GEARS GEARS GEARS, Please read before posting gear questions - Page 2 - Ford Bronco Forum
post #21 of 330 (permalink) Old 12-22-2004, 08:19 PM
Blown
Guest
Posts: n/a
I like Randy's calculators cause you can input your gearing if you don't have one of the tranny's listed in the above link.
http://randysringandpinion.com/conte...lators/RPM.asp
post #22 of 330 (permalink) Old 12-22-2004, 08:56 PM
Retired
79F150's Avatar
Originally Posted by 79F150
Here is a gear calculator for you Tomb971 http://www.grimmjeeper.com/gears.html try this old to see what you want to run. Stock gears and 33 are not bad try 38's.
I use this one.
79F150 is offline
post #23 of 330 (permalink) Old 02-17-2005, 02:16 PM
Nemean's Avatar
Bronco Info: 1993 Bronco XLT 351 Auto, 2 inch lift, 33's, Banks transcommand, lots of miles and running strong
You could also add VIN codes for axles to this as well. eg. under "axle" on your door's VIN sticker "H9" is 3.55's with a limited slip, "C5" would be 4.10 with a limited slip. This could help when searching the local wreckers.
Nemean is offline
post #24 of 330 (permalink) Old 02-26-2005, 02:37 PM
No more Bronco
Switch's Avatar
Bronco Info: 1990 Ford Bronco
Originally Posted by Beerman
Also this write is assuming you have an E4OD, or similar auto tranni.
So how off would this figures be for those running a ZF 5 speed?
James
James (Click on the pic to visit my Supermotors Page)
1990 Bronco with a new 5.8L, a ZF 5 Speed, Superwinch manual hubs, 3G Alternator
upgrade, roof rack, dual batteries, brush/grill guard with 4 150w Eagle Eye lights, and
a Saginaw steering pump. Stock suspension with 29" tires.
SuperMotors Watermarking sucks!!!
Switch is offline
post #25 of 330 (permalink) Old 02-27-2005, 02:43 PM
Are those REAL?!?!
Tomh971's Avatar
Bronco Info: 1993, 5.8, E4OD, BW 1356 (manual), 6" off-road lights, Kenwood stereo, more to come...
I use this one.
This one is great... except they don't list my T-case...
"You can have my guns when you pry them from my cold, dead hands" - Charlton Heston
Support Our Troops
Tomh971 is offline
post #26 of 330 (permalink) Old 02-27-2005, 04:35 PM Thread Starter
godless's Avatar
Bronco Info: Sold Bronco, but still live in the off topic threads
Sorry, for a zf 5 speed you will hve to figure out what your rpm band range is now, then do the math listed for each gear. once you have that then you will know your overall rpm range for 5th gear
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring."
Carl Sagan PH.D.
godless is offline
post #27 of 330 (permalink) Old 08-12-2005, 09:57 PM
Late Model Man's Avatar
Bronco Info: '95 351, ZF5, Dana 60s
My inside door sticker says the stock tire size is 265/75R15. Roughly 30.6 inches tall. So 4.10s with 35s will be about spot on.
SuperFord 95 8-lug Bronco with some stuff...
Late Model Man is offline
post #28 of 330 (permalink) Old 08-16-2005, 12:21 PM
Who needs oil anyways....
Aikidoka's Avatar
Bronco Info: 86 Bronco 351W
Circumference of tire divided by the gear ratio you want.
33" tire, 3.55 gears = 103.7" circ, forward 29.2", about 15% more than stock
Now my 8th grade math class taught me that circumference was 2*pi*r. So...
EDIT: Removed my strange math.
EDIT: Ha ha. Except that tires sizes are diameters and I was forgettig the 1/2 first that made it SEEM like the 2 was missing from the equation.
Size does matter. That is why they make 40oz.
I am not a mechanic. I reserve the right for anything I say to be wrong.
1993 EB Bronco
351W w/ 345K!
1990 Bronco
351W clean & rebuild in progress
1986 Bronco XLT
351W HO EFI Conv
Partial F-350 brake conv (still need to do calipers)
Crower 15935 baja beast cam
1985 Parts Bronco.
Also 351W and stripped down
My gallery
Aikidoka is offline
post #29 of 330 (permalink) Old 10-06-2005, 07:25 PM
Bronco Info: 88 Bronco 302 w/ K&N Filtercharger, 33x12.5 BFG MT's, smittybuilt rollbar, 8000lb winch
but, once you get larger tires moving does it require any more power to keep them moving than small tires? or is it just about the same difference?
88_Bronco_4x4 is offline
post #30 of 330 (permalink) Old 10-06-2005, 09:01 PM
Chuck's Avatar
A smidge. Bigger tires have a little more rolling resistance. It's small enough that you can pretty much neglect it, though.
Chuck is offline
post #31 of 330 (permalink) Old 10-06-2005, 09:52 PM Thread Starter
godless's Avatar
Re-gearing makes it easier to turn the big meats, however stopping the big meats is another issue
Carl Sagan PH.D.
godless is offline
post #32 of 330 (permalink) Old 10-10-2005, 09:30 PM
hmmm, I've found that stock brakes work pretty decently with 33's. I don't ever really put myself in situations that require really quick stopping though.
post #33 of 330 (permalink) Old 10-13-2005, 10:36 AM
Bronco Info: 1991 FS 5.0L EFI
Hi all
I am Lifting my 1991 FSB and and installing 35 inch tires.
Not using it for off road; the only time I will engage the front is in stuck situations.
So for those of you who have successfuly done this the gear setup
what is the ideal gear ratios for the front axle and rear axle.
Currently the front is 3.54 and don't know what the rear is
thanks
llanaro is offline
post #34 of 330 (permalink) Old 10-13-2005, 05:46 PM
Stock, the front will be the same as the rear. For a daily driver, I'd recommend 4.10s, because its darn near the same overall as 31" tires and 3.55s, which is what mine came with. 4.10s and 35s can get me 16mpg highway if I keep it at 65 on a good day.
post #35 of 330 (permalink) Old 10-13-2005, 05:47 PM
o[|||]o
JahWarrior's Avatar
Bronco Info: 86 Bronco XLT - 460, SAS
4.10's / 4.11's should be perfect for you.
I believe that banking institutions are more dangerous than standing armies. If the American people ever allow private banks to control the issues of currency...the banks and the corporations that grow up around them will deprive the people of their property until their children wake up homeless on the continent their fathers conquered.
- Thomas Jefferson -
JahWarrior is offline
post #36 of 330 (permalink) Old 10-13-2005, 09:21 PM
HI
jeff's Bronco Graveyard has 4.09 front and 4.11 rear
ring and pinnion will that do
do you need a bigger housing or just change the ring and pinnion
lou
llanaro is offline
post #37 of 330 (permalink) Old 10-14-2005, 11:12 AM
You are gonna have to get a new carrier for the front. (not a housing) About $50 for open, more for a ltd slip/ locker. The rear is fine, just put the gears in.
post #38 of 330 (permalink) Old 10-16-2005, 07:14 PM
thanks
I will need to do this job
there is great write up for the rear 8.8
any one know for the front if there is a rebuild write up
I searched but could not lacate any
thanks
Lou
llanaro is offline
post #39 of 330 (permalink) Old 12-28-2005, 05:13 PM
dach's Avatar
Bronco Info: 1988 XLT 351W
My stock FSB 351w is 31" with 3.08
I want to go 35" with 3.54
They are the same ratio but is it enough for the 35" or is it better going to 3.73??
Why in USA a lot of people go 4.11 / 4.56 ??
dach is offline
post #40 of 330 (permalink) Old 12-28-2005, 05:23 PM
GHOSTRIDER's Avatar
Bronco Info: 90 XLT/351W, 6" LFT SAS, 9" 35" TIRES , 4.56, LOCKED, REALLY COOL SNORKEL, OTHER COSTLY CHIT
Stock gears are 3.55's...the gear of choice for 35's is 4.45 and for 33's is 4.11...me, I got 25's and stock gears...
Riding on in the mist of morning, no one dares stand in my way...possessed by some distant calling, riding on through night and day.
PETE HALEY
GHOSTRIDER is offline
