Fuel Pump upgrade 125LPH- 255LPH - Page 4 - Ford Bronco Forum
 2Likes
post #61 of 76 (permalink) Old 04-20-2011, 05:15 PM
Bronco Info: 94 bronco xlt rough country 6" lift 5.0 e4od trans
Anybody?
02Mustang GT 3.73's diablo prog. no cats cherrybomb extremes, K&N CAI TFS udp MGW short throw frpp lowering springs 13.4@101mph 1.8 60ft in 1/4 mile with minor wheel spin 94 bronco 4x4 xlt 6" rough country lift more coming
Offroadbronco3388 is offline
post #62 of 76 (permalink) Old 04-20-2011, 08:39 PM
Wrenching for a Livin'
magnumpi's Avatar
No tuning or fuel pressure adjusting is required. The stock fuel pressure regulator should keep the pressure where it needs to be
My SuperFord
'85 Bronco......
magnumpi is offline
post #63 of 76 (permalink) Old 04-22-2011, 12:26 AM
I wonder if i could get the plastic work some how? Anyone know?
post #64 of 76 (permalink) Old 10-26-2013, 12:05 PM
Riggs's Avatar
Bronco Info: 91 Bronco 5.0 E40D and 4.10 gears
So to all of you that have done this mod, how are these pumps working out ? I love the customization and I am probably in the market for a new fuel pump soon.
Mine is getting loud as hell, I know that doesnt mean that its failure is imminent but its not exactly comforting either. I will probably get the walbro 190. Thanks
91 Bronco 5.0 E4OD and 4.10 gears
"The trouble with quotes on the internet is that it's difficult to determine whether or not they are genuine." - Abraham Lincoln
Riggs is offline
post #65 of 76 (permalink) Old 10-28-2013, 04:56 PM Thread Starter
Retired Staff
bossind's Avatar
bossind is offline
post #66 of 76 (permalink) Old 06-22-2014, 06:41 PM
BoulderBronco's Avatar
Originally Posted by bossind View Post
cool, same here very quiet/
I was concern about removing the slosh can, though I might have problems in the corners or steep grades on low fuel, turned out to not be a problem.
BAM! Found it. Ii was looking for this post as I remembered reading this when doing my research. I think I may be having this exact problem. I just put in a Walbro and it's stalling during hard acceleration and turns.
My thread here (I did not do a writeup but it's the same as yours)
BoulderBronco is offline
post #67 of 76 (permalink) Old 03-04-2016, 09:36 AM
I know this is an older thread but this is a pretty brilliant idea. I went with one of the newer Aeromotive 340 in tank pumps, they run 112 from jegs. I will have to take a couple snap shots when I throw it back together. I just assume add them to this thread if the OP has no argument against that?
scparrish is online now
post #68 of 76 (permalink) Old 03-04-2016, 04:24 PM
Practicing Infidel
Sixlitre's Avatar
I ain't a moderator
but to me it seems like the place to put it, being so related to this here thread....an all.
Sixlitre
My Superford site
Sixlitre is offline
post #69 of 76 (permalink) Old 03-07-2016, 09:15 AM
That's what I assumed.
post #70 of 76 (permalink) Old 01-12-2017, 10:19 PM
Bronco Info: 1994 Bronco EB Edition, Dark Blue c Camel Top, 157Kmiles, 5.8L E4OD Trans, push button 4WD
Your friendly neighborhood Paramedic thanks you!!
medic2731 is offline
post #71 of 76 (permalink) Old 01-13-2017, 02:32 AM
Nothing beets a Fullsize
Kingfish999's Avatar
i recently upgraded to a Walbro 255lph in my 96 to support my 425w. its been working great soo far. its defiantly alittle noisier than stock when you tuen the key but i dont hear it over my engine. i tried for awhile to modify the stock pump housing to fit it but it jsut wasnt working and wasnt worth it. i used a section of all-thread rod and a few hose clamps to mount my pump.
2 things to look out for:
defiantly want to make sure you use EFI fuel hose. its rated for higher pressure than standard fuel hose. i alos used some to lower the return line so it wont splash when tank is low
make sure the pump you use has a built-in check valve. some pumps may not and might drain the fuel back into the tank causing longer startup. the original one was inside the housing, not the pump. the Wlabro is insid ethe pump
Kingfish999 is offline
post #72 of 76 (permalink) Old 02-18-2017, 04:17 AM
Chillin on the Gulf Coast
cajunrebel's Avatar
Hey Kingfish, I ran a setup like yours for a couple years on my 89 and learned the hard way. Even EFI rated fuel hose, is not rated for submersion in fuel. It starts to fall apart after a while. The stuff rated for submersion is significantly more expensive.
Sent from my E6810 using Tapatalk
μολὼν λαβέ
Build the best you can with what you have to work with. Quality parts and quality installation is where it all starts.
"It is idle to say that combinations of old elements cannot be inventions; substantially every invention is for such a 'combination': that is to say, it consists of former elements in a new assemblage."
Supermotors
cajunrebel is offline
post #73 of 76 (permalink) Old 02-18-2017, 01:36 PM
Hillbilly Heaven's Avatar
Bronco Info: 1979 Bronco
Exclamation
Wow this is an old post but needs some updating as far as connection hose is concerned. With most gasoline now having up to 10% ethanol, hose problems have shown up. Even gasoline that claims to be "Pure Gas" can contain up to 5% Ethanol. Ethanol will attack almost all rubber type hoses. Gates does make an Ethanol compatible hose rated for submersion and non submerged. There is a catch though to Ethanol safe hoses. Even though the hose is rated Ethanol safe for submersion there are problems with the hose in submerged use. The inner and outer lining of the hose is Ethanol compatible. BUT it is what is in center layers of the hose that is NOT compatible with Ethanol. The cut ends of the hose allows the Ethanol to wick up in between the layers. The center layers become weak and start to dissolve. As far as I know a solution to this problem has not been found.
Instead of using Part Store type hoses, that will, no matter what the rating, fail. I recommend using an OEM solution that will give years of trouble free life. OEMs have been using clear or black nylon type tubing for years. There is a flexible type that is an excellent solution.
Racetronix - Fuel Feed - Tubes - Plastic
Submersible PTFE Fuel Tubing
They have preformed ends that slip over the metal tube and fuel pump outlet. Yes they are longer and can not be cut. If you use these you want to use one long enough to make a loop without having any kinks. Longer is better. You will want to use some type of clamp on each end. Whatever you use it should be Stainless and smooth on the inside. Screw type clamps are fine as long as the notches are on the outside of the clamp only. Inside must be SMOOTH. No need to put a gorilla grip on the clamp it only needs to be snug. You can heat the ends if needed to be easy to slip on. Use boiling water or hot air. NO FLAME as you will melt the tube.
Both links are excellent suppliers. Racetronix does not offer larger tubes but longer assortment. Radium offers two sizes that appear to be the correct length needed to make a good loop. They also come with the clamps needed. Radium is nice enough to provide a table of pumps and what size they use. If my memory is right the metal tube of the pickup is 3/8 inch. You can try the heat method to slip the 5/16 inch tubing over the steel tube but I do not recommend it.
On the pump side you do not want to force a tube too small onto the spout of the pump. If you force it, then try later to remove it you will break the tip off the spout or break the whole spout off the pump. Both void everybody's pump warranty. This is why you need clamps.
BikerPepe` likes this.
post #74 of 76 (permalink) Old 02-18-2017, 03:44 PM
deathmobile2's Avatar
Here is some cut to fit - glad you brought this up! I am in the process of putting a aeromotive 340 onto 89 pick up and was just going to use the hose supplied in the package.
https://liquidironindustries.com/3-8...Fuel-Line.html
deathmobile2 is offline
post #75 of 76 (permalink) Old 02-18-2017, 03:58 PM
Thanks for the additional link. They call that 3/8 tubing becareful it has a 5/16" ID it will not slip over the metal tube of the pickup. It did remind me of the OEM plastic fuel lines. It maybe possible to use them. I have never tried them submerged in a tank but do know the ID is compatible with modern fuels. Dorman does offer OEM fuel line repair kits that you can find at any parts store.
Some warning about that site: It does not have a secure check out. Also a 1 foot piece of tubing is $8.00 it was $14 shipping and tax. Can do better going to parts store.
post #76 of 76 (permalink) Old 02-23-2017, 12:40 PM
96UAV's Avatar
Bronco Info: 1996 302
Glad to see some updates here! I was just about to go to the parts store to grab the fuel line and went back to this thread to double check measurements. Just ordered both size kits from Radium. Thank you!
Hillbilly Heaven likes this.
Stay positive and love your life
96UAV is offline
