Installing SUMMIT Shorty Headers on a 1989 Ford Bronco - Page 3 - Ford Bronco Forum
 3Likes
post #41 of 272 (permalink) Old 05-18-2003, 09:27 PM
OUT OF BUSINESS / M.I.A.
Fireguy50's Avatar
Bronco Info: rusty
Originally Posted by 81Bronk36
That angle your talking about is 90 degrees out from the head, so its really no angle at all lol.
No. The GT40P's do seem like it, but there is still an angle to the plugs. And you are corect they are straighter in the head. I've liked their performance, I plan on upsizing the valves in a while. Hope to stuff 1.90 - 1.60 in them. But they work great on my 363
Fireguy50 is offline
post #42 of 272 (permalink) Old 05-18-2003, 09:27 PM
FSB warrior
81Bronk36's Avatar
ya thats the same one I got im pretty sure(drivers side), its the tube that runs under and touches one of the boots that I had the most problems with.
1BadBronco
81Bronk36 is offline
post #43 of 272 (permalink) Old 05-18-2003, 09:31 PM
Fireguy50's Avatar
Bronco Info: rusty
I played it safe from the start and got those fiberglass boot covers. I thought that wit hthe amount of money spent in exhaust work, $8 per cover was a good idea.
Side Note:
The 9mm Ford Racing wires seem pretty well built and made to handle lots of heat and stress. I love mine.
post #44 of 272 (permalink) Old 05-18-2003, 09:45 PM
FSB warrior
81Bronk36's Avatar
Im runnin 4 MSD 90 degree custom wires and 4 accells for a 81 Bronco. I havent built up the last 4 accells cuz I havent found looms nor installed any
my wires look like a tangled mess!! I put header wrap around the tube that practially touches the boot, so far its lasted the longest with that and the dent in it.
1BadBronco
post #45 of 272 (permalink) Old 05-18-2003, 10:22 PM
Fireguy50's Avatar
Bronco Info: rusty
So you have the P's as well? on that 320+HP 302? LOL
you really need to get it dyno'ed, LOL. I was rating my truck in the 340's untill I saw the real numbers from the dyno. There is a big difference between preception and fact.
What headers did you use? the MAC set for both sides? If you ever need a passanger side replacement let me know. The MAC 302 header didn't fit on the 351 block.
post #46 of 272 (permalink) Old 05-18-2003, 10:30 PM
FSB warrior
81Bronk36's Avatar
hmm that doesnt sound good!! What you running for parts??? I didnt exactly stick a stock iron intake and 2 brl carb on there. Im gettin it dynoed as soon as I get it running the way I want it(like better then 4MPGs) Stupid centrificul probillet distributor is a bitch to figure out what springs to run.
Im running Macs both sides. Got em from Central Coast Mustangs, the guy didnt tell me they were direct replacement, just that they would fit the P heads.
I think im gonna fill out my Superford with exactly what I got... then Ill get hood pins with some locks on em!!
1BadBronco
post #47 of 272 (permalink) Old 05-18-2003, 10:42 PM
Fireguy50's Avatar
Bronco Info: rusty
Check out my engine on my superford site. not sure what the chassie dyno gave me but i didn't even come close to 200.
BUT, don't mock me or doubt the truck:
story time, LOL:
I once had a friend "test drive" LOL a 95 lightning. Well then I showed up at the light, LOL. the salesguy was clueless. We each aniled it for almost 1/4 mile, or at least untill we were aproaching 80MPH. The 95 lightning was only avout 2 truck lengths ahead of me.
MY TRUCK:
363
B&M drag AOD with a 2.40 first gear
3.55 diff ratio
29" tires
95 LIGHTNING:
351
AODE 2.70 first gear
4.11 diff ratio
30" tires
So the lightning drivtrain should have given him a clear head start. But my engine was compensating for my wimmpy gear ratios.
I'll be swaping to 4.56 / 33" tires this year
And a AODE will be comming in the budget some day.
I'll also be swappign to a TrickFlow 351 intake in the next few months.
SO the Dyno says I suck, But the street says different. This whole real chassie dyno thing makes me wonder what the factory rates engines at.
post #48 of 272 (permalink) Old 08-26-2003, 08:21 PM
Oscar's Avatar
Bronco Info: To much to list look at my supermotors site
it was a good help for me I finally put in my ford motorsport stainless steel headers they bolted rigth in with no problems thank you pepe you saved me alot of extra hours
1996 Bronco now 514 efi bigblock(was 351 sc) E40D sas D-60 and 10.25 5.38gears 46 claws http://www.superford.org/registry/ve...dex.php?vID=26
Oscar is offline
post #49 of 272 (permalink) Old 09-05-2003, 01:25 AM Thread Starter
Harley's & Bronco's FTW!
Hey Oscar... no problem man! Love to hear that helped someone out.
Knowing that I had something to contribute to that awsome beast of yours... I'm honored.
BikerPepe` is online now
post #50 of 272 (permalink) Old 03-08-2004, 11:33 PM
PrerunnerBronco's Avatar
Bronco Info: 1994 FSB XLT 351, 35" Toyo Opencountry A/T, Autofab Long Travle F&R, lockers w/456
What was the part number on those gaskets? I have been looking for them but found nothing for the FSB or F-150.
PrerunnerBronco is offline
post #51 of 272 (permalink) Old 03-09-2004, 06:22 AM
Oscar's Avatar
mr gasket #5930
Oscar is offline
post #52 of 272 (permalink) Old 03-21-2004, 06:17 PM
Master Bater
plug ugly's Avatar
Pepe, bringing up your thread.
How are those painted headers holding up to your weather??????
Stupid is as Stupid does
mostly a 94 Bronco
wt4wheeling
plug ugly is offline
post #53 of 272 (permalink) Old 03-21-2004, 10:05 PM
Master of the Estate
PaulT's Avatar
Bronco Info: '71, 4" lift, Rebuilt 302, Edlebrock carb/intake, MSD ignition & dizzy
According to Chilton, 12-15 lbs of torque on the valve covers, retighten after 2 min
PaulT is offline
post #54 of 272 (permalink) Old 03-23-2004, 03:27 PM
Bronco Info: 1981 Bronco XLT, New 357W, New Frame
I bet they are rusted already - mine only stayed black for a couple days..
I've tried EVERYTHING - Header paint, POR-20 Paint, and MagnetPaint!. Nothing sticks...
They all burn right off!
Pile_Of_Parts is offline
post #55 of 272 (permalink) Old 03-23-2004, 04:09 PM
Master Bater
plug ugly's Avatar
I dont care how they look, I just want to know if they are holding up well as far as sealing, etc.
mostly a 94 Bronco
wt4wheeling
post #56 of 272 (permalink) Old 03-23-2004, 09:41 PM
Diesel Gynachologist
Dustin's Avatar
Bronco Info: 2001 F350
jet hot them, they have locations here in phx but not sure where else. that stuff is the shit for coating headers!
Ford Senior Master Technician
http://www.superford.org/registry/ve...x.php?vID=1309
"The existence of flamethrowers is proof that someone, somewhere, said to himself, "I want to set those people over there on fire, but I don't feel like walking over there to do it."
Dustin is offline
post #57 of 272 (permalink) Old 03-24-2004, 03:51 AM
What Side Up?
FatMan's Avatar
Bronco Info: '89 Bronco,MSD Coil/Wires,3" Cat Back,Summit Headers,Rough Country 2.5" Lift,4.56's gears,33"A/T's.
hey was doin some searching and found this thread. just like to say great right up 4xPepe`and theres some good gouge on this thread.
i just found a crack in my passenger side exhaust manifold and went to get some jb weld to patch it up and saw that the crack goes all the way around the manifold so it looks like header time. i've been checking out the summit headers just have to come up with the $$$$.
hey 4xPepe` i was wondering how your headers were holding up also???
hey 81Bronk36 does that header wrap keep that area cool??
'89 Bronco-DD
'87 Bronco II Hybrid-Trail Rig
LUCKY13
Darker than your average wheeler.....
FatMan is offline
post #58 of 272 (permalink) Old 03-24-2004, 09:56 AM
Master Bater
plug ugly's Avatar
what kinda cost we looking at dustin? Is it better just to get stainless I wonder?
mostly a 94 Bronco
wt4wheeling
post #59 of 272 (permalink) Old 03-24-2004, 10:53 AM
Pissin' into the wind
Bronco Info: I don't even own a Ford anymore...but I still luv you guys
If you don't have one of those Jet Hot type places in your area there is probably something equivalent. Out here in Utah there is a place called HPC Coating that does the same stuff. When I get some headers I'm taking them straight to HPC.
My friend coated his header and tail pipe on his quad and you can literaly touch the pipe after one to two minutes of sitting after a long ride. Its amazing how cool that coating keeps things.
Also, from what I understand you can coat just about anything with that stuff. I'm also thinking about doing my intake manifold. Sorry plug, but I don't know prices off the top of my head, I know its not pocket change though, but its also not going to break you.
...thoughts arrive like butterflys...
Burl Swift is offline
post #60 of 272 (permalink) Old 03-24-2004, 07:20 PM Thread Starter
I replied to plugs PM, but for eveyone else... the headers have been holding up great.
They aren't the purtiest things around, but I've got no complaints.
Here's a little shot of drivers side on the new engine... (10 months later)
YOu can see it's starting to look a little rusty, but there's no roblem structurally. They actually look less rusty in person.
Also... changing plugs is a bitch, but not as bad as I originally anticipated.
Cost was under $200 and I had mine overnight.
Thanks D-diesel.
