3G alternator FACTS (its wins agian!) - Page 24 - Ford Bronco Forum
 2Likes
post #461 of 478 (permalink) Old 01-10-2015, 01:36 AM
Steve83's Avatar
You need to fill in your profile & signature with all your truck's details so we know what you're working on, and can tell you what it needs. Click this & read the caption:
http://www.supermotors.net/registry/media/72354
post #462 of 478 (permalink) Old 01-14-2015, 06:19 PM
Owned 21 Years
Originally Posted by Fyrmn1979 View Post
So since I have been a member of this site the members have been an amazing help to any and all of my questions. So here we go for another one, does anyone know where I can get the 3g upgrade harness or can someone give me some pictures. The ones at the beginning are not visible, also none of the 3d upgrade harness links work. Any help will be greatly appreciated, my buddy totaled his 1997 5.0 explorer and it looks like a 3g but im not sure if it is ill grab it and then I just need the harness info. Thanks in advance
Did you look in our vendors forum:
LEB 3g Alternator Kit
post #463 of 478 (permalink) Old 01-14-2015, 09:27 PM
Bronco Info: 1995 Bronco 5.0 4x4 Eddie Bauer all stock
Rookie
Noob update I added info about my truck but ill do it here also 1995 Bronco 5.0 Stock, please let me know where I can buy or how I can make the harness I will be getting the alt soon. Thanks
Fyrmn1979 is offline
post #464 of 478 (permalink) Old 01-14-2015, 09:53 PM
Steve83's Avatar
Your truck already has a 3G.
post #465 of 478 (permalink) Old 01-25-2015, 01:19 AM
Thanks guys for all your help, Steve83 your the man again... thanks awesome to know it already has a 3g.
post #466 of 478 (permalink) Old 01-26-2015, 02:09 AM
MORE POOWER
So I found out I have a 3g alt. but it is only a 95amp, I was wondering what if any ford I could pull a 130amp alt out of? I will go to the junk yard for the core and get the bigger one new if its possible... also would I need to change anything in order for this to work. Thanks again guys
post #467 of 478 (permalink) Old 02-14-2015, 07:54 PM
GvilleBKO's Avatar
Bronco Info: '90 EB w/ '96 gt40 5.0, AOD, electric TC, 3.55 TTB/8.8
Did the 3G swap today. Pulled the alternator off a 96 V6 tbird @ the JY, snagged the harness and mega fuse with it. Reused/adapted the vr plug/wiring, and ran my own 2awg welding cable for the charge wire. Reused the mega fuse w/ a Bussman fuse holder.
Worked out great! Charges @ 14.4v with all electrical maxed out.
"If you ain't first, you're last" - Reese Bobby
GvilleBKO is offline
post #468 of 478 (permalink) Old 09-20-2015, 12:17 AM
helirich's Avatar
Does anyone know where the tach wire or terminal is? I've done allot of searching and they all say the 3G has tach out put, but where?
helirich is online now
post #469 of 478 (permalink) Old 11-06-2015, 04:25 AM
andyyy2586's Avatar
Originally Posted by Sixlitre View Post
You're preaching to the converted Ryan !
Nice work on the photos ! I'd say the 3G swap was the single best mod I've done to my 86 ...period.
It was also a virtual bolt on for us V-belters.
Nice to see the proof though
Sixlitre
Yes the mustang 3G will work. I have done this swap and have pictures I can send you if you shoot me a private question. However you will need to do some minor modifications to allow it to physically fit as the 3G uses a larger casing.
andyyy2586 is offline
post #470 of 478 (permalink) Old 01-05-2016, 02:44 PM
jknc's Avatar
Bronco Info: '87 Bronco, '80 302 V8
I'm trying to find the one that will fit the v belt motor. Every one I find has the serpentine flat style pulley. Do you have to swap the pulleys?
jknc '87 Bronco 302 4x4
jknc is offline
post #471 of 478 (permalink) Old 01-12-2016, 09:20 AM
aschessla's Avatar
Bronco Info: 1996 Eddie Bauer
I cant implore enough the benefits of upgrading the cables as well. I had a 110 amp on my '96 that I was not getting the benefit from. I did the Big 3 upgrade and the amps starting flowing! Definitely worth it!
aschessla is offline
post #472 of 478 (permalink) Old 01-12-2016, 09:22 AM
jknc's Avatar
I had to go with a stock one for now. I couldn't find a 3g with a v belt pulley. I am going with 6 gauge wire for when I do the 3g swap in Spring.
jknc - '87 Bronco w/ '80 302
jknc is offline
post #473 of 478 (permalink) Old 03-04-2016, 09:05 PM
ScottE's Avatar
Bronco Info: 1994 XLT 351-4"Cepek w/arms-Eaton E-locker-33" Yoko M/T+ tires-RockRing-K&N FIPK-TSM rear discs
Which regulator?
I purchased an alternator from Fireguy a few years back, and recently after starting my 94' Bronco, the volt gauge maxed out and blew out my headlights. I replaced the alternator with one from a ford van (not sure of the model #, but is the same 3G case). I'd like to get the Fireguy alternator working again, but am not sure which regulator (I assume that's what went wrong) to buy. Would this one work?
Amazon.com: Voltage Regulator for Ford 3G Alternator w/ Brush Holder (Heavy Duty): Automotive
Any other links to good regulators?
Scott
1994 XLT 5.8
Rear Eaton E-locker/4.56 gears-TSM rear discs
Yokohama Geolander M/T+ 33's
Cepek 4" lift with arms
Custom Y-pipe w/single Dynomax cat/ K&N FIPK
ScottE is offline
post #474 of 478 (permalink) Old 03-29-2016, 03:58 PM
IIVIIoonshiner's Avatar
is there a "redhead" alternator one could buy?
i know that steering gears have an aftermarket king (redhead)
is there an aftermarket king for alternators? $$ no object
Slightly Modified
IIVIIoonshiner is offline
post #475 of 478 (permalink) Old 03-29-2016, 04:18 PM
aschessla's Avatar
Not sure if aftermarket kings but I got mine from here, Alterstart. I got a 250amp. Great guys, easy to work with and helped me out. Make sure they include the extra shims since the pulley is smaller.
post #476 of 478 (permalink) Old 05-13-2016, 11:05 AM
B-man's Avatar
I have a 1992 Bronco now.. I did this 3G upgrade on my previous 1988 Bronco.
The pics are gone from this thread (lol) so, I am not sure what I am looking for again. I don't think I have a 3G in my rig already, so...
Anyone with a 92-96 do this upgrade?
If so, any information would be great.
Thanks in advance.
B-man is offline
post #477 of 478 (permalink) Old 09-29-2016, 05:46 PM
i have a 1990 with a 4.9l in it and i cannot find how to do this alternator upgrade or what alternator will bolt in would someone be willing to help me please
kyacklich is offline
post #478 of 478 (permalink) Old 03-21-2017, 11:25 AM
Fitzy's Avatar
Picked up a 130amp Alternator for something like $70 a few months ago, absolutely loving it!
Fitzy is offline
