3G alternator FACTS (its wins agian!) - Page 2 - Ford Bronco Forum
 2Likes
post #21 of 377 (permalink) Old 10-14-2004, 04:20 PM
Practicing Infidel
Sixlitre's Avatar
Originally Posted by Stokes
i have been hearing about the 3g having a weak regulator, plus since its an internal regulator, once it goes, its time to get another alt. wasnt it Soderblom that said that he blew one of his 3g's by just holding the window button to long or somthin simular? it just makes the large case alt seem like a better setup, plus it puts out almost just as much power.
Bah ! Wive's tales !!!!
Just do the 3G conversion, the large case is old technology and huge into the bargain. It's easy, cheap and very, very effective. Cured just about all that ailed my 86 electrically.
True Soderblom has it in for the 3G, Ryan's output print outs prove the 3G works from idle up and I've had mine on for three years and it's still kicking !
I believe it was Steve83 that said you can buy the regulator kits for cheap and they can be changed fairly easily.
Sixlitre
My Superford site
Sixlitre is offline
post #22 of 377 (permalink) Old 10-14-2004, 04:56 PM
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
autozone sells the regulators for $42.
I have winched with my G3, one single 800CCA redtop. when the winch turns on the volts drop to 10 or lower if doing a long pull. It just keeps charging.
Let's Go Fishing.
jopes is offline
post #23 of 377 (permalink) Old 10-14-2004, 05:06 PM
aka: kemicalburns
TravisITGuy's Avatar
ryan in the pic of the 3 alternators mine is the style on the bottom. and of course its a 95amp. did those rigs that came with the 130amp use that style at all or where they all like pic 1 & 2.
Thanks
late
TravisITGuy is offline
post #24 of 377 (permalink) Old 10-14-2004, 05:50 PM
TTB Hater of course
Ouch. The external ones are half that for the large case, 1/3 of that if you want the el-cheapo bargain basement special.
Ryan, kudos to you for obtaining real results. Your tests tell me the 3G does great on the RTI ramp, but it doesn't tell me how it does in the real world.
I dunno how anyone would ever do it, but I'd like to see test results immediately after both a 3G and a large-case have been made to do an identical, hard winch pull in the same engine compartment on the same motor on a 95 degree day.
It's common knowledge that heat is the enemy of basically anything electrical; as I look at a 3G and a large case it's a no-brainer to me that the large case is gonna run cooler.
Totally Twisted and Broke makes me a saaaad Panda
"You can almost see the dismay on Phil, Paul & Bob's faces when Trautwig is talking....and the pause in their voices after he stops....after which they pick-up the pieces of his non-sensical commentary and continue with their telling of the story that is the Tour de France! "
TTBlows is offline
post #25 of 377 (permalink) Old 10-15-2004, 02:41 PM
Owned 21 Years
I'm not sure I am following you guys. Here are some pics at this site of two 3G alternators. One is Large case, the other is not. Both are 3G. So, my 1995 3g stock is the small case. if you look at the size of the case it's obvious which is which. You can also look carefully at the holes, you will see a difference. So, for me it's just a matter of converting from the small case 95A 3g to a large case. These pics are for the newer trucks mounting pattern. Look at the pic ofthe alts. from the front. You will notice a "Y" casting with holes inside. Now, the large case has 2 large holes within each Y casting, while the small case has 4 small holes. That's how I tell.
http://www.alternatorparts.com/Ford_3G.htm
post #26 of 377 (permalink) Old 10-15-2004, 03:21 PM
TTB Hater of course
Originally Posted by axaviere
why not stick another fan on the pulley like the large case? that will move some air around it
Might work..........the fan requires a spacer so it doesn't rub the alt body, is the shaft of the 3G long enough? I'd guess not, since it was never built w an external fan. Also, I'd be a little concerned about it properly moving air into the holes (most alts w external fans have large slots)...............and doesn't the 3G have an internal fan? If so I'd wonder if the two fans would cancel each other out rather than work together.
TTBlows is offline
post #27 of 377 (permalink) Old 10-15-2004, 04:14 PM Thread Starter
OUT OF BUSINESS / M.I.A.
Fireguy50's Avatar
Bronco Info: rusty
Those are not FACTS, those are opinions!
I can get a new regulator for $25, its not hard to change it
Maybe I'll do that, just for the tech write up, and to make more FACTS
http://oldfuelinjection.com/?p=72
I wrote this right after the picture, are you blind
Originally Posted by Ryan
Ford part # F6UU-10300-FA is a 130amp alternator for the later serp trucks.
I'm not sure if the dealer would have the best price, shop around and on ebay.
That part number was on:
(1997-03) Ford E Series Van, F Series Pickup 4.2L
(1995-01) Ford Explorer, Ford Ranger 4.0L
Fireguy50 is offline
post #28 of 377 (permalink) Old 10-15-2004, 04:20 PM Thread Starter
Fireguy50's Avatar
Bronco Info: rusty
Thanks for the kind words.
I know the 6G alt on new Fords are controled by the computer. The computer reads the alternators temp, battery voltage, and comands the alt output. That might be able to get that kind of data.
Might just use a digital volt meter, and an inferred temp sensor.
Great link, not sure if the prices are a good deal.
From what my research has found, the small case was only 95A. The 130A alternator was only built in the large case.
post #29 of 377 (permalink) Old 10-15-2004, 04:43 PM
I'm no expert!
BigNorm's Avatar
Bronco Info: 1982 Toyota with the roof cut off. 351W, D60 welded, 14bolt, 5.13s, on 39.5 TSLs with beadlocks.
I got a 3G today off of a 93 Sable. In the middle it says 130A. I also took a big chunk of the harness so hopefully I'll have enough wire to work with. I got the alternator, oil cooler w/ hose and engine attatchment, Transmision cooler, F250 Master Cylinder, Booster, power steering pump reservoir, and two T shirts today for $75 at my local Pick n Pull's half price sale. Whaaaat a bargain!!
1982 Toy Chasis & Cab. 351W, C6, NP203/205, D60 welded, 14 bolt Detroit & 5.13s, running on 15" wheels and 40s.
BigNorm is offline
post #30 of 377 (permalink) Old 10-15-2004, 06:08 PM
gone fish'n
jopes's Avatar
I got my 130 amp G3 from the junk yard. It costed me like $15 bucks.
Oh looky here. I got both in my bronco...Wait the top one is a welder
Let's Go Fishing.
jopes is offline
post #31 of 377 (permalink) Old 10-16-2004, 02:17 PM
Chris85xlt's Avatar
Bronco Info: 85xlt with stuff
i just went to the junk yard 2 days ago and picked up a 3.0L 92 Taurus with harness. i took it to kregans and had them test it and it passes :). so far i havent found any 130amp stamping on it and its not listed on Ryans post. any other way to find out?
Chris85xlt is offline
post #32 of 377 (permalink) Old 10-16-2004, 03:21 PM
Zach94's Avatar
Bronco Info: 5.0HO, AOD, 1345, cut fenders, body lift, 37" MT/R's, 5.13's with a 14bolt in back and a full spool
you said you had it tested, how many amps did it push out?
Zach94 is offline
post #33 of 377 (permalink) Old 10-16-2004, 03:27 PM Thread Starter
Fireguy50's Avatar
Bronco Info: rusty
Most places only test if the alternator is at 14volts.
Not many places can test amp output.
All the Taurus / Sable should be 130, because of the electric fan
post #34 of 377 (permalink) Old 10-16-2004, 06:24 PM
I'm no expert!
BigNorm's Avatar
The little center shiny aluminum piece on the back side of my alt had 130A printed on it. It looks like it would come off if any oil/solvent splashed on it.
BigNorm is offline
post #35 of 377 (permalink) Old 11-02-2004, 04:32 PM
FSB warrior
81Bronk36's Avatar
I couldnt find any at any of the junkyards around here so I won one on Ebay for 42 bucks including shipping. I hope it works Coming soon... Write up for V belt/external regulator vehicles. Its gonna be so easy
1BadBronco
81Bronk36 is offline
post #36 of 377 (permalink) Old 11-02-2004, 05:07 PM
Practicing Infidel
Sixlitre's Avatar
It will be easy for you 81Bronk36
It worked great on my V-belted 86(cured a lot of problems). Do you have a double pulley on you current 2G ?
Sixlitre
My Superford site
Sixlitre is offline
post #37 of 377 (permalink) Old 11-02-2004, 11:28 PM
Practicing Infidel
Sixlitre's Avatar
I have 2 alts, one in storage thats double, one on the truck that is single. Which do you suggest I use??
The double I had (other groove runs my air pump) didn't allow the 3G nut very far onto the 3G shaft, five threads I think.
I lived with that for almost a year and then deepened the pulley center with a lathe so the nut goes well and truly on far enough.
The reason I mention this is you need a wafer thin washer(got one at Home depot) to keep either pulley far enough away from the 3G alternator housing or it will rub. That washer makes the pulley/nut problem even worse.
If you've got access to a lathe on the base you might want to deepen the double groove pulley center almost 1/4" ahead of time.
Sixlitre
My Superford site
Sixlitre is offline
post #38 of 377 (permalink) Old 11-12-2004, 05:16 PM Thread Starter
Fireguy50's Avatar
Bronco Info: rusty
I added the 200A 3G to the first post:
http://oldfuelinjection.com/public/a...200_output.jpg
post #39 of 377 (permalink) Old 11-12-2004, 09:02 PM Thread Starter
Fireguy50's Avatar
Bronco Info: rusty
The bottom guage is alt RPM,
looks like 6600RPM to me.
Divide by aprox 3 = 2200 engine RPM
post #40 of 377 (permalink) Old 11-17-2004, 02:17 AM
Bronco Master
BroncoAZ's Avatar
Bronco Info: 87 Bronco...in progress
Can the 3G be setup to run an external regulator like the large case? I had to replace the 3g (from autozone) in my truck 3 times before I swapped to the large case. Each time it was the diode that went bad. Since my coilover swap I can no longer fit the large case, and replaced it with a tiny 60A for the time being.
Mitch
BroncoAZ is offline
