How to properly set the timing on a 302 or 351 - Page 4 - Ford Bronco Forum
 4Likes
post #61 of 69 (permalink) Old 06-24-2015, 05:55 AM
MinesBigger's Avatar
im going to be using this write up this week. hopeflully ill be able to get this things running.
00Excursion V10 4x4 - 93Bronco 5.8L 4X4
.__-0_0_0
L__|_\__\___
|/--\_/--\[FORD]
(o)_) (o)_)-o-)_)
MinesBigger is offline
post #62 of 69 (permalink) Old 08-27-2015, 04:18 PM
Bronco Info: 86 5.0L AOD man.t-case
What should I be expecting with ECM advance at idle?
I'm showing like 27, I think. I advance the dial on my light to about 17 ti find my 10 degree mark. Is this correct?
I've been going through TFI modules (on my third). Seems the truck has a different personality every time.
86 5.0L AOD man.t-case, too ugly to include a pic, me or the Bronco.
Unkleskunky is offline
post #63 of 69 (permalink) Old 08-28-2015, 08:09 AM
ourobos's Avatar
Bronco Info: 1986 XLT - 408w, TFS 170s, TFS Camshaft, C6
The ECU adds 16 degrees of timing.
ourobos is offline
post #64 of 69 (permalink) Old 08-28-2015, 01:33 PM
Thanks, It is dropping rpms too low and stalling at times. After warm start, usually just once, sometimes with gear selection change.
I just changed out the TFI module(again) 6-8 months on the prior, several years of very poor performance on the one previous to that. I remote mounted this one. It acts now like the power band is different again. Getting tired of this shit.
post #65 of 69 (permalink) Old 09-27-2015, 11:00 PM
This is the best and most complete information that I've found anywhere on the internet. Simple to the point. Thanks. All my questions answered in post. Thanks.
dps444 is offline
post #66 of 69 (permalink) Old 09-30-2015, 08:38 PM
JKossarides's Avatar
Interesting that it's hit or miss with parts sometimes, my Motorcraft distributor and Motorcraft TFI module have been on my BKO since 2004 and still going strong.....IDK......
JKossarides is offline
post #67 of 69 (permalink) Old 01-31-2016, 11:07 PM
Use the Force...
Darth_ted_82's Avatar
Bronco Info: 1988 Eddie Bauer; 5.0L AOD; 3" suspension lift w/33x12.50 KOs. '77 F100 Custom, step side, restoring
Outstanding, Sackman. Thanks a lot for the write up. Worked like a charm.
sackman9975 likes this.
'88 Eddie Bauer, '98 5.0L w/GT40p heads, HD AOD, 130A 3G, 3" suspension w/33x12.50KOs, Tow Package.
Porkchop Express' Thread - http://www.fullsizebronco.com/forum/...d.php?t=279266
Blacksheep 2/75
R.L.T.W.
Darth_ted_82 is offline
post #68 of 69 (permalink) Old 04-08-2016, 10:16 PM
mamunoz4's Avatar
Bronco Info: 88 ford bronco, 302 V8, 5 speed manual trans W/overdrive, 6" custom lift, 35" MT's, 4.56 Gear Ratio
Yo Sackman! Great write up bro. Got my Bronco running better then every after I pulled the distributer without marking the rotor like a jackass. Many thanks ?
mamunoz4 is offline
post #69 of 69 (permalink) Old 11-11-2016, 05:44 PM
offroadgearhead's Avatar
Bronco Info: 89 Custom, 5.0, auto
Great info here! I took my newly purchased 89 Bronco to the smog shop (it's like going to do your taxes when you know you are gonna owe) and it failed. Took it home and found a bad vapor canister and needed to adjust the timing. It was at 22 deg. BTC. I unplug the spout connector and set it at 10 degrees BTC and when I plug it back in it jumps back up to about 22 degrees again. This was one issue that caused it to fail the smog test. Is this normal or is something else causing it. Any help would be appreciated.
offroadgearhead is offline
