Tapping Steering Gear Box for Hydraulic Assist Lines (PICS) + ram/hose install - Page 2 - Ford Bronco Forum
post #21 of 64 (permalink) Old 12-27-2003, 11:36 PM
They call me "MR FLAT TIRE"
locopny's Avatar
harbor freight has'em on "sale" this month about $11 IIRC
locopny is online now
post #22 of 64 (permalink) Old 12-27-2003, 11:39 PM Thread Starter
huh
Bronkzilla's Avatar
Bronco Info: Half Turd/ Half Zilla
cool.. might have to head down there.. need to finish this truck up so i can get it smogged...
Raf Truth Twister
Bronkzilla is offline
post #23 of 64 (permalink) Old 12-28-2003, 12:45 AM Thread Starter
huh
Bronkzilla's Avatar
got bored.. heres an animated picture..
Raf Truth Twister
post #24 of 64 (permalink) Old 01-08-2004, 11:12 PM Thread Starter
huh
Bronkzilla's Avatar
heres a picture of the filler extension installed.. thanks for the heads up on the heat gun tom.. it worked great..
Raf Truth Twister
post #25 of 64 (permalink) Old 01-09-2004, 01:07 AM
DeepSeaSnake's Avatar
Bronco Info: '80 bronc (currently under construction)
thats grade A shit raf I'll definatly add this to my cheap mod list
'80 rebuilt 302
Performer intake manifold
Holley truck avenger carb
DeepSeaSnake is offline
post #26 of 64 (permalink) Old 01-09-2004, 03:08 AM
scrounger extrordinaire
axaviere's Avatar
Bronco Info: 79 460 6" coming soon...39.5s, D60/D60 ARB/Detroit w/ 4.88s
i saw a guy in a mag and it looked like he used radiator hose & an old filler neck & hose clamps to do the same ghetto style.
take a look at TRUCK my 79 custom. 6" front, 4" rear, 460, 37s, 8 lug conversion. F&R discs. this season, i will have the D60/D60 installed, rear detroit and front ARB with 4.88s and 39.5 IROKs on hummer double bealocks, hydro assist and crossover steering
axaviere is offline
post #27 of 64 (permalink) Old 01-09-2004, 03:14 AM Thread Starter
huh
Bronkzilla's Avatar
thats a damn good idea
Raf Truth Twister
post #28 of 64 (permalink) Old 01-09-2004, 04:53 PM
Rockfrog's Avatar
So is the extension really needed? if it's really only there to increase fluid capacity (normally to allow greater cooling in a hydraulic system), why not plumb a tranny-type cooler into the low pressure side - you'll get better cooling of the fluid than a simple increase in capacity will allow for and - looking at the size of the extension - you'll get a larger increase in capacity. Just don't go overboard as a hydraulic system is supposed to run at reasonably high temps (IIRC ~ 200* or so, I'll check)
Just a thought.
Dave G
81 Bronco Project (actually 76 f250, 76 f150, 81 Bronc, 84 Bronc, etc) 300-6/NP435/NP203/NP208 d44/9" 3.50's on 33's .. 75% done
Rockfrog is offline
post #29 of 64 (permalink) Old 01-09-2004, 06:07 PM Thread Starter
huh
Bronkzilla's Avatar
ive got an inline cooler on the low pressure side.. i took out thing for put on the crossmember.. the extension is just to keep enough fluid in the pump. when you turn from left to right the fluid rises and sinks. im assuming this is just to keep it from either sinking too low or rising and pouring out of the top.. i went to the boneyard today and picked up a remote resevoir out of an old chevy van. i saw it on the WT website. You just add a fitting to the center of the cap on the pump and connect the hose that is attached to the resevoir.. the chevy pumps had no caps.. they had the cap end closed and it had a metal tube coming out to clamp the hose to.. i should of taken my camera.. i suck at explaining it.. here are the resevoirs.. i grabbed 2 of them...
picked up another steering box .. im gonna tap it and use it as a trail spare..
on the truck
Raf Truth Twister
post #30 of 64 (permalink) Old 01-13-2004, 11:36 AM
FSB Pimpster & Recruiter
allcruisen's Avatar
Bronco Info: '95 302 XLT
great write up Raf, Looks good...Cant wait to see that thing on the trailer....I mean on the Trails. hehehe
Allcruisen
Vote for FOTM !!!
VOTE for TOP 4X4 SITE
"DEATH BEFORE DISHONOR"
allcruisen is offline
post #31 of 64 (permalink) Old 01-29-2004, 07:21 AM
Bronco Info: 87, 302 .030 kenne bell Dana 60/10.25 built/locked, 91 bronco 302 mass air Dana 60/10.25 built/lock
nice job. thanks for the idea/help
yoyo
TFTBronco is offline
post #32 of 64 (permalink) Old 01-29-2004, 07:25 AM
what truck does that power steerign pump coem off of?
yoyo
post #33 of 64 (permalink) Old 01-29-2004, 02:21 PM Thread Starter
huh
Bronkzilla's Avatar
87-96 Ford Econoline V-8 van (5.0/5.8 V-8 engines)
Raf Truth Twister
post #34 of 64 (permalink) Old 01-30-2004, 12:44 AM
flame god's Avatar
Bronco Info: 90 5.0 XLT W/ 93+ F. Clip
I'll ask again here...cause I asked in Rafs last thread about this and never got a reply...
which hose on the ram goes to which fitting on the pump??? Or do you not have it hooked up yet?
It's a long way to the top...if you drive a FULL-size Bronco
flame god is offline
post #35 of 64 (permalink) Old 01-30-2004, 01:34 AM Thread Starter
huh
Bronkzilla's Avatar
must have missed it....
hope this helps
Raf Truth Twister
post #36 of 64 (permalink) Old 01-31-2004, 10:34 PM
m j
BRONCO MASTER
m j's Avatar
depends which way you mount the ram
IMO you should have stayed with JIC steel fittings rather then the aluminum
but opinions are like a holes
good thread
i swear your think i was asking for purple penis polish the way people look at me when i go in to ask for stuff
i swear some of the idiots at the parts stores couldnt pour piss out of a boot with the instructions written in the heel. its amazing
nice one axaviere
m j is offline
post #37 of 64 (permalink) Old 02-02-2004, 03:26 AM
Raffa-
hows the street driving with thos big 42'' tires. does the hyd ass. help keep you going smooth or do u still wonder around the road????
yoyo
post #38 of 64 (permalink) Old 02-02-2004, 03:30 AM
o ya with the upgraded ps pump does it steer like original or worse/better? and if you hook the lines going into the ram oppsit or the other way, will it hurt it or will the ram just push backwards. hope you understand what i mean. just dont want to mess it up.
yoyo
post #39 of 64 (permalink) Old 02-03-2004, 10:47 PM
flame god's Avatar
thanks man
post #40 of 64 (permalink) Old 02-03-2004, 11:04 PM Thread Starter
huh
Bronkzilla's Avatar
Originally Posted by TFTBronco
Raffa-
havent really driven it much .. not enough to get any good info..
the pump seems to work better.. no whine.. havent really tested it out though.. if you hook them up backwards it will push the wheel in the opposite direction really fast.. easy to tell its wrong..
Raf Truth Twister
