Fuel Pump upgrade 125LPH- 255LPH - Page 2 - Ford Bronco Forum
 2Likes
post #21 of 76 (permalink) Old 11-25-2007, 07:05 PM Thread Starter
Retired Staff
bossind's Avatar
Originally Posted by 94bronco351 View Post
seemed the same to me, I followed that step by step.
Its different than the one I have pictured up top.
bossind is offline
post #22 of 76 (permalink) Old 11-25-2007, 07:07 PM Thread Starter
Retired Staff
bossind's Avatar
When I did mine, I cut the black connector off the top of the new pump and I was able to retain the factory plastic bowl thing. That way I did not have to cut/bend up new steel and all that. not saying it is bad just different, and maybe easier.
dcskater602- I used a holly 190lph from a mustang gt. part number 12-901.
Was your mustang pump longer than the bronco pump? The pump I bought was, so giving the length I didn't see it fitting.
bossind is offline
post #23 of 76 (permalink) Old 11-25-2007, 08:44 PM
Bronco Info: 88 FSB.
If Mustang pumps fit, Walboro makes a 255 that's only like 50 bucks.
The SVT Focus has one that's somewhere around 300lph. That's the most volume for that pump style that I've ever heard of.
My Bronco
Could I have a box of tampons for my Bronco?
Seijirou is offline
post #24 of 76 (permalink) Old 11-26-2007, 07:54 AM Thread Starter
Retired Staff
bossind's Avatar
300LPH, thats crazy. :) Even 255 is way more than we would ever need in a bronco. Interesting though. I noticed the pump I used has a one way valve built in where as the bronco it was built into the plastic housing. I assume this is to keep the fuel from draining back when the engine isn't running.
bossind is offline
post #25 of 76 (permalink) Old 11-26-2007, 08:12 AM
The Focus fuel pumps are the trick for the super/turbocharged mustang crowd.
Exactly. Otherwise it's not going to readily start. Eventually those valves stop working right, and you have that problem. The trick when that happens is to cycle the key on and off once or twice to let the pump prime a couple times before starting it.
My Bronco
Seijirou is offline
post #26 of 76 (permalink) Old 11-26-2007, 10:04 AM
DcSkater602's Avatar
boss what brand pump did you buy??? i found them on ebay... there are a few not-so-name brands on there... you did this write up, and instantly my fuel pump started acting up... it just shuts off about once a day right now... while driving usually... kind of annoying lol
dc
DcSkater602 is offline
post #27 of 76 (permalink) Old 11-26-2007, 10:48 AM Thread Starter
Retired Staff
bossind's Avatar
dc
Dude second paragraph
"My factory pump has been screaming like a cat caught in a blender for almost 2 years now. Not wanting to replace it with an over prices original I bought a WALBRO 255LPH fuel pump, part number GSS340 and the 400-812 install kit. This kit is made for a 5.0 mustang and is good for up to 500HP a little over kill for a stock engine which mine isn't."
bossind is offline
post #28 of 76 (permalink) Old 11-26-2007, 10:51 AM Thread Starter
Retired Staff
bossind's Avatar
Must need that flow rate for the higher RPMs.
Come to think of it, i bet thats why my remote starter would only work ever now and than. And I notices when i went to release the fuel pressure to do the fuel pump which was right after I drove it on the hoist, there was no pressure just a couple drips. The first think I noticed after I did the swap was the pump doesn't kick on when I first turn the key, I got in a habit of waiting for the pump to stop before I cranked the engine over.
bossind is offline
post #29 of 76 (permalink) Old 11-26-2007, 11:12 AM
... thanks
post #30 of 76 (permalink) Old 11-26-2007, 11:12 AM
Bronco Info: 1994 garage ornament
yous looks just like mine, i dunno maybe iam missing somthing?
yes it was the same length as the one you put in. However, when i cut the black plastic clip off the top of the pump it was able to fit it in as long as I took the smaller plastic screen cup off the bottom of the pump. Since the Bronco FDM uses the big bag-screen it didnt need it.
94bronco351 is offline
post #31 of 76 (permalink) Old 11-26-2007, 11:15 AM Thread Starter
Retired Staff
bossind's Avatar
Different than the lightning I mean, sorry.
bossind is offline
post #32 of 76 (permalink) Old 11-26-2007, 11:21 AM
good write-up...im gonna order one of these tonight...
makes me want to order a new gas tank too... ever since i got that poly tank ive had problems... its not the same size... taller, wider etc... the filler neck doesnt line up nice either
dc
post #33 of 76 (permalink) Old 11-26-2007, 11:24 AM
The only thing that looks different is the hard lines are longer comming from the top plate, other then that, the FDM (plastic cup thing) itself looks the same, unless I missed something. I dont mean to be an ass or anything, just trying to understand what is different.
post #34 of 76 (permalink) Old 11-26-2007, 11:27 AM Thread Starter
Retired Staff
bossind's Avatar
I didn't think you were being an ass. Looked different to me in shape was all. Not having seen one in person I wasn't sure if the same mod would work on the bronco - this was before I found out you did it to yours. This is all good info, learning lots here.
bossind is offline
post #35 of 76 (permalink) Old 11-26-2007, 11:28 AM Thread Starter
Retired Staff
bossind's Avatar
dc
Thanks
Good to know about the tank, was thinking about one of those.
bossind is offline
post #36 of 76 (permalink) Old 11-26-2007, 11:30 AM
mine works great, its so quiet that when I first fired it up i thought I messed something up cause I didnt hear it prime.
post #37 of 76 (permalink) Old 11-26-2007, 11:44 AM Thread Starter
Retired Staff
bossind's Avatar
cool, same here very quiet/
I was concern about removing the slosh can, though I might have problems in the corners or steep grades on low fuel, turned out to not be a problem.
bossind is offline
post #38 of 76 (permalink) Old 11-26-2007, 12:19 PM
I seriously doubt the Focus needs that flow rate, it's way overkill. But my thanks for Ford for producing it. You can support well over 500hp on one.
Yeah that's probably exactly why.
My Bronco
Seijirou is offline
post #39 of 76 (permalink) Old 11-26-2007, 10:37 PM
im assuming theres prolly no difference in the 90 pumps???
post #40 of 76 (permalink) Old 11-27-2007, 08:30 AM Thread Starter
Retired Staff
bossind's Avatar
Thats a good question, guess I should find that out and post the years this is good for. Thanks.
bossind is offline
