GEARS GEARS GEARS, Please read before posting gear questions - Page 17 - Ford Bronco Forum
post #321 of 330 (permalink) Old 05-26-2014, 04:49 PM
Originally Posted by BigRed1993 View Post
Deeper? sorry what do you mean by that? and it is just an open diff.
Lower gears/numerically higher.
TS 90F150 is offline
post #322 of 330 (permalink) Old 05-27-2014, 03:29 PM
BigRed1993's Avatar
Bronco Info: 93 ford bronco, 302, e4od, 8.8 rear, dana 44 ttb front, 35x12.50's
oh! ok i see. thanks for all the help guys!
BigRed1993 is offline
post #323 of 330 (permalink) Old 07-15-2014, 04:55 PM
Moabicon's Avatar
Bronco Info: 94 FSB EB, 5.8L, 33" BFG M/Ts
Originally Posted by godless View Post
If you have to ask, my opinion is dont try it.
By the time you bye all the tools to do the job (press, backlash tool, etc) you could have just drove the axle to some guy and had it done for a case of beer and $100.00
Most of the guys I know here locally will do gears for that price with a smile on their face.
Really?? I need better friends. For a case of beer and $100?? I would pay this anytime. Seems to me that a good shop will cost around $100 per hour and charge you for what, 8 hours or so to do do both axles. 4 Wheel parts charges around $1600 for parts and labor.
Moabicon is offline
post #324 of 330 (permalink) Old 07-15-2014, 05:33 PM
Owned 21 Years
Don't expect him to answer.
You must have pulled that quote from about 9 years ago. godless hasn't been on here in about that time. But anyway, you're right a shop will charge around what you say for parts and labor.
post #325 of 330 (permalink) Old 07-16-2014, 09:37 AM
logain's Avatar
Bronco Info: Sold
Gear swap to 4.56 in my F150 was $400 labor. :)
logain is offline
post #326 of 330 (permalink) Old 08-19-2014, 02:49 PM
BigRed1993's Avatar
ok. Im back with a couple more questions.. I,ve never messed with diffs at all so I don't know a whole lot about them.. I have the 8.8 in the back of 93 bronco and a dana 44 up front(i think). Im looking at gears and Im wondering if i need reverse rotation gears or not? and does the spline count on the axle shafts matter for gears?
post #327 of 330 (permalink) Old 08-19-2014, 03:21 PM
Owned 21 Years
Yes, you need the reverse spiral front gear set with a high pinion 44.
post #328 of 330 (permalink) Old 08-23-2014, 09:23 PM
thebiglebowski's Avatar
Bronco Info: 1979 Bronco 351w/C6, 1970 F250 highboy 460/C6, 1971 crew cab f250 cummins, 1992 f150 302
I didn't read through all the posts here so this may have been covered but what gearing should I use:
460/C6
D60/14 bolt
40-42" tires
5.13s?
thebiglebowski is offline
post #329 of 330 (permalink) Old 08-23-2014, 10:16 PM
People keep buying my
Alex95's Avatar
Bronco Info: A 88 Bronco and a LBZ to pull it.
460/C6
D60/14 bolt
40-42" tires
5.13s?
With 29" tires on 3.55s to get you to stock on 42's itd take 5.141379310344828s lol. So yeah 5.13s unless you want more power then deeper.
A general rule in modding a vehicle is: Powerful, Reliable, Cheap; You can only pick two, not three.
88 Custom- Don't get to mess with it much anymore. Project racetruck took over
07 Chevy Silverado 2500HD - Project racetruck.
http://www.fullsizebronco.com/forum/signaturepics/sigpic52472_1.gif
Alex95 is offline
post #330 of 330 (permalink) Old 02-28-2016, 08:42 PM
Bronco Info: 1988 Bronco, 351W, Mostly Stock
I'm putting on 37" tires and going with 4.56 gears. According to the original post my forward roll will be 25.5" which is the same as stock. So my question is will I need to change the speedo cable gears for the speedo to be accurate after all the swaps are made.
Bama88Bronco is offline
