What's a PSOM & how do I "P" it??? - Page 3 - Ford Bronco Forum
post #41 of 299 (permalink) Old 03-21-2007, 03:23 AM
djdan's Avatar
Bronco Info: 1992 EB 5.8 Durabak Black Chuck Norris "Thumbs Up" Edition
Originally Posted by Ogeechee 4x4 View Post
Interesting! Sooo...what's that say in english?
+1
djdan is offline
post #42 of 299 (permalink) Old 03-21-2007, 07:50 PM
Satyr of the Midwest
SigEpBlue's Avatar
Just for giggles today, I decided to check out my conversion factor. My rig originally came factory with the 235/75-15's, but someone put the better-looking 31x10.5's and aluminum rims on it in a past life. No big surprise to find out that the conversion factor was never changed to reflect the change in tire size; it was 9.72, so I changed it to 9.18....after I accidentally touched the cigarette lighter's hot contact. DOH! Replaced the fuse, and all is well. For some reason, it just feels better driving now, especially at highway speed.
SigEpBlue
SigEpBlue is offline
post #43 of 299 (permalink) Old 03-21-2007, 10:13 PM Thread Starter
Steve83's Avatar
The shift points are now correct for the engine's power band & the vehicle's weight.
post #44 of 299 (permalink) Old 03-22-2007, 01:03 AM
djdan's Avatar
Wow - something I never knew... I'll have to try it sometime.
Ok Steve...pretend I'm dumb (I am)....what does this MEAN?!
djdan is offline
post #45 of 299 (permalink) Old 03-22-2007, 01:48 AM Thread Starter
Steve83's Avatar
Did you read the caption??? It's pretty straightforward.
post #46 of 299 (permalink) Old 03-22-2007, 02:10 AM
djdan's Avatar
In my defense I'm sleep deprivated, on 3 Jack and Cokes, and working feverishly on organizing THOUSANDS UPON THOUSANDS of music files that I've put off doing for YEARS. I'm trying to be a better DJDan
I also havent driven my Bronc in 3 days so I'm having withdrawal. The pass. side exhaust man. took a HALF DAY to remove! It was angry.
Back on Topic! Sorry!
djdan is offline
post #47 of 299 (permalink) Old 03-22-2007, 09:04 AM
green ones make me horny
imlikeojnow's Avatar
Did it today. felt weird at first like i was going too slow but then i guess i have been just going too fast the whole time
imlikeojnow is offline
post #48 of 299 (permalink) Old 03-22-2007, 05:14 PM
Mentally in Cancun.
stan the man's Avatar
so all this does is recalibrates the speedo? or does it change the shift points too?
i wonder if this will help get better MPG.
stan the man is offline
post #49 of 299 (permalink) Old 03-22-2007, 05:18 PM
Depending on the year. with mine it fixed the shift points because they are computer controlled. My trucks shifts at lower RPMs now than it did before so i can only see it getting better gas mileage.
post #50 of 299 (permalink) Old 03-22-2007, 05:36 PM Thread Starter
Steve83's Avatar
It doesn't actually CHANGE the shift points; it just makes them happen at the actual correct speeds, where they were always designed to happen.
And it won't actually change the mileage, either. But it will show the CORRECT mileage, and your MPG calculated off your (now corrected) odometer will be higher than it used to be when the odo was wrong. But again: the actual fuel economy isn't changing - you were just using bad numbers between going to bigger tires & correcting the PSOM.
If you went to SMALLER tires than the PSOM was programmed for, you apparent MPG would have gone up with those wrong tires, and by reprogramming, you'd bring it back DOWN to true.
For instance:
Stock tires are ~29" tall, and we'll say you were getting ~15 MPG on them. If you swap to 33s (~31.5" tall), your actual mileage wouldn't change much, but it would APPEAR to drop ~9% to around 13.5 MPG only because your odometer is now ~9% wrong. By calibrating the PSOM, it would appear to go back up to ~15 MPG, but it was really ~15 MPG the whole time.
On trucks with a PSOM, gearing has no effect on odometer accuracy. On all vehicles, gearing has very little effect on MPG.
post #51 of 299 (permalink) Old 03-22-2007, 09:46 PM
Mentally in Cancun.
so uh silly question... how would i go about grounding this PSOM wire?
post #52 of 299 (permalink) Old 03-23-2007, 12:45 AM Thread Starter
Steve83's Avatar
Put down the tools; step AWAY from the Bronco...
That's pretty scary. If you don't know how to ground something, you really shouldn't mess with anything electrical.
post #53 of 299 (permalink) Old 03-23-2007, 01:29 AM
Mentally in Cancun.
haha... no i know how to ground wires. my lt blue and yellow wire runs into a brown plastic connector and it says PSOM on it.
post #54 of 299 (permalink) Old 03-23-2007, 04:24 AM
djdan's Avatar
Pull the pass. kick. Take a (approx.) 2 ft. peice of wire and strip both ends. Take wire and stick one end in BACK or brown plastic connector. Take other end and wrap around metal bracket located next to the inertia switch.
When finished remove wire and put everything back together.
djdan is offline
post #55 of 299 (permalink) Old 03-23-2007, 06:14 AM
Yup, I'm fullsize....
unixdude's Avatar
Bronco Info: 1995 XLT, 351, ARB's, 4" BDS lift, Truxus MT 35's w/4.56 & MT Classic II's, '00 CVPI
Or take a shorter piece of wire (strip both ends) and ground it to the cig lighter. I think Steve83 mentioned this trick somewhere in this thread. Worked perfect for me. If I can figure it out, anyone can.
-unixdude
Your mind is like a parachute, it works much better when it is open.
Prior Proper Planning Prevents Piss Poor Performance (the 7 p's)
Code:
 _     _ __   _ _____ _     _ ______  _     _ ______  _______
 |     | | \  |   |    \___/  |     \ |     | |     \ |______
 |_____| |  \_| __|__ _/   \_ |_____/ |_____| |_____/ |______
unixdude is offline
post #56 of 299 (permalink) Old 03-23-2007, 08:10 AM
Are you serious you do not know how to ground that wire? I got a wire just for grounding. it has aligator clips on it. One side to the connector other one to door hinge and voila
post #57 of 299 (permalink) Old 03-23-2007, 02:02 PM
djdan's Avatar
My pass. kick was already off so I went with it there.
djdan is offline
post #58 of 299 (permalink) Old 03-25-2007, 12:20 PM
SigEpBlue's Avatar
What are you guys talking about? Just lick both thumbs, grab the wire with one hand, hang on to something metal under the dash with the other, and you're set.
j/k if you thought that was going to work, I've got a bridge to sell you.
SigEpBlue
post #59 of 299 (permalink) Old 03-29-2007, 09:38 PM
ToughXLT's Avatar
Bronco Info: 1995xlt 5.8
Crap in a hat! This was the SIMPELEST mod I have done so far. Literally took 3 minutes. The instructions are exact (at least for me doing my 1995).. Now I have the correct specs for my 35's. I want to go try it out now.. Anyone who has made the change to 35's this is the best thing to do after.
People seem to like me because I am polite and I am rarely late. I like to eat ice cream and I really enjoy a nice pair of slacks. Years later, a doctor will tell me that I have an I.Q. of 48 and am what some people call mentally retarded.
ToughXLT is offline
post #60 of 299 (permalink) Old 06-17-2007, 07:20 PM
william_ace's Avatar
Bronco Info: 1996 f150 300 ci sas/ZF/10.25/8 lug 44 front 37" tire thingys
thanks for the write up steve, just found it. i did it and used the constant of 810 seems like im going alot slower now. might have to adjust it one more time, but i need someone to drive next to me so i can see how fast im actually going. but thats probably being used to seeing the speedo at 65 and passing people.
william_ace is offline
