Bigger Tie Rods + Tie Rod Flip - Page 2 - Ford Bronco Forum
 37Likes
post #21 of 60 (permalink) Old 06-05-2014, 11:26 AM
Bronco Info: 1996 Bronco
Thanks, I will take off one side and see what I have.
CDA 455 likes this.
btrebil666 is offline
post #22 of 60 (permalink) Old 06-05-2014, 11:49 AM
Kingfish999, You are right the RuffStuff inserts that are shown on the links in this post and other posts are for CHEVY, I just called them and they are a 3 degree or 3/4 taper not what is required for the Bronco. Thank you for pointing that out to me and I am glad I called to verify. Looks like I will have to invest in a reemer.
CDA 455 likes this.
post #23 of 60 (permalink) Old 06-06-2014, 12:53 AM
thephalanx's Avatar
Bronco Info: 88 302 Custom M5OD 5spd 6" Suspension 3" Body, 4:56 35" Tires, Detroit Truetrac Front Aussie Rear
Synergy TRE Adapter from Poly Performance. Sold singularly!
These are the ones I ordered for my flip, as mentioned in this thread Tie Rod Flip-Do it now!
They are the 7/8" drill bit type.
thephalanx is offline
post #24 of 60 (permalink) Old 06-06-2014, 11:20 AM
Thanks Thephalanx, I will contact them to get the specs.
post #25 of 60 (permalink) Old 06-06-2014, 12:43 PM
tonygz88's Avatar
Bronco Info: 1990 XLT 351/E4OD 4" lift, 35" GB AT2, Yukon Duragrip rear
Thanks for the post Thephalanx, I think I'm going with those ones now for mine
Originally Posted by AFBronco235 View Post
Welcome to FSB, the only addiction help group that encourages the addiction.
Build Thread
tonygz88 is offline
post #26 of 60 (permalink) Old 06-06-2014, 03:06 PM
The ones that Thephalanx posted are not the correct size. They are 1.5" per foot not 1.25" per foot. I had emailed the company to find out and they are not the correct ones. Just FYI.
CDA 455 likes this.
post #27 of 60 (permalink) Old 06-06-2014, 03:07 PM
I have also called Bronco Grave Yard to find out the spec for the ones they sell, I am waiting for them to get back to me since they don't know the internal dimensions.
CDA 455 likes this.
post #28 of 60 (permalink) Old 06-06-2014, 04:58 PM Thread Starter
Nothing beets a Fullsize
Kingfish999's Avatar
JBG only sells the one and it is the correct. its just a sleeve that's really used just to make smaller tierods fit into bigger hole knuckles. they both use 7* taper
CDA 455 likes this.
Kingfish999 is online now
post #29 of 60 (permalink) Old 06-06-2014, 05:36 PM
tonygz88's Avatar
Oh haha, guess its going to be JBG then.
CDA 455 likes this.
Build Thread
tonygz88 is offline
post #30 of 60 (permalink) Old 06-07-2014, 11:41 AM
thephalanx's Avatar
Interesting. I'll have to take a look at mine then. I have so much slop in my steering before I even get to my tierods that I wouldn't even notice. Glad you checked
CDA 455 likes this.
post #31 of 60 (permalink) Old 11-15-2014, 07:59 PM
bgrdbronc90's Avatar
Bronco Info: 1990 EB Ford Bronco 6 inch lift 3 inch body lift 2 inch spacers
Correct me if I'm wrong but isn't the 7 degree reamer equivalent to 1.5" by foot. Making the poly performance adapters compatible
Tapered reamers for proper fitting of ball joints to spindles, tie rod ends to spindles, etc. These have 1/2" shank. The 1-1/2" per foot reamer, also known as a 7° tapered reamer, works with Speedway ball joints 917-20031 K6024, 917-20032 K6136, and 910-34323 K772.
Measures a little less than 1/2" at the small end and 1" at the big end.
CDA 455 likes this.
“No, you've got that WRONG. I'm even TOUGHER without the badge and gun.”
1990 Ford Bronco Eddie Bauer, 6 inch lift 2 inch coil spacer, 3 inch body lift, 15x10 wheels 38 inch tires MSD ignition and a lot of lights
bgrdbronc90 is offline
post #32 of 60 (permalink) Old 12-24-2014, 09:09 AM
Bronco Info: 1988 Bronco with a 5.8L/C6 35" tires with a 4" lift
tre sleeve
I'm about to do this upgrade in a couple of weeks. I just want to make sure I buy the right sleeve. The one from JBG say they are for 66-77 bronco. I have an 88. Are they the right ones?
CDA 455 likes this.
jweiss is offline
post #33 of 60 (permalink) Old 12-29-2014, 07:21 PM Thread Starter
yes they are right. they are designed for a different purpose but work well for this
CDA 455 likes this.
post #34 of 60 (permalink) Old 07-30-2015, 09:16 PM Thread Starter
jsut to help bump this thread, i used this setup on my 90 F250 with so it seems to work perfectly on TTB D50/44HD axles also. i jsut installed a set into my stock 96 Bronco today.
CDA 455 likes this.
post #35 of 60 (permalink) Old 08-18-2015, 08:53 AM
Mister Sunday's Avatar
Bronco Info: 1984 XLT, 351 4V H.O., C6, NP208, 9"
Dang! I just ordered all the parts for this, then realized my Bronco is an '84. I sure hope they fit. If not I'll be Craigslistin em.
Mister Sunday is offline
post #36 of 60 (permalink) Old 08-18-2015, 10:58 PM Thread Starter
it will work on 80-96. they all use the TTB suspension
CDA 455 likes this.
post #37 of 60 (permalink) Old 08-24-2015, 04:45 PM
FSB Pimpster & Recruiter
allcruisen's Avatar
Bronco Info: '95 302 XLT
Kingfish, do these sleeves also work with the stock Tie rod ends and is JBG the only ones that sell them?
Thanks in advance,
Allcruisen
CDA 455 likes this.
Vote for FOTM !!!
VOTE for TOP 4X4 SITE
"DEATH BEFORE DISHONOR"
allcruisen is offline
post #38 of 60 (permalink) Old 08-24-2015, 07:02 PM Thread Starter
yes the JBG sleeves work on stock tierods when doing the flip. basically the bigger tierods and the tie rod flip are 2 completely individual mods that i jsut combined into 1 thread since i did them at the same time. im not sure where else sells them anymore but im sure there around. as far as i know, Ruffstuff no longer makes the correct ones anymore.
CDA 455 likes this.
post #39 of 60 (permalink) Old 08-24-2015, 10:22 PM
allcruisen's Avatar
Thanks again for all your help...
Allcruisen
CDA 455 likes this.
Vote for FOTM !!!
post #40 of 60 (permalink) Old 09-18-2015, 02:15 PM
Bronco Info: 1981 Bronco
Bigger Tie Rods ?
On the previous post it was confirmed that it would work on early 80s Bronco, but if i don't plan to lift it nor flip it, do i still have to ream it to just install them in their normal configuration?
i just bought a 81 for my son to drive to school when he turns 16 in December, so i have a couple months for a major tune up, replace all suspension, steering, new exhaust, etc,etc,. I plan on replacing all tie rods, gearbox, pump, but if i can go in with a littler better/heavier parts i don't mind spending the little extra.
Thanks,
Rob
CDA 455 likes this.
rebrown2 is offline
