Ultimate Throttle Position Sensor (TPS) Thread - Page 10 - Ford Bronco Forum
 2Likes
post #181 of 185 (permalink) Old 10-25-2015, 07:53 AM
Do you know which color the ref ground is?
Shayne311 is offline
post #182 of 185 (permalink) Old 10-25-2015, 07:53 AM
Ref voltage**
post #183 of 185 (permalink) Old 10-25-2015, 07:42 PM
RocketcarX's Avatar
Bronco Info: 1982 4x4 EFI 5.0 All Built In-House
It's the green wire at the TPS, trace it back into the harness and that is the color it is at the ECM
I know this is mustang specific info (my 5.0 and ECM are from a 90 GT) but it will help you diagnose.
Mustang FAQ - Wiring & Engine Info
Custom built EFI 5.0, MSD, SpeedShop C6 w/E40D gear set, ATI converter, Trac-loc'd 44HD, Skyjacker 182s springs, RS9000 front shocks, Procomp adjustable rear shocks, SpeedShop triangulated rear shock system, TRE flip, SpeedShop fabricated bumpers, Long tube headers, SpeedShop 2.5 Y-merge to 3in single exhaust, 33x12.50-15
RocketcarX is offline
post #184 of 185 (permalink) Old 10-26-2015, 04:18 PM
Seattle FSB's Avatar
See this link for detailed TPS wiring, testing and replacement. Read to the end of the thread for additional information.
Throttle Position Sensor (TPS) Testing, Replacement and Adjustment
Seattle FSB is offline
post #185 of 185 (permalink) Old 05-29-2016, 04:05 AM
akzep69's Avatar
Bronco Info: 89-351W, 3" Lift - 33" Pro-Comps
Angry TPS PIGTAIL & which one does my 89 5.8L take -fixed or adjustable?
The title says it all ....
FYI when i got the TB removed... only thing attached to TB were the mounting screws and some melted plastic...
I literally have no idea which one to buy new or which way the pigtail faces?
Please advise
Thanks
akzep69 is offline
