Fuel Pump upgrade 125LPH- 255LPH - Ford Bronco Forum
 2Likes
post #1 of 76 (permalink) Old 11-18-2007, 08:31 PM Thread Starter
Retired Staff
bossind's Avatar
The following Tech Write up was completed on a 96 bronco and maybe off interest to those of you that have done upgrades to your engine such as larger injectors, and for those of you that just want a better quality pump.
My factory pump has been screaming like a cat caught in a blender for almost 2 years now. Not wanting to replace it with an over prices original I bought a WALBRO 255LPH fuel pump, part number GSS340 and the 400-812 install kit. This kit is made for a 5.0 mustang and is good for up to 500HP a little over kill for a stock engine which mine isn't.
The original pump flows at 125LPH, so this is a significant upgrade if I can make it work. I know the factory pump is enclosed in a plastic case, at best this will swap right in and at worst I’ll have to fabricate something to make it work.
With the fuel needle on empty lets begin.
The Kit, I also purchased a pump retainer ring – they are usually rusted past reuse.
If you can get your bronco at a comfortable height to work on
Support the tank so you can safely remove the bolts
Remove the 8 bolts holding the skip plate in place, this hold your tang as well.
Disconnect the connector to the fuel pump
Next disconnect the black vent line, the blue fuel line and the gray return line. You need to use a special fuel line disconnect tool for the blue and gray line.
Loosen the clamp to the filler
Lower the fuel tank and set it down were you can work on it. Even with the needle on empty there was still about 20 liters of fuel in the tank. This is a good time to flush your fuel tank or replace it with a new one. Even though mine looks rough its still sound so I'll just flush it.
There is a tool for this but you can make do with a blunt brass chisel. (use a brass punch and not a steel one as shown to avoid sparks) The ring removes counter clockwise.
With the ring removed you can now pull out the pump
To get at the pump you need to remove these 2 bolts and 1 on top
And here is the old pump removed from its plastic hiding place.
The old on the left compared to the new high flow on the right, notice the differences – it isn’t going to be an easy replacement.
Now faced with the fact the new pump isn’t going to be a direct replacement I need to fabricate a bracket. Here I’m deciding on a length for the bracket and that’s going to be 5 inches x 1 ½”.
Cut out of I/8” flat steel
Sorry I changed the design after realizing the pump outlet wouldn’t align with the sending unit.
I form the bracket around a steel pipe similar in circumference of the fuel pump to hold the pump securely.
Bolt it on and clamp the pump in place
Filter now in place and the wires are connected, it is ready for the tank.
Installed in the tank with the new ring and seal.
Now install the tank and test.
Happy to say the pump can no longer be heard and I’ve noticed I bit more pull during wide-open acceleration up an incline in the road to my house. I’m now ready for larger injectors!
Hope this helps.
bossind is offline
post #2 of 76 (permalink) Old 11-18-2007, 08:37 PM
yes
Mikes79Bronco's Avatar
Bronco Info: 79, 460, 6.5" lift, 38" TSL Super Swampers < Thats the old...check my sig for progress thread
Looks good...I would have cleaned the tank up while i had it out though...
1979 Bronco - In progress
Build Thread
Eating chevys and shitting hemis
Mikes79Bronco is offline
post #3 of 76 (permalink) Old 11-18-2007, 08:41 PM Thread Starter
Retired Staff
bossind's Avatar
Thanks I should mention that.
bossind is offline
post #4 of 76 (permalink) Old 11-18-2007, 08:43 PM
Why bother with the time of unbolting the tank, just grind the bolts off.
Need4racin is offline
post #5 of 76 (permalink) Old 11-18-2007, 08:49 PM
DcSkater602's Avatar
granted i had to grind a bolt or two off once... not recommended... but why would you grind them???
whyd you go 255lph??? are you planning a big HP motor in the future??? my factory fuel pump whines like all hell...its pretty loud
cost for all of this???
dc
DcSkater602 is offline
post #6 of 76 (permalink) Old 11-18-2007, 08:51 PM Thread Starter
Retired Staff
bossind's Avatar
Cause mine came right out?
bossind is offline
post #7 of 76 (permalink) Old 11-18-2007, 08:55 PM Thread Starter
Retired Staff
bossind's Avatar
dc
Price was good - $80.00 off of ebay, and I am building a bigger badder motor and I want to make sure it gets it fuel. And since I had to replace the pump anyways and I don't like doing things twice I went with the better fuel pump now.
bossind is offline
post #8 of 76 (permalink) Old 11-19-2007, 05:55 AM
Bronco4Life's Avatar
Just curious, is the power draw from that 255lph pump significantly higher then the stock pump?
+ lots of cool crap.
Originally Posted by dgmid61
Bronco4Life is offline
post #9 of 76 (permalink) Old 11-19-2007, 07:28 AM Thread Starter
Retired Staff
bossind's Avatar
Certainly there is more draw, our wiring and dedicated fuel pump relay on the bronco are up to the job.
bossind is offline
post #10 of 76 (permalink) Old 11-19-2007, 07:43 AM
Some assembly required!
Dave's Bronc 90's Avatar
Bronco Info: 90 EB, 351W, E40D, D60 SAS, 10.25 rear, ARB's front & back, indellible Cheerwine stain in carpet
You want to hear something weird? The fuel pump went out on my '95 BMW K1100RS motorcycle, and I couldn't afford the $375 the BMW dealer wanted for it. I ended up using a new Bosch pump for a Ford Explorer 5.0 that looked identical to that, $55 from Advance. Can't speak for the flow numbers, but they look identical. Apparently that style pump really gets around. Nice write up, I love seeing alternatives to the stock stuff.
Dave's Bronc 90 is offline
post #11 of 76 (permalink) Old 11-19-2007, 09:00 AM
Bronco Info: 88 FSB.
Originally Posted by bossind View Post
There is a tool for this but you can make do with a blunt chisel. The ring removes counter clockwise.
Please people don't use steel/iron/etc for this. You have a fuel tank here that will blow up if you throw sparks.
Get yourself a brass chisel/punch that will not throw sparks.
Think about the poor people that will need to clean up your charred guts!
Seijirou is offline
post #12 of 76 (permalink) Old 11-19-2007, 09:14 AM Thread Starter
Retired Staff
bossind's Avatar
Its unlikly but it could happen. I didn't use the punch the ring was too rusty so I pulled it out. I'll update.
bossind is offline
post #13 of 76 (permalink) Old 11-19-2007, 09:17 AM
It is unlikely but it only takes one.
Seijirou is offline
post #14 of 76 (permalink) Old 11-19-2007, 09:20 AM Thread Starter
Retired Staff
bossind's Avatar
You point is valid, Iím not arguing with you. I have made the necessary changes to the write up.
bossind is offline
post #15 of 76 (permalink) Old 11-19-2007, 09:27 AM
Sorry I didn't mean to sound argumentative. I'm agreeing with you that it's unlikely. I think we're both in agreement all around.
I saw the change
Seijirou is offline
post #16 of 76 (permalink) Old 11-19-2007, 01:14 PM
Bronco Info: 95 Bronco XL, 5.8, E40D
Heres another write up, thanks to 94Bronc351 for finding it
http://www.nloc.net/vbforum/gen-1-li...-thread-2.html
beckyandrich is offline
post #17 of 76 (permalink) Old 11-19-2007, 01:34 PM Thread Starter
Retired Staff
bossind's Avatar
I seen that, but its different than what our Broncos use for a pump housing.
bossind is offline
post #18 of 76 (permalink) Old 11-25-2007, 04:27 PM
what braqnd was it??? im looking at them on ebay now
dc
post #19 of 76 (permalink) Old 11-25-2007, 06:43 PM
Bronco Info: 1994 garage ornament
When I did mine, I cut the black connector off the top of the new pump and I was able to retain the factory plastic bowl thing. That way I did not have to cut/bend up new steel and all that. not saying it is bad just different, and maybe easier.
dcskater602- I used a holly 190lph from a mustang gt. part number 12-901.
94bronco351 is offline
post #20 of 76 (permalink) Old 11-25-2007, 06:46 PM
seemed the same to me, I followed that step by step.
