What's a PSOM & how do I "P" it??? - Page 4 - Ford Bronco Forum
post #61 of 300 (permalink) Old 06-18-2007, 09:12 AM
steveravenscroft's Avatar
Bronco Info: 94 Bronco Dana 44 sas 35x12.50, 456 Gears, Trac Lock Rear,Lock-Right front
Ok I went to the Tire Rack and caint find the Constant for my tires,or any for that matter.33x12.50x15 BF all Terrain.
steveravenscroft is offline
post #62 of 300 (permalink) Old 06-18-2007, 09:36 AM
aka: kemicalburns
TravisITGuy's Avatar
the speedo on my 94 is not working. I purchased a VSS just have no idea where it goes. the sensor on the rear diff is strictly for abs. my chiltons gives no picture or general area where to even look.
HELP
TravisITGuy is online now
post #63 of 300 (permalink) Old 06-18-2007, 11:58 AM
william_ace's Avatar
Bronco Info: 1996 f150 300 ci sas/ZF/10.25/8 lug 44 front 37" tire thingys
the vss in your 94 goes in the rear end, its not just for abs.
william_ace is offline
post #64 of 300 (permalink) Old 06-18-2007, 11:59 AM
Found it 32.7 dia. 636 revs per mile=8.59 but this is for the above tires I have.Now to get in the truck and change it.:Pickle:
P.S. So even if the batt. is disconected it will hold the new setting????
post #65 of 300 (permalink) Old 06-18-2007, 12:00 PM
http://www.tirerack.com/tires/Spec.j...D325R5ATAKORWL
edit, well ya beat me to it, haha
post #66 of 300 (permalink) Old 06-18-2007, 12:39 PM
aka: kemicalburns
this is a vss http://www.fordfuelinjection.com/index.php?p=33
try and fit that into the rear diff.
post #67 of 300 (permalink) Old 06-18-2007, 01:44 PM
Cool
Ok,I done it,but till I have some one run along side of me I'm not sure if it really worked. (E 08 6 was in the begining.Now it's E 08 5 so it must have took the new setting.I wish the test mode would just show 8.59
I hate to use one of my 5 more times to check it.
post #68 of 300 (permalink) Old 06-18-2007, 02:59 PM
green ones make me horny
imlikeojnow's Avatar
Should be a spot on the very top of your rear chunk for it. if not look in the back of the tcase
imlikeojnow is offline
post #69 of 300 (permalink) Old 06-18-2007, 03:51 PM
it should be on top of the diff, but i guess it could be iin the back of the tcase
post #70 of 300 (permalink) Old 06-18-2007, 07:30 PM
Harmful if swallowed
Agily00's Avatar
Quick question:
I did this way back when I put 33's on, and now I went back to 32's
would the best option be to use the advertised diameter(I have sport kings~ the same as BFG's) of 31.7 or the actual measured diameter on the vehicle of 30.25?
When I did the 33's, I used the actual measured height on vehicle.
Agily00 is offline
post #71 of 300 (permalink) Old 06-19-2007, 11:42 AM
Agily00's Avatar
Bueller?
Agily00 is offline
post #72 of 300 (permalink) Old 06-19-2007, 04:11 PM
use the measured height of the tire on the truck
post #73 of 300 (permalink) Old 06-19-2007, 04:55 PM
Agily00's Avatar
Thats what I was expecting.
When I did the 33's I proofed it with the GPS and was dead on at 65
Agily00 is offline
post #74 of 300 (permalink) Old 06-19-2007, 10:47 PM
Heavy and slow fun
Aurorabusa's Avatar
Bronco Info: 94 XLT 351 Auto 37 IROK's SAS ext. arms D44 9in Detroit rear ARB front 5.13 16.5TI Warn OBA York
You can check your conversion number--just dont ground out the single wire,Press and hold the reset while turning on the key,press it i think 2 more times and it will show it without worrying about reprograming or using a time.
Have fun
If you don't like it, blow it out your E-ass.
http://www.supermotors.net/17065
Aurorabusa is offline
post #75 of 300 (permalink) Old 06-25-2007, 01:15 AM Thread Starter
Steve83's Avatar
Back where you bought it.
So you're saying that Ford & all the people who've posted success with these instructions are wrong? Or did you just not read the first post in this thread?
this is a vss http://www.fordfuelinjection.com/index.php?p=33 try and fit that into the rear diff.
So you DIDN'T read the first post... And apparently, neither did imlikeojnow or william_ace.
Originally Posted by Agily00 View Post
Quick question:
...would the best option be...
...to follow the instructions in the first post. Use the RevsPerMile from TireRack.com .
...I'm not sure if it really worked. ... I hate to use one of my 5 more times to check it.
Originally Posted by Aurorabusa View Post
You can check your conversion number--just dont ground out the single wire...
FINALLY! Someone who DID read the first post! All you lazy old-timers need to follow this newbie's GOOD EXAMPLE!
post #76 of 300 (permalink) Old 06-25-2007, 02:57 AM
How did i get brough into this
post #77 of 300 (permalink) Old 06-25-2007, 03:16 AM Thread Starter
Steve83's Avatar
Like this:
the speedo on my 94...
Should be a spot ... in the back of the tcase
post #78 of 300 (permalink) Old 06-25-2007, 09:58 AM
aka: kemicalburns
i finally got my thick head to understand what you all are saying.
I hate it when i do that.
post #79 of 300 (permalink) Old 06-25-2007, 11:52 AM
and me, all i said was in the rear end? it doesnt matter
post #80 of 300 (permalink) Old 06-25-2007, 02:16 PM
Like this:
That was in reference to where his VSS goes. Not his speedo
