Dana 44 diagrams - Ford Bronco Forum
post #1 of 13 (permalink) Old 08-21-2006, 09:57 PM Thread Starter
Ragged_ol_86's Avatar
Bronco Info: I dont have one any more. 1994 F-350 crewcab flatbed. 351w efi 10.25" e4od.
Dana 44 diagrams
Does anyone here (steve) have a dana 44 rebuild book or an exploded diagram of a 77 coil d44 so i can figute out what little parts i need? Ie slingers and outer seals and stuff?
Thanks.
Josh Rogers
Rogers Racing Products
Your Local Hometown AMSOIL Dealer!
Sig courtesy of KoJ
CLICKY----> THE DESTROYER
PARTS FOR SALE---->CLICKY
BR is still an emo kid.
Ragged_ol_86 is offline
post #2 of 13 (permalink) Old 08-21-2006, 10:09 PM
rolling Rolling ROLLING....
Bronco Info: 93 Cherokee
not really an exploded view but a nice write up on rebuilding one.
http://www.off-road.com/ford/bigbroncos/tech/dana44/
also small version here....
Exploded View of a Solid D-44
Tim
Newest token Jeep owner....
Redwagon is offline
post #3 of 13 (permalink) Old 08-21-2006, 10:23 PM
PM me your email and I'll email you a gif diagram of one.
ΜΟΛΩΝ ΛΑβΕ
BlueBronco is offline
post #4 of 13 (permalink) Old 08-21-2006, 10:43 PM
Bronco Info: '92 Bronco, 351, 6" lift, 35s, ARBs
You could also try here...straight from the horse's mouth:
http://www2.dana.com/expert/wc.dll?hvtss~deabill~6~
Wasn't sure which model you were looking for when I searched, but if you can find the BOM # on the axle it would tell you exactly everything and every part # you need...
Hope it helps.
orangecrushed is offline
post #5 of 13 (permalink) Old 08-21-2006, 11:08 PM Thread Starter
Where would i find this #?
Josh Rogers
Sig courtesy of KoJ
post #6 of 13 (permalink) Old 08-21-2006, 11:08 PM
should be a metal tag attached to the axle.
Tim
Redwagon is offline
post #7 of 13 (permalink) Old 08-21-2006, 11:23 PM
montanaman81's Avatar
Bronco Info: 1989 302, AOD, D44, 8.8, 31's
stamped on the axle tube
"The beauty of the second amendment is that it will not be needed until they try to take it." -- Thomas Jefferson
"A Bill of Rights is what the people are entitled to against every government, and what no just government should refuse, or rest on inference." -- Thomas Jefferson
montanaman81 is offline
post #8 of 13 (permalink) Old 08-21-2006, 11:46 PM Thread Starter
Thanks all.
Josh Rogers
Sig courtesy of KoJ
post #9 of 13 (permalink) Old 08-22-2006, 12:17 AM
X2...not often easy to see but there nonetheless...focus on the long side first and hope someone hadn't gotten happy with the grinder.
post #10 of 13 (permalink) Old 08-22-2006, 02:16 AM
Steve83's Avatar
Order this catalog, or see if they've put it online yet. I haven't been to this site in years.
http://www.macsautoparts.com/
post #11 of 13 (permalink) Old 08-24-2006, 06:02 PM Thread Starter
ok it doesnt have it on the dana site. The BOM# is 603 808 5 Please help
Josh Rogers
Sig courtesy of KoJ
post #12 of 13 (permalink) Old 08-24-2006, 06:30 PM
Steve83's Avatar
Did you look thru Dana's library? You can dl some of those old manuals as PDFs.
post #13 of 13 (permalink) Old 08-24-2006, 06:38 PM
As long as you're confident that the axle was originally from a '73-'79, you should still be able to find what you need. Dana 44 internals didn't change all that much at all. It should have 30-spline axles, which means its a "later" open knuckle axle. And you probably know this, but a good master rebuild kit will come with new slingers and such...but ask about inner axle seals 'cause some have 'em and some don't. Sometimes there are differences on the outer end from the knuckles out (seal and bearing-wise), but unless the axle has been completely disassembled you should be able to find the numbers you need off of the original parts. Worst case scenario there'd only be 1-2 or at most three different possibilities, so you could find what you need by process of elimination if you HAD to. I doubt it would be necessary to go that route, and again this is only with the "knuckles-out" assembly. As long as you know the pedigree of the axle, any good gear shop like Randy's will steer you right.
Good luck.
