D44 TTB Tie Rod End (TRE) flip - Page 3 - Ford Bronco Forum
 3Likes
post #41 of 46 (permalink) Old 03-20-2013, 06:44 PM
Beach bumming it ........
Saltlife's Avatar
Thanks bud for the write-up. I followed it and it came out great on my bronco:
http://www.fullsizebronco.com/forum/...=1#post3061199
Saltlife is offline
post #42 of 46 (permalink) Old 09-22-2014, 04:52 PM
T/C
Bronco Info: 94 351 EOD 120k miles6 " db lift on 35" super swampers
Anyone still have a reamer they would loan out if I pay shipping? Will also replace if damaged.
T/C is offline
post #43 of 46 (permalink) Old 10-19-2014, 11:23 PM
dirty_drew's Avatar
Bronco Info: 88 Bronco, 4.9l 5 speed, 32" Falken Wild Peaks, 2" lift
Anyone know if this is a worthwhile mod on something with 2" of lift? I'm just interested in the better clearance they provide.
Chevy lover
dirty_drew is offline
post #44 of 46 (permalink) Old 10-20-2014, 03:12 AM
Nothing beets a Fullsize
Kingfish999's Avatar
generally its more for 4+ inch lift. just like a dropped pitman arm but better
also Saltlife, did you use the sleeves? you know the idea of using the sleeves is to ream the hole deeper than without so you don't hourglass the hole.
Kingfish999 is offline
post #45 of 46 (permalink) Old 10-23-2014, 10:17 AM
89 Problems
Happster's Avatar
Bronco Info: 1989 with MAF 351w, D60 front w/ARB, 14 Bolt rear W/ARB, c6, 1356, 37s, Cage arms, etc
So, let me get this straight.
If I wanted to do this (after/during my 4" lift) It would be better to do it with Chevy TREs, but they are thicker than the ford ones so would not require the 30 dollar sleeves? I would just have to use the same reamer and keep testing with the actual TRE until the hole was the right size?
I know you believe you understood what you think I said
but I am not sure you realize that what you heard
is not what I meant
Happster is offline
post #46 of 46 (permalink) Old 03-16-2017, 01:14 AM
Ready 4 a Mid-Life Crisis
CDA 455's Avatar
Bump and subscribed !
Excellent write up.
BikerPepe` likes this.
μολὼν λαβέ
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline
