Tapping Steering Gear Box for Hydraulic Assist Lines (PICS) + ram/hose install - Page 3 - Ford Bronco Forum
post #41 of 66 (permalink) Old 02-26-2004, 05:27 PM
Bronco Info: 1981 Bronco XLT, New 357W, New Frame
Originally Posted by TFTBronco
where can u find a good ram for cheep????
Yeah - where do you get a cheap ram??? I'm going to do this mod with the SAS for safety and strength... And to take stress off of the steering box.
Pile_Of_Parts is offline
post #42 of 66 (permalink) Old 02-26-2004, 07:38 PM Thread Starter
huh
Bronkzilla's Avatar
Bronco Info: Half Turd/ Half Zilla
check out www.surpluscenter.com i just got their catalog and they have tons of rams
Raf Truth Twister
Bronkzilla is offline
post #43 of 66 (permalink) Old 02-26-2004, 08:45 PM
Bronco Info: 78 bronco custom
I must have missed it so I'll ask.How do you detremine the length of the ram?And are the rams 2 way?Those may sound like dumb quetions but I think I may try to do this on my bronco and I dont want to screw it up LOL.
78 Ford Bronco,460,RV cam,L&L headers,Detriot locker in the 9" rear
madmark is offline
post #44 of 66 (permalink) Old 03-08-2004, 01:21 AM Thread Starter
huh
Bronkzilla's Avatar
my ram has an 8" stroke.. its one sided.. im not sure if they make other lengths or not.. cant help you there..
Raf Truth Twister
post #45 of 66 (permalink) Old 09-09-2004, 07:49 PM
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
How would this cylinder work for hydraulic assit? decent price..
FordPerf300 is offline
post #46 of 66 (permalink) Old 09-09-2004, 08:20 PM
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
you need a double acting ram for hydro assist. My ram I am using I got from surpluscenter for $50.00.
Let's Go Fishing.
jopes is offline
post #47 of 66 (permalink) Old 01-01-2005, 09:13 AM
Bronco Info: 1991
Just curious if you had a chance to drive this on the street at all. How does it compare to the stock steering (sloppier/tighter, wander/no wander, easier to steer/harder,etc..). Also, where did you get the saginaw filler neck extension and heat shink tubing?
broke33 is offline
post #48 of 66 (permalink) Old 01-02-2005, 02:00 PM Thread Starter
huh
Bronkzilla's Avatar
its tighter, doesnt wander, easier to steer.. offroad it is great.. got the filler extension with the ram i bought off some guy on pirate.. you can get them from AGR .. i think their site is www.AGRSteering.com
Raf Truth Twister
post #49 of 66 (permalink) Old 01-02-2005, 06:42 PM
Bronco Info: 1991
Thanks for the link, but its no good. Any other ideas where a filler neck extension can be had?
broke33 is offline
post #50 of 66 (permalink) Old 01-02-2005, 07:18 PM Thread Starter
huh
Bronkzilla's Avatar
http://www.agrperformance.com dont remember where exactly on the site..
Raf Truth Twister
post #51 of 66 (permalink) Old 01-02-2005, 07:33 PM
Excessively Engineered
lightnin's Avatar
Bronco Info: 1993 5.8 e40d
So this still uses the Powesteering fluid not Hydraulic fluid right? That is why you have the extention piece on top of the PS pump for the extra fluid and the fluid level raising and lowering due to the ram.
97 tj crawler
93 bronco 5.8 auto
lightnin is offline
post #52 of 66 (permalink) Old 01-02-2005, 08:37 PM
scrounger extrordinaire
axaviere's Avatar
Bronco Info: 79 460 6" coming soon...39.5s, D60/D60 ARB/Detroit w/ 4.88s
ps fluid is hydraulic fluid. yes, the extra volume to fill the ram necessitates the filler neck trick or the reservoir to handle the movement of the fluid
take a look at TRUCK my 79 custom. 6" front, 4" rear, 460, 37s, 8 lug conversion. F&R discs. this season, i will have the D60/D60 installed, rear detroit and front ARB with 4.88s and 39.5 IROKs on hummer double bealocks, hydro assist and crossover steering
axaviere is offline
post #53 of 66 (permalink) Old 03-23-2005, 08:04 PM Thread Starter
huh
Bronkzilla's Avatar
ttt for badass82f100
Raf Truth Twister
post #54 of 66 (permalink) Old 03-25-2005, 01:47 PM
hates EVERYTHING!
Blaze's Avatar
Bronco Info: Jesus loves you!!! I think you're a cocksucker!
Very clean/informative write up Raf. It'll make the addition a breeze for anyone! Great job..
The guy you bought your stuff from, was he an individual or a vendor??
Blaze is offline
post #55 of 66 (permalink) Old 09-15-2008, 09:57 PM
a.k.a.: BigDumbFord
TonyM's Avatar
Bronco Info: 93 "Custom" 1 Ton, Locked Front/Rear, EFI460, C6, Hydro assist,Ballistic High Steer,44 boggers, etc.
Has anyone done this setup using the stock PS pump? Or do you need to go to the saginaw style as referenced above out of the Econolines....?
Also, when you got to Hydro Assist... do you run Power Steering fluid or will Type F ATF still work (Which is what I am running now...)
FOTM September 2009
FOTM June 2011
FOTY 2011
Mat-Su Valley OHV
The Build
TonyM is offline
post #56 of 66 (permalink) Old 09-16-2008, 11:40 AM
is hazardous to others
hav24wheel's Avatar
Bronco Info: Wagoneer, 351M, C6, upside down 205
i tried it with the stock pump... didn't work very well, upgraded to the bolt-on sag. pump. also i run the type F fluid in it and it works great.
i see you know how to search.... lol bringin back a old thread like that..
hav24wheel is offline
post #57 of 66 (permalink) Old 09-17-2008, 12:46 AM
a.k.a.: BigDumbFord
TonyM's Avatar
We just got done tapping our box... and it looks exactly like the pictures (Except steel fittings instead of alluminum).... my question is, the fittings only thread in about 3 full threads (As you can see in the previous pictures as well).... is that normal? Has anyone actually done this and ran it? If so, how well does it work? Anyone spit a fitting or anything?
FOTM September 2009
FOTM June 2011
FOTY 2011
Mat-Su Valley OHV
The Build
TonyM is offline
post #58 of 66 (permalink) Old 03-19-2009, 04:21 PM
Bronco Info: '79 Bronco 14 Bolt rear w/Detroit, HP 44 front w/ARB, 460ci, 36" IROCs
Is there any way to get the pictures back to this thread. I am having a hard time following the directions without them, I am more of a visual type learner.
KTWBronco is offline
post #59 of 66 (permalink) Old 03-19-2009, 04:34 PM
rolling Rolling ROLLING....
Bronco Info: 93 Cherokee
Sorry its been awhile since Raffa has been on...did you check his supermotors site?
Tim
Newest token Jeep owner....
Redwagon is offline
post #60 of 66 (permalink) Old 03-19-2009, 04:41 PM
gone fish'n
jopes's Avatar
click thay link Raf posted on the first page. it has pictures.
none there
Let's Go Fishing.
jopes is offline
