Installing SUMMIT Shorty Headers on a 1989 Ford Bronco - Page 14 - Ford Bronco Forum
 3Likes
post #261 of 272 (permalink) Old 05-02-2013, 01:35 PM Thread Starter
Harley's & Bronco's FTW!
Summit claims you should gain 15 HP from installing these headers and I have to agree that the feeling is noticeable and the sound, while not any louder is somewhat “throatier”.
I wouldn't call it a "Holy Sh!T!" kind of improvement. More of a "hey, right on!" kind.
BikerPepe` is online now
post #262 of 272 (permalink) Old 09-17-2013, 12:50 AM Thread Starter
sorry guys. my original pics were jacked up from supermotors maleware problem. Never got it fixed after it was resolved, until now.
helirich: Mine we're summit, as referenced at the part number pic at the beginning of the thread.
They obviously have a very healthy "flange".
Evan_P:
Here, you can see the EGR tube pre-installed.
In this pic, you can see the tube entrance to the header, just under the first plug at the bottom of the pic. Hope that helps.
post #263 of 272 (permalink) Old 09-17-2013, 02:56 PM
September 15 FOTM
ANGELO's Avatar
Bronco Info: 1992 F-250 custom, 7.3 idi, zf5, 4x4
PARTS (Where’s my DAMN STICKERS?):
were does the small bar in the middle go? i dont see were i would mount
1992 f250 turbo intercooled idi
ANGELO is offline
post #264 of 272 (permalink) Old 09-17-2013, 06:36 PM Thread Starter
Originally Posted by Evan_P View Post
I meant how do you get to the spark plug to change it? The first 3 don't look bad, but the rear looks like a pain. That pic does help a little though. Thanks.
I hope somebody will chime in here... but I replaced my plugs for the same reason and the truck was sold before I ever had to go deal with it. I'm going to suggest a swivel socket or removing the header, but as I said... I never had to go back after it.
Even IF someone chimes in here on your question, no guarantees. I'm pretty sure I've still got that little bracket in my toolbox. I think it was meant to help relocated one of the accessory parts to clear the new headers. Unfortunately, I did this writeup over 10 yrs ago, so it's long since gone in my mind. sorry.
post #265 of 272 (permalink) Old 06-19-2016, 09:59 AM
tombIII's Avatar
Bronco Info: 1990 xlt 5.8
GR8 ! well done thanks
tombIII is offline
post #266 of 272 (permalink) Old 06-19-2016, 02:50 PM
September 15 FOTM
ANGELO's Avatar
i have had mine for 3 years now. the egr tube almost cracked off and part of #1 cylinder tube had a pretty good size crack. i just welded it but i think next time im going to buy ones that are alittle more expensive
ANGELO is offline
post #267 of 272 (permalink) Old 06-19-2016, 04:21 PM
I would have expected more vulgarity and flying wrenches but great work! All header can be a major PITA, I like either Allen bolts or header studs to make my agrivation a little less, stainless is your friend fastener wise.
I think the bracket is for A/c or PS, I can't remember but the bracket in certain locations is used where a manifold, stud would have been to mount a bracket.
post #268 of 272 (permalink) Old 08-11-2016, 03:32 AM
I did done broke it
InsanePyro's Avatar
Bronco Info: 1993 F150 5.8L 2WD a.k.a RaceTruck 1994 F350 7.5L ZF5 2WD a.k.a TankTruck
So all you did was zip tie the secondary air crap up out of the way?
Surviving is winning. Everything else is bullshit. Whatever it takes, kid. Survive.
Forever in search of 1FMEU15H5JLA59703
InsanePyro is offline
post #269 of 272 (permalink) Old 08-11-2016, 01:47 PM Thread Starter
yep. never had an issue with it.
post #270 of 272 (permalink) Old 03-03-2017, 06:20 PM
@BikerPepe`
I just unboxed my set and the instructions say it's for models with a "secondary AIR tube".
I quote: " on the 70-1323170-1325 models, the secondary AIR tube has a plastic diverter valve at the rear. This valve must be moved away from the header by using the steel bracket included. This bracket will bolt to the tubes location and the tube will mount to the bracket."
The engine they are going on is a 96 f350 with a 351, that is speed density. It has some odd emissions equipment that my 94 and 95 didn't have so I might find out. I know half of that crap is unhooked though so who knows.
BikerPepe` likes this.
BigBlue 94 is offline
post #271 of 272 (permalink) Old 03-04-2017, 01:24 AM Thread Starter
finally. that's been buggin' me.
seriously though, glad somebody got the question answered.
BigBlue 94 likes this.
post #272 of 272 (permalink) Old 03-04-2017, 03:35 PM
Pulled my y pipe off and cut the ends off to remove the two-bolt flanges, so i can re use them on my new custom y-pipe. The driver side had 2.5" pipe, while the passenger side had 2.25" pipe... From the factory. This is a 96 f350 with 351. I thought that was rather odd.
