Bigger Tie Rods + Tie Rod Flip - Page 3 - Ford Bronco Forum
post #41 of 51 (permalink) Old 09-18-2015, 06:42 PM Thread Starter
Nothing beets a Fullsize
Kingfish999's Avatar
Originally Posted by rebrown2 View Post
On the previous post it was confirmed that it would work on early 80s Bronco, but if i don't plan to lift it nor flip it, do i still have to ream it to just install them in their normal configuration?
i just bought a 81 for my son to drive to school when he turns 16 in December, so i have a couple months for a major tune up, replace all suspension, steering, new exhaust, etc,etc,. I plan on replacing all tie rods, gearbox, pump, but if i can go in with a littler better/heavier parts i don't mind spending the little extra.
Thanks,
Rob
yes it will still work. no you dont need to ream or flip it. the ream/flip and the bigger tierods are seperate mods that i combined into 1 writeup because i did them at the same time.
Kingfish999 is offline
post #42 of 51 (permalink) Old 09-20-2015, 10:15 PM
Bronco Info: 1981 Bronco
Thanks.
rebrown2 is offline
post #43 of 51 (permalink) Old 09-21-2015, 01:06 AM
blicharski1989's Avatar
Bronco Info: 1996 XLT
Anybody have a reamer they will rent or lend out? Hoping to do the flip to eliminate my bumpsteer.
blicharski1989 is offline
post #44 of 51 (permalink) Old 09-21-2015, 09:05 AM
tonygz88's Avatar
Bronco Info: 1990 XLT 351/E4OD 4" lift, 35" GB AT2, Yukon Duragrip rear
I am buying a reamer this week to do the flip. If anyone needs to borrow it in the future let me know. https://www.facebook.com/groups/DBOR4x4/
Originally Posted by AFBronco235 View Post
Welcome to FSB, the only addiction help group that encourages the addiction.
Build Thread
tonygz88 is offline
post #45 of 51 (permalink) Old 09-21-2015, 06:23 PM
Don't have a Facebook but I'll kick you some money when you're done with it to barrow it for a weekend. I promise to use cutting oil lol
post #46 of 51 (permalink) Old 03-16-2016, 08:05 PM
Bronco Snob
RicoBronco's Avatar
Bronco Info: 1992 XLT 351W E4OD 4" lift TRE flip 130 amp 3G Alt Saginaw P.S. BFG MT KM2 315 75 16
Originally Posted by Kingfish999 View Post
These parts are from numerous types of vehicles to get the most strengths possible. Some parts are from different years, different models, different drivetrains and even different editions.
Are there too many mixed parts, or would the steering system from an f250 or f350 donor work? Im doing the tie rod flip right now and there's a pretty clean 90 f350 supercab at the Junkyard..thought I might upgrade.
A society that puts equality before freedom will get neither. A society that puts freedom before equality will get a higher degree of both. - Milton Friedman -
RicoBronco is offline
post #47 of 51 (permalink) Old 03-17-2016, 12:34 AM Thread Starter
IIRC, the short driver side tie rod is the same as stock for bronco and f250. the longer driver side is indeed stronger however. im not sure about f350 with the solid axles
post #48 of 51 (permalink) Old 03-17-2016, 12:51 AM
Bronco Snob
RicoBronco's Avatar
It's not an f350...it's an f250..my mistake. I think I'll get the entire setup..looks practically brand new, and it's only $27. Thanks for the write-up.
post #49 of 51 (permalink) Old 03-17-2016, 01:09 AM Thread Starter
jsut because its something i should have done i added a small application chart on the second post of what vehicles were offered each part. they do not display what GVW came with them however. clicking on each link will display MOOGs page for each part with a more complete application chart. but that would take forever getting each of those parts from the correct vehicle. good luck
post #50 of 51 (permalink) Old 09-09-2016, 01:53 AM
Heihachi1337's Avatar
Bronco Info: 1996 Ford Bronco XL
Okay, figure I would post my question here (there are 2 other threads that I read up on) regarding the TRE flip.
I have a 4-inch Rancho lift with the drop pitman arm and the old school straight extended radius arms.
I intend to the the TRE flip and there were 3 different sleeves I just saw. The one is from Bronco Graveyard (JBG), the other is the Ruff Stuff specialties (but I think it is for GM, unless someone can confirm the GM and Ford tie rod are same angle?) and the last one was from Poly Performance and I don't think they make the one for a Ford I think I only saw it for a Jeep.
I have no problem buying my own reamer, but I wouldn't mind the other sleeves instead where I don't have to worry about angles just punch a hole and hammer a sleeve until it bottoms on the shoulder. Are the other two sleeves even an option or is the one from JBG really the only one left available and proven?
1996 Bronco XL, 5.8L w/ K&N filter, shorty headers, larger exhaust, E4OD, 3.55 gears, 8.8 (Ford's wannabe GM rear axle), Dana 44, 31x10.5R15....so mostly stock.
Heihachi1337 is offline
post #51 of 51 (permalink) Old 03-16-2017, 01:21 AM
Ready 4 a Mid-Life Crisis
CDA 455's Avatar
Bump and subscribed .
μολὼν λαβέ
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline
