Fuel Pump upgrade 125LPH- 255LPH - Page 3 - Ford Bronco Forum
 2Likes
post #41 of 76 (permalink) Old 11-28-2007, 11:50 PM
DcSkater602's Avatar
interesting ...i idnt know ford got rid of the shitty connector on the pump... itd be nice to get ahold of a 96 setup like this one... ive got to reach on top of my tank to unplug mine on the 90...
hmmmmmm... i know where theres a 96 bronco in the jyard... maybe ill go pull the tank from it... prolly worth it... my tank sux...i bought one of those plastic ones from JBG... it doesnt fit... the skid plate isnt even tightened all the way up(its dangling by the 2.5" long bolts..the tank is too obviously) and the top of the tank was hitting the floor... my FP connector is broken i discovered today...causing the random FP shutdowns i was experiencing... turns out the pump was fine... thats okay im gonna replace it anyway and convert the crap NAPA one into a siphon pump
dc
DcSkater602 is offline
post #42 of 76 (permalink) Old 11-29-2007, 09:46 PM
Mudd_Slinger92's Avatar
Bronco Info: 1992 Ford Bronco XLT
It might be a dumb question, but how did you flush the tank? Did you just slosh some fresh gas in it and dump out all the dirt, WITH the pump out?
When in doubt...FLOOR IT!! // 92' Bronco XLT 5.0 *GT-40 Heads, ALL Roller, ALL new, summit headers!* 6" RC lift 36" TSL Radials // -Joey
Click my supermotors
http://www.supermotors.net/getfile/592685/fullsize/dscf0029.jpg
Mudd_Slinger92 is offline
post #43 of 76 (permalink) Old 12-02-2007, 01:52 PM
matt4068's Avatar
Bronco Info: 95 f150 - 5.0 e4od
hhhm, i just bought a $150 lifetime Bosch pump.......... daym.
i cant get the vent tube off thats dead center in the tank, ive pryed and pulled, shoved the smallest flat head between the rubber and metal lines and i still cant get it too come off..... any suggestions? \
and great writeup btw, i only wish i found it when my pump went dead on the 28th. then i coulda bought a different cheaper fp since im currently jopbless.
went from a 95 Bronco, to a 95 F150, both 5.0, e40d.
Therefore, we are ambassadors for Christ, as though God were making an appeal through us; we beg you on behalf of Christ, be reconciled to God. He is real, and yes you can trust him, even in this generation.
matt4068 is offline
post #44 of 76 (permalink) Old 12-02-2007, 03:03 PM Thread Starter
Retired Staff
bossind's Avatar
I left it connected and disconnected it at the frame.
bossind is offline
post #45 of 76 (permalink) Old 12-02-2007, 03:05 PM Thread Starter
Retired Staff
bossind's Avatar
I drained the gas that remained, left about a 1/2 cup or so and slushed it around and dumped it into a another container. It was rather clean so I left it at that and used fresh gas to refill.
bossind is offline
post #46 of 76 (permalink) Old 12-02-2007, 11:18 PM
pulled my pump apart(89') they look identical... ill get pics
dc
post #47 of 76 (permalink) Old 12-04-2007, 11:46 PM
pic of 89 pump assembly stripped down for the new 255 lph...
its identcal to yours minus the connector... im thinking about hardwiring the connector and using a connector on the frame like the 96's...
heres the steel tank all cleaned up and painted ill be installing
back to steel plastic is junk
dc
post #48 of 76 (permalink) Old 12-05-2007, 09:57 AM Thread Starter
Retired Staff
bossind's Avatar
dc
Nice!
bossind is offline
post #49 of 76 (permalink) Old 12-05-2007, 05:21 PM
got my bracket made and pump all set up... ill upload the pics when i get back from my mig/tig class at 10...
post #50 of 76 (permalink) Old 12-05-2007, 09:06 PM Thread Starter
Retired Staff
bossind's Avatar
Looking forward to it.
bossind is offline
post #51 of 76 (permalink) Old 12-05-2007, 10:47 PM
go here
post #52 of 76 (permalink) Old 12-27-2007, 02:23 AM
Support our troops!
Dangling_Dave's Avatar
Bronco Info: 1996 Bronco, D-60 5.13 gears Detroit Locked front, Sterling 10.25, 5.13 gears, Detroit locked rear
Great and timely writeup, but I have a few quick questions...
I have an old tired 302 with 220k miles on it. I notice that you are using a 255lph pump, I should be ok with at 190lph right?
I cannot find specs on what the stock pump is rated at, does anyone have this info? ---> HUA problems, I now notice that the stock pump is 125lph...
You use a Walbro brand pump, what are your thoughts on Holley, Edlebrock etc? Are there any I should stay away from?
thanks in advance!
dc
Dangling_Dave
Only WE can prevent Illegal Aliens!
Round them up and send them home
Dangling_Dave is offline
post #53 of 76 (permalink) Old 12-27-2007, 05:34 PM Thread Starter
Retired Staff
bossind's Avatar
thanks in advance!
dc
My OEM pump was 125LPH, 190LPH is more than enough as is the stock. I got my 255LPH for a really good price and it was a brand that was well known by the mustang guys as being reliable. I'm sure Holley and Edlebrock are fine, I would stay away from no name brands.
bossind is offline
post #54 of 76 (permalink) Old 12-27-2007, 07:11 PM
Practicing Infidel
Sixlitre's Avatar
makes me want to order a new gas tank too... ever since i got that poly tank ive had problems... its not the same size... taller, wider etc... the filler neck doesnt line up nice either
dc
Tell the world DC
Every time another newbie asks about plastic tanks, let him have the facts with both barrels !
Nuthin' wrong with a new steelie for under $130.00 what more could you ask for ?
I clean the packing grease off em' and empty a whole spray can of clear urethane onto them, in 6-10 coats.
Keeps the salt and rust away for decades, all for about $5.00 !
Sixlitre
p.s./
Great fabrication ans write up Bossind !
My Superford site
Sixlitre is offline
post #55 of 76 (permalink) Old 01-07-2008, 11:38 PM
OUT OF BUSINESS / M.I.A.
Fireguy50's Avatar
Bronco Info: rusty
Just installed my poly gas tank, and if fit perfectly. Got if from Jeffs Bronco Graveyard
http://www.fullsizebronco.com/forum/21-noobie-bronco-tech-questions-flame-free-zone/112263-fuel-system-repairs.html
Fireguy50 is offline
post #56 of 76 (permalink) Old 01-07-2008, 11:57 PM
Bronco Info: 91 Bronco XLT. 351W, OEM Aluminum Wheels, Rachero RS 5000 Shocks
Walbro makes a good pump. It's worked fine in my car for over a year (and the car's making 400+ RWHP)
91 Bronco XLT - 351W
67 Galaxie 500 2 door hardtop - 302, AOD
86 Chevy C30 3+3 Dullie - 454
2003 Mercury Marauder - Supercharged 281
2004 Mercury Marauder - 281 (The wifes car)
teamrope is offline
post #57 of 76 (permalink) Old 01-08-2008, 08:08 AM Thread Starter
Retired Staff
bossind's Avatar
http://www.fullsizebronco.com/forum/showthread.php?t=112263
Cool, thanks for the update.
bossind is offline
post #58 of 76 (permalink) Old 12-17-2008, 12:27 PM
5billiondead's Avatar
Bronco Info: 94 351 33s, 2.5" lift, red top, Saginaw, 130amp, 4-bolt SOLD: 90 351 D60 KP/10.25, 4.56, 37s
dc
I had the same exact problems with my plastic tank. I bought mine from JC Whitney. It didn't fit right and after fiddling with and unscrewing the upper harness limiting straps until they were maxed out it fit and then while filling the tank I discovered that there was a crack along the side of the tank about half way up. Hell of a thing to discover when you just put close to 15 gallons of gas in your tank and to have it start gushing out instantly. Luckily my garage wasn't far from the gas station so I drove it home spilling gas everywhere. Took it back and siphoned the fuel out, called JC Whitney and they're shipping me a new one free of charge even though they claimed to have never had this complaint before. I think I might sell it though and just buy a new metal one like you had. That or figure out a way to make spacers to make up for the extra height. I guess they had to make the tank larger in order to make up for all of that extra wall thickness, but this is a real headache.
5billiondead is offline
post #59 of 76 (permalink) Old 04-04-2010, 12:23 PM
Bronco Info: 1992 Eddie Bauer 351W want a lift!!
Where did you get the retainer ring from?
http://memimage.cardomain.net/member...920_1_full.jpg
4 inch Rancho lift kit 33" BFG'S K&N Sixlitre upgrade KC Lights Pioneer deck Infinity Subwoofer!!!
biggies92bronco is offline
post #60 of 76 (permalink) Old 04-18-2011, 10:42 PM
Bronco Info: 94 bronco xlt rough country 6" lift 5.0 e4od trans
Quick question... I got a buddy with a walbro like you installed for $50 an was wandering if its drop in other than bracketry... I wouldnt need a new tune or anything right? Adjust regulator psi or anything?
02Mustang GT 3.73's diablo prog. no cats cherrybomb extremes, K&N CAI TFS udp MGW short throw frpp lowering springs 13.4@101mph 1.8 60ft in 1/4 mile with minor wheel spin 94 bronco 4x4 xlt 6" rough country lift more coming
Offroadbronco3388 is offline
