3G alternator FACTS (its wins agian!) - Page 5 - Ford Bronco Forum
 2Likes
post #81 of 480 (permalink) Old 03-15-2005, 08:51 PM Thread Starter
OUT OF BUSINESS / M.I.A.
Fireguy50's Avatar
Bronco Info: rusty
Originally Posted by OX1
Sorry, thought it was a re-packaged large case. Anyway, what do you think of that alt?? Found it here for $173.
http://autoexpress.safeshopper.com/1311/cat1311.htm?342
That sounds like a good deal.
Originally Posted by Sixlitre
Apart from the different mounting ears(like 85F150 notes), I'd bet at least one molar tooth they ain't wired with the same plugs either.
Sixlitre
Will you ship teeth to Michigan
Ryan McCormick
Fuel Injection Technical Library
Parts replacement is not auto repair, if you canít diagnose, donít open the hood!
Fireguy50 is offline
post #82 of 480 (permalink) Old 03-15-2005, 08:57 PM
Practicing Infidel
Sixlitre's Avatar
D'oh !
Wait ! I'm invoking the tiny little white wire (w/black tracer) single plug that ain't there on the wanna-be Dodge alternator !
Sixlitre
My Superford site
Sixlitre is offline
post #83 of 480 (permalink) Old 03-15-2005, 11:30 PM
Stuck like a MoFo
85f150's Avatar
Bronco Info: Srry no Bronk only a F150
Naaa
If you're already 3G, then you're GGGolden
Sixlitre
Thats for wimps...go for the platinum with a large case Delco and be pimpified like me
Truck Porn mooseracing.org
1985 F150 300 cubic inches of raw tq
79 XS 1100 SF
79 Firebird & T/A
64/65 Studebakers
85f150 is offline
post #84 of 480 (permalink) Old 03-16-2005, 04:06 PM
B-man's Avatar
I don't know if I have that 3g? But, I doubt it..It will have to wait, gotta get the damn thing running decent before anything else.
B-man is offline
post #85 of 480 (permalink) Old 03-17-2005, 08:42 PM
Bronco Info: 1985 Dodge
Some things never change... Ryan ya get that bronco of yours into the sub16 sec 1/4 mile times yet? ;-)
And BTW anytime you want to argue the 3G durability issue I have the perfect test for it....and it's not on some alt tester either..... but it will see if it has any stamina. The Large case Ford is hard to beat providing you get a quality rebuilt/new one... so is the large case GM...both have huge bearings, huge components period and run much cooler. They also will easily accept modifications to run SERIOUS wire so as to not have a situation where the alt can feed more than the wiring can stand..... and BTW I missed the explanation for why Ford didn't use the 3G on industrial/fleet/HD applications?
NoRM
Who has a 3G on my car (Same place Ford used them).... not on my truck.
Dodge is offline
post #86 of 480 (permalink) Old 03-17-2005, 10:45 PM
Try it now!!
kf4amu's Avatar
My cup runeth over!! I couldnt ask for a better post to entice a debate!!!
-Will
89 XLT 460
kf4amu is offline
post #87 of 480 (permalink) Old 03-17-2005, 11:01 PM
Practicing Infidel
Sixlitre's Avatar
-Will
89 XLT 460
No debate in my mind, 3G wins for;
1.) compatability to existing brand.
2.) ease and cost in junkyards.
3.) cure all for electrical problems on 80-86s
4.) flawless operation for four years under my hood
5.) more than enough power for all my stock and aftermarket needs.
Sixlitre
My Superford site
Sixlitre is offline
post #88 of 480 (permalink) Old 03-18-2005, 02:33 AM
Try it now!!
kf4amu's Avatar
Sixlitre
Not sure what this means but I'm sure its true. It sounds good anyway.
Sixlitre
Definitely I agree. 15 bucks for another alternator. Can't go wrong.
3.) cure all for electrical problems on 80-86sSixlitre
Wouldnt know.
4.) flawless operation for four years under my hoodSixlitre
Thats cool, but its kinda sad when a good standard for an alternator is 4 years of life.
Sixlitre
10 amps - 50 watt 2 meter ham radio
20 amps - 4 55 watt lights on roof rack
20 amps - headlights
20 amps - fire dept strobe lights
10 amps - blower motor for AC/heat
20 amps - ignition/CB/radar detector/dome light/other small draw things (guessing here)
That leaves 30 amps available. I can't think of much else I would need beside a big stereo or a winch. And if I was winching I could live with turning off the AC and strobe lights
So far I cant think of what I could have to overdraw my 3G.
But then again, I've never put it to the test for an extended period of time, or in dirty conditions, which seems to be everyone's complaints.
-Will
89 XLT 460
kf4amu is offline
post #89 of 480 (permalink) Old 03-18-2005, 02:20 PM
press ALT+F4
78bronco460's Avatar
I see the same problem with these little japper alt's as I had with Mopar alternators... Open frame design. It's great for cooling and running to the mall, but mud and dust kills em. Fast. I'm running the stock A/C option FoMoCo alt in my 78 and it's been wheelin me 9 years w/o a hiccup. My Bronco has the original dual battery setup but I only run it with one red top, use the other battry space for a ammo can toolbox. I have a Lincoln large case for a backup that's just been sitting there all this time. I guess I just missed why this machine is needed. Aren't they the ones that caught fire?
78bronco460 is offline
post #90 of 480 (permalink) Old 03-18-2005, 03:10 PM
Stuck like a MoFo
85f150's Avatar
-Will
89 XLT 460
I overwork mine all the time, or overwork my belts. Plowing, with roof strobes going, 100 watt highbeams on, E-fans on high, And then picking up the plow with a motor that is basically a starter motor.
Mine usually stays at 14 except when i pick the plow up, the belts start screamin for dear life then. It drops to 11 volts but that is good compared to my stock 65 amp that would never go above 12 the whole time plowing
79 XS 1100 SF
79 Firebird & T/A
64/65 Studebakers
85f150 is offline
post #91 of 480 (permalink) Old 03-18-2005, 03:13 PM
Practicing Infidel
Sixlitre's Avatar
(Ford to Ford)Definitely I agree. 15 bucks for another alternator. Can't go wrong.
Yep
Wouldnt know.
Kiss the ground and be thankfulThats cool, but its kinda sad when a good standard for an alternator is 4 years of life.
...and counting. That's just how long it's been since the conversion
I've got a honkin' great stereo with a 1200 and 1400 watt amplifiers and 9 speakers. With everything running at night I can see into the next county with the headlights and that 's good enough for me.
All this and the volt meter stays pegged at 14.75 volts!
I's happy
-Will
89 XLT 460
Sixlitre
My Superford site
Sixlitre is offline
post #92 of 480 (permalink) Old 03-18-2005, 03:25 PM
OX1
OX1's Avatar
That was the connectors on the 2nd gen
OX1 is offline
post #93 of 480 (permalink) Old 03-18-2005, 07:00 PM
Try it now!!
kf4amu's Avatar
Add a 30 amp electric fan to my above calculations...and I've maxed my 3G.
And I never even went into all the radios I want to have in it. Mobile packet/APRS, HF. These things will draw much more.
And I never put a stereo in the mix.
I need dual alternators
-Will
89 XLT 460
kf4amu is offline
post #94 of 480 (permalink) Old 03-19-2005, 10:24 PM
So I might be an idiot, but what about the connectors off the back? Can I just go to a parts store and get the harness or use my stock. I found a 3g in the junkyard today for $45.00, but want to still research this swap. I can build the larger gauge wires for the main hook-up, but what about the "special" connectors.
TCHDNSD is offline
post #95 of 480 (permalink) Old 03-19-2005, 10:27 PM
Try it now!!
kf4amu's Avatar
Instead of getting that alternator, pay me to get one for you. 15 bucks from my junkyard.
You can use whatever gauge wires you want. Its just a stud on the back, I'm using 2 gauge wire.
-will
89 XLT 460
kf4amu is offline
post #96 of 480 (permalink) Old 03-19-2005, 10:59 PM
press ALT+F4
-Will
89 XLT 460
Is that really the case? If the loads are more than the alternator can put out then the battery will do the extra work, for a while at least. If you really are running that much load then wouldn't a second battery would be more helpful than a second alternator?
post #97 of 480 (permalink) Old 03-20-2005, 02:05 AM
Try it now!!
kf4amu's Avatar
I guess it would help smooth out the loads, probably a better option than dual alternators. But I was only half kidding anyway. Before I go through the expense of dual alternators I'd just add another battery or turn some stuff off :-)
-Will
89 XLT 460
kf4amu is offline
post #98 of 480 (permalink) Old 03-20-2005, 11:43 AM
-will
89 XLT 460
I'm still looking for a possible better deal. That was just one junkyard around here.
I'm refering to the "pigtail" harness. I can figure out the heavy gauge wiring but where the others are on the back I'm trying to find out if I need to change or upgrade those.
TCHDNSD is offline
post #99 of 480 (permalink) Old 03-20-2005, 11:50 AM
Try it now!!
kf4amu's Avatar
I dont think so. But do yourself a favor and order the harness from Ryan McCormick (Fireguy50).
Its a good well built harness, no one has been unhappy with it thats has bought it. I myself have to wait a couple weeks before I get it cuz I'm poor, but in the meantime....
It works fine.
kf4amu is offline
post #100 of 480 (permalink) Old 03-20-2005, 12:50 PM
Fireguy, I sent you a message.
TCHDNSD is offline
