Look here for all the diesel swap thread links - Ford Bronco Forum
post #1 of 10 (permalink) Old 08-29-2012, 01:27 AM Thread Starter
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
Post the Diesel swaps into FSB's in this thread.
Let's Go Fishing.
jopes is offline
post #2 of 10 (permalink) Old 08-29-2012, 01:33 AM Thread Starter
gone fish'n
jopes's Avatar
Seawalkersee, 6.9 IDI into a 84. My Diesel install.
Let's Go Fishing.
jopes is offline
post #3 of 10 (permalink) Old 08-29-2012, 02:23 AM
Clarke's Avatar
Bronco Info: F150 ext cab, 5.8 auto/ 96 bronco 5.8 MAF with E4ohishitmyself pushy button 4x4
Sam Burton’s first gen 92 6bt with a ZF 5 tranny and the 205 transfer case into a 78 BKO
My 78 cummins conversion
jfritts 4bt with ZF 5 speed swap
jfritts 4bt Swap
Andrewu6 first gen 6bt and SAS with 5 speed into an 84
84 BRONCO D60/10.25 leaf SAS and cummins swap
Impalaslayer's 2nd gen 6bt with 5 speed into a 76 highboy, not a bronco but a great build
76 hiboy tear down resto mod build thread
52wrench's 4bt swap into a 1990 f150 not a bronco but also a great build
D44 SAS with Cummins swap
strange's 4bt-zf5speed swap into a 95 bko
Good riddance 5.0, hello 4 banger
gos's 2nd gen 6bt with built e40d into a 96 BKO
Cummins conversion started!
nate0031's 7.3 powerstroke swap into a 86 BKO
1986 Powerstoke Bronco Build!
mush's 88 - 7.3 powerstroke swap into a 88 BKO
Another 7.3 Powerstroke Bronco Build
norfolkff05's 7.3 idi swap into a 85 BKO
85 Bronco 7.3idi and 1 ton leaf sas
to name a few, ill find more later
"The definiton of insanity is doing the same thing over and over again and expecting different results." Albert Einstein
obviously he shouldve used a bigger hammer
Clarke is offline
post #4 of 10 (permalink) Old 08-29-2012, 08:44 AM
Thanks 351w500
LarryP's Avatar
American Thunder - The Cummins Bronco 6BT
IMO the Best swap
He puts a Cummins 6BT into his 78 Bronco
The Cummins Bronco
LarryP is offline
post #5 of 10 (permalink) Old 08-29-2012, 04:56 PM
norfolkff05's Avatar
Bronco Info: 1985 EB current 1-ton sas and diesel/zf5 swap in progress
mine is actually a 7.3idi diesel, not a powerstroke. not much different mechanically mine is just lots easier without all the electrical.
dieselboy's 7.3idi swap into a 93 or 95 (not sure year)
http://www.fullsizebronco.com/forum/15-general-discussion-bronco-wheeling-related/170908-diesel-sas-swap-56k-warning.html
norfolkff05 is offline
post #6 of 10 (permalink) Old 08-31-2012, 11:13 AM
yo JOPES,
I have some SWAP LINKs from Other Sites @ http://www.broncolinks.com/index.php?index=834
Such as for example;
Installation Information, 5.9L Cummins; "...A 6 cyl. 5.9 Cummins engine will fit in your full size Bronco, but if you have not already beefed up your front suspension you will want to do so. A minimum fix is a good set of air bags for your coil springs. Other options, if not already done, include a solid front axel or a heavy suspension lift. The full size Ford Bronco takes all of the same Ford Cummins diesel conversion hardware as the F Series Ford pickups of the same year..."
Source: by fordcummins.com at http://www.fordcummins.com/bronco-cu...onversion.html
Installation pics, 5.9L Cummins in an 88
Source: by 88rustsurvivor (monster) at http://www.supermotors.net/registry/19639/75401
Installation pics, Cummins 4BT in a 90
Source: by jfritts at http://www.supermotors.net/registry/20677/73476
Installation pics, Cummins in a 79 F350
Source: by heresHellToPay at http://fordfzone.com/topic/5264-79-f...cummins-build/
Installation, 5.9L Cummins in a 91 (owned by Paul S (Swamp Thing))
Source: by Jason S at http://www.dieselpowermag.com/featur...stroke_diesel/
Installation, 5.9L Cummins pics in an 84
Source: by Andrewu6 at http://www.supermotors.net/registry/22829/75280
Installation, 7.3L & 6.0L in Two 93's (owned by David C)
Source: by David K at http://www.dieselpowermag.com/featur...stroke_diesel/
Installation, 7.3L pics in an 82
Source: by Ford Bronco God and countyhunter6 at http://www.supermotors.net/registry/17115/57969
Installation, Cummins HE341 Turbo (2003-04.5 Dodge Ram) in an 80
Source: by Ryan P (Odey, OD) at http://www.supermotors.net/registry/552/72330
Installation, Cummins in a 91 (pics are gone)
Source: by Wil via vetteboy79 at http://www.pirate4x4.com/forum/showthread.php?t=449496
7.3L (DI Turbo) Installation in a 92 Centurion
Source: by Moseley M (Tow & Recover, Do & Hope, Smooth) at http://www.supermotors.net/registry/18695/71405
7.3L (IDI) Diagnostic Guide for 94-1/2 (422KB)
7.3L (DI Turbo) Installation in an 88
Source: by mush's 88 at Another 7.3 Powerstroke Bronco Build
etc.
post #7 of 10 (permalink) Old 08-31-2012, 10:27 PM
I Paid for this sh!t
stormfinder's Avatar
Bronco Info: None Currently, 2000 Ford Excursion
Stormfinder's 4BTA Diesel Swap - 90 eddie bauer
Stormfinder - Stormfinder's 4BTA Diesel Swap
Project Phoenix - Stormfinder's 4BTA Diesel Bronco swap. Version 2.0 - 90 frame 95 body
1997 Lincoln Mark VIII LSC - 4.6 DOHC V8/4R70w
2000 Ford Excursion XLT - 5.4 SOHC V8/4R100 (Cummins 6bt/5r110 future plan)
SOLD: 1995 4bta Cummins Bronco, zf5, dana 60/sterling 10.25
Jake
Dark times come and they surely do suck... but there's peaks and valleys man. As long as we keep giving it our best, it can only be shit for so long. - Words of a wise man, Pepe
stormfinder is offline
post #8 of 10 (permalink) Old 12-16-2012, 11:07 AM
Thanks 351w500
LarryP's Avatar
Stuck now. I also could not find it last week and gave up.
LarryP is offline
post #9 of 10 (permalink) Old 04-10-2014, 09:00 AM
ilystbronco's Avatar
Bronco Info: 95 fummins / 94 with kp60&10.25, 37s
cummins swap!
here is mine!
#1-95 Fummins,zf5,6"lift,37"s,17klb winch,jbg rear bumper,warn front,sliders,currie 60 rear,detroit lockers front&rear,rcv front axles,super runner steering,cummins 12v,hamilton 188/220cam,66mm turbo,4"exhaust,#10plate,4kgsk,191dvs,5x12 injectors,high rise manifold,pusher intake,dps ex mani,raptor150 lift pump
#2-94 bko aka berneice kingpin60 sas,high stear,10.25 rear,37s
ilystbronco is offline
post #10 of 10 (permalink) Old 03-29-2016, 03:55 PM
IIVIIoonshiner's Avatar
IIVIIoonshiner's SAS with 4BT swap
IIVIIoonshiner's Low Lift SAS
hope it helps someone
Slightly Modified
IIVIIoonshiner is offline
