Stupid question on greasing. - Ford Bronco Forum
post #1 of 19 (permalink) Old 03-13-2003, 11:26 AM Thread Starter
godless's Avatar
Bronco Info: Sold Bronco, but still live in the off topic threads
I know keeping my ball joints, u joints, tie rods greased is important.
I grease them as often as it is needed, probably every 2-3 months or more in the summer.
Whenever I grease everything I never know what is a "safe" amount.
Some people say just keep squeezing grease into them until it squirts out and some people say just use two-three pumps.
Besides the tie rod boots can you really danger any of the u-joints or ball joints by squeezing to much grease through them?
I usually just keep pumping grease through ball joints until I see fresh grease protruding out through them, and same with the u-joints.
Tie rod boots I squeeze grease into them until I see grease start to pop a little out of the boot.
Is this good or am I going about it all wrong?
Sorry it is a stupid question but I would rather be safe than sorry.
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring."
Carl Sagan PH.D.
godless is offline
post #2 of 19 (permalink) Old 03-13-2003, 11:35 AM
Traveling FSB'er
dhath's Avatar
Bronco Info: 79 Red and White Bronco
That is the way I have always greased mine. I pump grease until a see just a little bit coming out the rubber seal. :
Currently undergoing a face lift.....
dhath is offline
post #3 of 19 (permalink) Old 03-13-2003, 12:03 PM
YER FUKKED NOW...BITCH!
Damager's Avatar
Bronco Info: 1986 Eddie Bauer,1991 EFI 302, TTB and Spooled 8.8 with 35's .. for now....Carnage is Good
I don't see how it could ever be too much...it will squeeze out a fall off :roll:
http://www.supermotors.net/clubs/sup.../registry/1371
A U.S. VETERAN
- Whether active duty, retired, national guard or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to "The United States of America", for an amount of "up to, and including, my life."
That is honor, and there are way too many people in this country who no longer understand it.
Author unknown
Damager is offline
post #4 of 19 (permalink) Old 03-13-2003, 02:19 PM
Tator Salad
1982bronco's Avatar
Bronco Info: 1985 Ford Ranger
that is a very good question. i have always wondered about that.
Cory Seiber
1985 Ford Ranger
1982bronco is offline
post #5 of 19 (permalink) Old 03-13-2003, 09:17 PM
You cant over grease any of the items mentioned, just dont pump to quickly and they all will vent grease. The original post mentioned greasing more in the summer........winter and spring are usually the most hostile enviroments, mud and water are the worst. Overgreasing these points helps to flush out dirt.
'94 with a couple of extra goodies
big mike is offline
post #6 of 19 (permalink) Old 03-13-2003, 11:04 PM
OOPS GIVE A DAMN IS BROKE
gearrat's Avatar
Bronco Info: 94 xlt 302. 4 in lift 3in body lift and 35's.
i have never heard of over greasiing those fittings
94 bronco XLT
36x12.50x15 swamper tsl
tuff country 4" suspension lift
3 in PA body lift
http://azrockrat.4t.com/index.html
gearrat is offline
post #7 of 19 (permalink) Old 03-13-2003, 11:14 PM
Damager's Avatar
figure you could sit there and pump a whole cartridge through it...if it squeezes out it is self regulationg...for lack of a better analogy
figure if it was a contained/enclosed area it could be overfilled, if there was no place for oxtra to overflow
A U.S. VETERAN
Author unknown
Damager is offline
post #8 of 19 (permalink) Old 03-13-2003, 11:45 PM
uh oh
BadassBronco's Avatar
on your bronco i can say you can safely grease all those things like that. Beware though on some cars as they use a ballon type seal over the balljoints and you can acually pop those and then they wont hold grease worth a crap.
BadassBronco is offline
post #9 of 19 (permalink) Old 03-14-2003, 12:33 AM
Disgruntled Trucker
Jon0807's Avatar
Bronco Info: 1979 Custom
I've heard all of those too. But for ujoints, I do it till it starts comming out. For ball joints I wait till new grease comes out.
Smile You Son Of A Bitch!!
Ignorance is bliss when knowledge is so damn frightening! - Anita Blake
Jon0807 is offline
post #10 of 19 (permalink) Old 03-14-2003, 12:45 AM
dogonmut's Avatar
I have what some people have called a "retention" problem with maintenance. I have 2 pneumatic grease guns set up for lubing those parts. One has Quaker State Synthetic grease(green) and the other has Mobil One synthetic grease (red). I alternate between the two when lubing said parts. One time green, the next time red and so on...
This way it's easy to know when you have replaced all the old grease with new.
I always lube the night before I go wheelin...like I said I have a problem. :
dogonmut is offline
post #11 of 19 (permalink) Old 03-14-2003, 12:11 PM
Damager's Avatar
it's ok Dogonmut...being well lubed is a good thing...I'm sure your lady will agree :
A U.S. VETERAN
Author unknown
Damager is offline
post #12 of 19 (permalink) Old 03-14-2003, 04:27 PM Thread Starter
godless's Avatar
So the Bronco does not have anything like this right?
When I grease the zirks and the grease pops out the top I can just keep pumping until I see fresh grease right?
Thanks that makes me feel better.
Carl Sagan PH.D.
godless is offline
post #13 of 19 (permalink) Old 03-14-2003, 04:31 PM
User This
Canadian Bronco's Avatar
i put more into it until clean grease comes out :mrgreen:
'93 Chevy ext cab 2wd c1500 ( 20s 2/4 drop and cowl hood waiting for spring time to be installed )
VOTE 4 TOP 4x4 SITE!!!
Canadian Bronco is offline
post #14 of 19 (permalink) Old 03-14-2003, 04:43 PM
Davids78Bronco's Avatar
This is what I do too, with all my joints
Davids78Bronco is offline
post #15 of 19 (permalink) Old 03-14-2003, 04:51 PM Thread Starter
godless's Avatar
Cool thanks.
I know I can always rely on the board.
If you ask autozone they tell me
"Now not to much cuz youll break the seal".
I would like to break their seal with my fist sometimes when they answer me like that!
Carl Sagan PH.D.
godless is offline
post #16 of 19 (permalink) Old 03-14-2003, 06:09 PM
Well Done Man!
welndmn's Avatar
Well, Let me bounce a few ideas off this
I don't greese like you guys, i give it 1-3 pumps.
Tie rod for example
I pump it until i see the boot expand, then stop.
You know how when you keep pumping until you see greese come out, it makes that "POP" when the greese come outs?, Guess what, thats the seal that supposed to keep the gunk out, each time to make that seal POP it gets quiter and quiter until it really does not seal very well at all.
Most people never notice this, (i am a freak), but get a new something, greese it, hear the pop, then grease the one on, you can see what you've done to the seal
Mark
71 BKO 42 inch balloons.
http://www.wildhorses4x4.com/
welndmn is offline
post #17 of 19 (permalink) Old 03-16-2003, 03:59 PM Thread Starter
godless's Avatar
Mark I can see that for tie rod boots but what about u-joints and ball joints. There isnt really a "Boot" for them is there?
Carl Sagan PH.D.
godless is offline
post #18 of 19 (permalink) Old 03-17-2003, 02:09 PM
Well Done Man!
welndmn's Avatar
Ball joints use a boot, along with the u-joints, see that little different colored part underneeth the U-joint cap (looks like a ring), thats the boot/seal
Mark
welndmn is offline
post #19 of 19 (permalink) Old 03-17-2003, 03:53 PM Thread Starter
godless's Avatar
Thank you. once again your the man.
Carl Sagan PH.D.
godless is offline
