the junkyard this weekend that had been converted to a floor shift, and it got me thinking about it.
My SuperFord
'85 Bronco......
magnumpi is offline
post #100 of 276 (permalink) Old 03-04-2007, 06:19 PM Thread Starter
USAF C-17 Avionics
Cool man!, just get it to me when done and i'll throw it right on the first page.
Ford 3.03. Got em in the '71 and '66. Used up 'till '83. Don't worry, the manuals are gettin' a complete rewrite and major update here this week. It'll be my spring break project.
Adrianspeeder
