Mirror Replacement on 96 Bronco - same for many - Ford Bronco Forum
post #1 of 38 (permalink) Old 04-07-2008, 10:27 PM Thread Starter
Retired Staff
bossind's Avatar
Even though this is for a 96 with signal mirrors, the install would be the same for all year broncos with this flag style mirror.
The mirror on the drivers door meet an unfortunate fate, finding a replacement proved challenging. My 96 Eddie Bauer Bronco comes with what they call signal light mirrors, a cluster of LEDS behind the mirror form an arrow. What’s interesting is the mirror has a laminated optic over the LEDS so the driver does not see the LEDS when illuminated, but is visible from the side and back of the bronco. I soon found out these were discontinued from ford and no one made an aftermarket replacement with the built in signal light.
It wasn’t so much the coolness of the signal light as it was the uniqueness to my bronco that I wanted to preserve – only 96 Broncos had this option.
After much searching I found a site http://car-part.com/ and after searching for a drivers side mirror with signal it came up with a few sites and on in particular Alpha Automotive, Inc. Reporting they had a new one in stock. I emailed for more information and gentleman named Wade replied back confirming he had what I needed, I called to close the transaction and found out not only did he have one but 38 in stock!
Today my new OEM drivers side mirror showed up.
Lets begin the install.
Tools
Philip Scredriver
#25 Torx bit
8mm Socket
Large flat tip screwdriver or upholstery tool
Drivers door with the broken mirror, you'll want to start with the window down.
There are a total of 8 screws to remove before the door panel can come off.
There is 1 screw in the arm rest
1 in the upper right hand corner
5 along the bottom
rug covering might be hiding some of them, but they are there so find them and remove them
The last and 8th screw is in the switch pad
You may remove the switch pad all togeather or you can tuck it into the panel as i did.
The vent latch need to be out of the way, open the window only slightly
Using a flat tip screw driver locate the plastic clips holding the panel on.
Pry them free and work your way around the panel till it hangs freely.
After you remove the panel you will need to unhook the light, 1/4 turn and it pops out.
This is what you should be looking at, great time to upgrade the speakers.
Locate the 8mm bolt that supports the mirror
remove the bolt
The mirror wire harness connector is located below the speaker
With a 25 Torx bit remove the 2 torx screws holding the mirror, support the mirror so it doesn't fall out
Slowly pull the mirror and its wire harness out
The new and old mirror
Clean up the surface where the mirror mounts.
Install the new mirror:
Start by feeding the wire harness from the mirror in the hole in the door
Care must be used so the support bracket doesn't pinch the harness
Apply Anti Seize to the new screws that came with the mirror
On the bolt use some sort of Loc Tight, you don't want this to work its way loss or you have to take the panel off again to get at it.
With the harness hooked up its time to test the mirror, this is a view to other drivers
What the driver sees - just a mirror.
Before reinstalling the panel, apply some grease to the window track
Panel install is the reverse
And heres the end result
Special Thanks to Wade at Alpha Automotive, Inc.
3980 Velp Avenue
Green Bay, WI, 54313
Phone: 1-920-434-0772 or 1-800-317-1270
Fax: 1-920-434-0884
bossind is offline
post #2 of 38 (permalink) Old 04-07-2008, 10:46 PM
Bronco Info: 94 xlt, 3in bl, 33's, new trans, rebuilt 302. 2kwatt stero system
how much was the mirror? ive considered buying them just beucase mine are beat up
metal1313 is offline
post #3 of 38 (permalink) Old 04-08-2008, 03:45 PM Thread Starter
Retired Staff
bossind's Avatar
Originally Posted by 89MustangGX View Post
If they're cheap enough I might buy them just to add them to my truck. So ... how much?
Looking at 500.00 for a pair.
bossind is offline
post #4 of 38 (permalink) Old 04-08-2008, 04:57 PM
c-dub's Avatar
Bronco Info: 96 xlt 5.8 (blk) e40d
i think new from ford was 250.00 back in the long ago. may be worth picking up a set just to have
black 96 5.8 xlt sport, e40d, edelbrock intake, bassani y-pipe, bilstien shocks, 32"bfg's
azure blue 03 mach1 4.6 dohc
"Sorry - no matches. Please try some different terms."
c-dub is offline
post #5 of 38 (permalink) Old 04-08-2008, 05:20 PM Thread Starter
Retired Staff
bossind's Avatar
Bet you it was more like 500.00 each from ford.
bossind is offline
post #6 of 38 (permalink) Old 04-08-2008, 08:51 PM
Bronco Info: 92' 6" lift on 35s 302
do you have to already have the signal mirror you get those cuase i ahve a 92 eddie bauer but not the signal ones can i still install em?
Winners never Quit, Quitters never Win!!
Go big or Go home!!
http://www.supermotors.net/18152
BroncofrmTX is offline
post #7 of 38 (permalink) Old 04-08-2008, 08:55 PM Thread Starter
Retired Staff
bossind's Avatar
It could be done, you would have to mod your harness.
bossind is offline
post #8 of 38 (permalink) Old 04-08-2008, 10:52 PM
c-dub's Avatar
nah, this had to be about 10 years ago. when i got my truck, used from the dealer. the mirror had a defect in it, 250 comes to mind from the parts department... dealer cost.
c-dub is offline
post #9 of 38 (permalink) Old 04-09-2008, 09:21 AM Thread Starter
Retired Staff
bossind's Avatar
391.69 with Signal
219.91 with out.
bossind is offline
post #10 of 38 (permalink) Old 04-09-2008, 07:42 PM
Mike5959's Avatar
Bronco Info: 1996 Bronco 4" Lift and 33x12.50x15
damn. I didnt even realize my bronco had the signal mirrors till last week but my pass side doesnt lights up. Are they servicable? I havent taken it apart yet.
Mike5959 is offline
post #11 of 38 (permalink) Old 04-09-2008, 07:58 PM Thread Starter
Retired Staff
bossind's Avatar
Not really, but it might just be a bad wire.
bossind is offline
post #12 of 38 (permalink) Old 04-10-2008, 10:53 AM
Steve83's Avatar
You can retrofit them, but your mirror connector won't match the signal mirror's, so you'll have to either splice some wires or track down the proper connector to splice onto your door harness. Click my black Bronco below & look thru the Flag Mount Mirror album.
post #13 of 38 (permalink) Old 04-11-2008, 12:19 AM
c-dub's Avatar
i'll post up some pics of the guts. just had mine broken over me elbow.... i think, busted in 4 pc's.(the light not the bow)
c-dub is offline
post #14 of 38 (permalink) Old 04-11-2008, 02:37 PM
c-dub's Avatar
not the best pic, it looks like the glass pops out to get to the motors and than the chrome or black back is held by 4 torx screws. cant make out the leds, but its the white blob in the corner
c-dub is offline
post #15 of 38 (permalink) Old 04-11-2008, 03:27 PM Thread Starter
Retired Staff
bossind's Avatar
Thanks for posting the pic!
Heres whats on the back side of the mirror.
bossind is offline
post #16 of 38 (permalink) Old 04-13-2008, 01:15 PM
c-dub's Avatar
Red face
wouldn't happen to have a wiring diagram for a 94 power mirror...would you?
c-dub is offline
post #17 of 38 (permalink) Old 04-13-2008, 02:36 PM
Steve83's Avatar
Yeah, it's either in my Diagrams album, or the Flag-Mount Mirrors album.
post #18 of 38 (permalink) Old 04-19-2008, 01:37 PM
c-dub's Avatar
got it steve, was in the diagram section. looks like all the wires are the same color/function, but the 96 has two extra for the arrow led's.
c-dub is offline
post #19 of 38 (permalink) Old 04-19-2008, 06:19 PM Thread Starter
Retired Staff
bossind's Avatar
after calling every junkie in the book i ordered one from alpha, placed the order tuesday afternoon and it was sitting on my door friday after "happy hour" thanks for the info
cool
bossind is offline
post #20 of 38 (permalink) Old 05-18-2008, 09:29 PM
Drew2010's Avatar
Im not much of a poster over here but the info is great here at FSB. So if I have this right, it was an option on 96's but all have the wiring. not all have the signals. Because I have a 96 F150, would that have the wiring? I am very interested in these mirrors.
Drew2010 is offline
