3G alternator FACTS (its wins agian!) - Page 4 - Ford Bronco Forum
 2Likes
post #61 of 481 (permalink) Old 02-09-2005, 11:44 PM
Practicing Infidel
Sixlitre's Avatar
Originally Posted by BroncoAZ
Can you recommend a good place to get a 3g? or am I better off getting something custom wound?
See if Ryan has any of those 200 amp 3Gs left
If not head over to P.A.Performance and pay too much. I just grabbed a jobber remanufactured 130 amp unit and it's still going strong three years after the warantee ran out (touch wood).
Sixlitre
My Superford site
Sixlitre is offline
post #62 of 481 (permalink) Old 02-13-2005, 01:12 AM
actually, if you are serious about a truely high quality alternator, skip on the P.A. Performance BS and give Dominick a call @ Iraggi Alternator in TN. They are unbelieveably cheap for what you get. Anyone who has priced one from Ohio Generator knows what i'm talking about..... Dominick custom builds them to your specs, and offers the 3G's in 190, 220, or 240 amp versions. But I couldn't care less about their max output, what sold me is the idle charge.
Gamehunter is offline
post #63 of 481 (permalink) Old 02-13-2005, 03:45 AM
I'm no expert!
BigNorm's Avatar
Bronco Info: 1982 Toyota with the roof cut off. 351W, D60 welded, 14bolt, 5.13s, on 39.5 TSLs with beadlocks.
You got an address/link/email/number? I'm all into getting good service for an honest price.
1982 Toy Chasis & Cab. 351W, C6, NP203/205, D60 welded, 14 bolt Detroit & 5.13s, running on 15" wheels and 40s.
BigNorm is offline
post #64 of 481 (permalink) Old 02-13-2005, 08:05 AM
YER FUKKED NOW...BITCH!
Damager's Avatar
Bronco Info: 1986 Eddie Bauer,1991 EFI 302, TTB and Spooled 8.8 with 35's .. for now....Carnage is Good
I have one of these 200amp 3G units coming beginning of the week for $160.00 :)
Output at idle = 95 amps
http://cgi.ebay.com/ebaymotors/ws/eB...%3AWN%3AMT%3A1
Call Steve Lewis Call toll free at 800-753-2242 and tell him Ron From FullsizeBronco sent you
]http://www.supermotors.net/getfile/624303/fullsize/bronco- ]A U.S. VETERAN[ Whether active duty, retired, national guard or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to "The United States of America", for an amount of "up to, and including, my life." :
That is honor, and there are way too many people in this country who no longer understand it." Author unknown
Damager is offline
post #65 of 481 (permalink) Old 02-13-2005, 10:24 AM
Practicing Infidel
Sixlitre's Avatar
Which is ?
Sixlitre
My Superford site
Sixlitre is offline
post #66 of 481 (permalink) Old 02-13-2005, 01:22 PM
Damager's Avatar
hopefully mine will produce what is claimed above
Damager is offline
post #67 of 481 (permalink) Old 02-22-2005, 09:31 AM
Bronco_In_Ny's Avatar
Bronco Info: 90 bronco 392 stroker motor, 80mm Pro-M MassAir conversion, edlebrock upper and lower intake manifol
I have a quick question, I have a 200amp 3G that I'm going to be putting in today or tomarrow and I've seen installs where you use both a new 2 or 4 gauge wire as well as taking the 2 older hot wire and running and then seen installs where you just use a 2 or 4 gauge wire and get ride of the old harnes with other hot wires. My question is which way should I do it?
90 fullsize bronco
6in ProComp lift stage2 in front
4.5in superlift springs w/2in blocks
351w stroked to 392
Roush Racing heads w/stage2 porting
80mm ProM MassAir Conversion
MSD igntion sys (Complete)
Gibson headers W/true dual exhaust
Edelbrock Upper and lower intake manifolds
BBK 56mm Throttle body
200amp alternator
Auburn ECTED locker in the rear
35in Thornbirds
Super Motors Garage
Bronco_In_Ny is offline
post #68 of 481 (permalink) Old 02-22-2005, 03:26 PM
I got tools-i can fix it
Bronco Info: 1983 Full Size Bronco
you need to isolate the wires. to the alt you need a ignition hot signal wire and the 2 guage charge wire. i ran new wires to the alt and the new circuite breaker and the battery to relay. in the old harness is a couple wires that need to get connected to a battery source or you will not have power in the bronco.. here ws my swap over.
http://www.supermotors.org/registry/...=22835#content
mike
collinsperformance is offline
post #69 of 481 (permalink) Old 02-22-2005, 03:27 PM
Try it now!!
kf4amu's Avatar
Ryan McCormicks way (Fireguy50). It works.
-Will
89 XLT 460 (recent 3g install with 2 gauge wire)
kf4amu is offline
post #70 of 481 (permalink) Old 02-22-2005, 03:55 PM
Practicing Infidel
Sixlitre's Avatar
If memery serves me right
You're talking about the two fairly large 10 gauge wires (orange with black tracers) that feed the body harness power, correct ?
I spliced them together onto one larger 4 gauge wire as per Brian Soderblom's diagrams. Apparently if you don't then trying to run that kind of amperage down a 10 gauge wire can get pretty darn hot
Sixlitre
My Superford site
Sixlitre is offline
post #71 of 481 (permalink) Old 02-22-2005, 08:17 PM
Its in and Running I used This, THanks to Fireguy's site. I've needed a new Alternator for along time now my Ignition as well as the rest of my bronco can have the Power it needs Muuuhhhhhhhhhhhhh
http://fordfuelinjection.com/public/...ALT_wiring.gif
90 fullsize bronco
351w stroked to 392
200amp alternator
35in Thornbirds
Super Motors Garage
post #72 of 481 (permalink) Old 03-15-2005, 08:09 AM
OX1
OX1's Avatar
Just curious!! If the 3G can be boosted to 200 amps, why does the ford ambulance package bother going to a large case 1G?
http://homepage.mac.com/mcgroves/PhotoAlbum20.html
OX1 is offline
post #73 of 481 (permalink) Old 03-15-2005, 08:40 AM Thread Starter
OUT OF BUSINESS / M.I.A.
Fireguy50's Avatar
Bronco Info: rusty
You must be blind, cause that is a NOT a large case 1G
That is a Mitsubishi Alternator that can crank out close to 300Amps in the right conditions
Ford hasn't use the crappy 1G in 25+ years!
The Mitsubishi Alternator costs over $400
I only have 160Amp 3G's for sale now
Fireguy50 is offline
post #74 of 481 (permalink) Old 03-15-2005, 01:36 PM
Practicing Infidel
Sixlitre's Avatar
Originally Posted by Fireguy50
Ford hasn't use the crappy 1G in 15+ years!
It costs over $400
Ain't gonna find parts for that ricer piece on Sunday, deep into buttf#%&k county, 12 hwys off the interstate.
The nearest Taurus in a local junkyard (or dark parking lot) will yield a temporary replacement for Ryan's 3G, if it ever gives you trouble (not likely).
Sixlitre
My Superford site
Sixlitre is offline
post #75 of 481 (permalink) Old 03-15-2005, 02:38 PM
OX1
OX1's Avatar
You must be blind, casue that is a NOT a large case 1G
It costs over $400
Sorry, thought it was a re-packaged large case. Anyway, what do you think of that alt?? Found it here for $173.
http://autoexpress.safeshopper.com/1311/cat1311.htm?342
OX1 is offline
post #76 of 481 (permalink) Old 03-15-2005, 02:39 PM
OX1
OX1's Avatar
Sixlitre
If it's a direct swap (cept for 1/2 inch belt length), why couldn't you use that taurus alt if the big mitsu craps out??
OX1 is offline
post #77 of 481 (permalink) Old 03-15-2005, 03:09 PM
Stuck like a MoFo
85f150's Avatar
Bronco Info: Srry no Bronk only a F150
look at the big mitsu case, it has different style mounting like a diesels, not the norm 6 and 12 positions.
Truck Porn mooseracing.org
1985 F150 300 cubic inches of raw tq
79 XS 1100 SF
79 Firebird & T/A
64/65 Studebakers
85f150 is offline
post #78 of 481 (permalink) Old 03-15-2005, 03:43 PM
B-man's Avatar
Damn, ANOTHER upgrade to do.. I am going to be installing a winch soon, so maybe this upgrade should happen as well.. Got some pick yards that carry a bunch of cars.. Hopefully I can find one of these alternators.
B-man is offline
post #79 of 481 (permalink) Old 03-15-2005, 03:59 PM
Practicing Infidel
Sixlitre's Avatar
Naaa
If you're already 3G, then you're GGGolden
OX1
Apart from the different mounting ears(like 85F150 notes), I'd bet at least one molar tooth they ain't wired with the same plugs either.
Sixlitre
My Superford site
Sixlitre is offline
post #80 of 481 (permalink) Old 03-15-2005, 04:10 PM
OX1
OX1's Avatar
Good point!! I'm thinkin it fits where a 3G fits, so it would swap. Totally overlooked the mounting, DUH!!!
OX1 is offline
