What's a PSOM & how do I "P" it??? - Page 5 - Ford Bronco Forum
post #81 of 300 (permalink) Old 06-25-2007, 02:48 PM
All I got for X-Mas was a
Joes93Bronco's Avatar
I think he is sayin that cause he gots a '94 it's in the rear. Not the t-case. And that you should know better.
Which you do.
But none of this BELONGS in a thread about the PSOM.
Baby Girl
My SuperCrap Site
-Plato
Joes93Bronco is offline
post #82 of 300 (permalink) Old 06-25-2007, 03:15 PM
Owned 21 Years
I'm not going to go back and read all 5 pages of this, but just as an FYI, while tireracks info. on revs per mile is helpful, you can also do this yourself with a little math. I've never used tireracks specs, always worked my own. Then went out and used reliable milemarkers on the highway. It's certainly not GPS accurate but who cares, it's pretty darn close, it was off by about 10-15 ft each mile with tire wear that will get worse or better, I don't remember which now, but I likely erred on the side of it getting closer as the tire wore. Assuming I was off 15 ft. that is off by about .0028% so good enough.
post #83 of 300 (permalink) Old 07-22-2007, 09:43 AM
Bronco Randy's Avatar
Bronco Info: 1993 XLT 351W/E4OD, 35" SuperSwampers, 4" Skyjacker Lift, Rancho Traction Bars, No fender rust :)
This was probably one of the easiest things I've ever done. Took about 30 seconds once I found a proper ground. And to think, I almost took my rig to a speedo shop for recalibration. Gotta love FSB!
Bronco Randy is offline
post #84 of 300 (permalink) Old 08-03-2007, 12:16 AM
lakemarykid's Avatar
Bronco Info: 1994 F150 6" Lift 35's
I cant find the revs per mile for my tires. 315/75R16 Dick Cepek FC II. So what would i do?
-Curtis-
lakemarykid is offline
post #85 of 300 (permalink) Old 08-03-2007, 12:24 AM Thread Starter
Steve83's Avatar
Did you look on the DC website? If it's not published anywhere, read the instructions in my first post about calculating it, or look up a few other tires the same size & use the average.
You can put a mark on a tire & drive it a short distance, and then calculate it based on the number of revs & the distance you go, which will probably be the most accurate (if you figger it right).
post #86 of 300 (permalink) Old 08-06-2007, 07:24 PM
topfisherman's Avatar
Bronco Info: 1992, 5.0, M5OD, warn hubs, Catco y-pipe
Does anyone have a picture of the wire that you need to ground out? I looked through Steve's diagrams, but I can't find the light blue/yellow wire. All I have is two different black/orange wires that are not connected to anything under the glove box.
1992 Custom, Rebuilt 5.0L, M5OD swap, BW1356.
Warn hubs, K&N filter, Catco Y-pipe, Ford Racing Headers, 3G Alt, Saginaw PS Pump, E-Fan.
Pioneer head unit and 220W 3-way speakers.
My Supermotors.
topfisherman is offline
post #87 of 300 (permalink) Old 08-06-2007, 07:37 PM Thread Starter
Steve83's Avatar
Go to p.2 of this thread & read down from post #29. What revision is your PSOM? You may not have that wire.
post #88 of 300 (permalink) Old 08-07-2007, 11:38 AM
The revision I have E03, does that have the wire? If it doesn't how else do I change the cal number?
My Supermotors.
post #89 of 300 (permalink) Old 08-07-2007, 12:16 PM Thread Starter
Steve83's Avatar
Early models use a Bk/Or wire instead of LB/Y, but it's still a 1-wire connector on top of the harness that runs along the bottom of the dash behind the L edge of the glove box. The wire should be pretty small since it doesn't carry any power. It's just a logical input.
post #90 of 300 (permalink) Old 08-07-2007, 12:54 PM
GearHead71's Avatar
Bronco Info: 95 xlt 5.8 cali mass air e4od 33x12.5's
My speedo is off reads about 75 when other cars I've checked it against read about 70, so I checked this yesterday. It has the right calibration for the 31's I have on the truck and it hadn't been messed with before. Is it possible that I need a new one?
As long as it does what it's built to do, it must be cool.
GearHead71 is offline
post #91 of 300 (permalink) Old 08-07-2007, 01:30 PM
Ok, I just got it to work, it was the Blk/Or wire. Just like djdan said way back on page 2 you really had to push the button a lot to get it where I needed it with the E03 version. Now my speedo will be accurate with the new 31's I put on.
My Supermotors.
post #92 of 300 (permalink) Old 08-07-2007, 10:25 PM Thread Starter
Steve83's Avatar
Originally Posted by GearHead71 View Post
My speedo is off... It has the right calibration for the 31's I have on the truck and it hadn't been messed with before. Is it possible that I need a new one?
More likely, your tires are worn down or underinflated. The spec tolerance is ~3 MPH, so that combined with a little tire wear suggests your PSOM is fine.
post #93 of 300 (permalink) Old 08-17-2007, 11:46 AM
aka: kemicalburns
TravisITGuy's Avatar
my speedo doesnt work but the mileage shows 56k and doesnt change. would that dictate a bad psom or perhaps something else. i pulled the cluster last night and will be looking at a local yard for a replacement and will a 94 f150 cluster work? if i cant locate then i will get intouch with you steve.
TravisITGuy is online now
post #94 of 300 (permalink) Old 08-17-2007, 04:47 PM Thread Starter
Steve83's Avatar
Did you do the self-test described in post #1 of this thread? If it passes, then it's not getting the ABS sensor signal. Trace the wires to the rear diff.
post #95 of 300 (permalink) Old 08-17-2007, 05:49 PM
aka: kemicalburns
i am going to perform the self test tonight. so if i understand, when i run this test if the speedo doesnt sweep then psom is bad. if the speedo sweeps then i have other issues.
post #96 of 300 (permalink) Old 09-30-2007, 04:06 PM
Bronco Info: 1992 Eddie Bauer 351W want a lift!!
Originally Posted by djdan View Post
Wouldnt I be the lucky one? At any rate I'm not going to find out the hard way. The next and last adjustment I will make is when I regear and add 35's.
Thanks again for your help on this!
EDIT- I thought Steve (and maybe others) might find this interesting as well. My numbers did not count DOWN, but UP when I pressed the select button during programming. I had to push the button a BUNCH to get it to where it needed to be.
i plan on doing this soon and is this a 92 only type deal or does it vary for all years? this sounds super simple,but just wanting to make sure that im reading this correct. mine was manufactured 6/92 so idk if thats early in year or late?
http://memimage.cardomain.net/member...920_1_full.jpg
4 inch Rancho lift kit 33" BFG'S K&N Sixlitre upgrade KC Lights Pioneer deck Infinity Subwoofer!!!
biggies92bronco is offline
post #97 of 300 (permalink) Old 09-30-2007, 08:03 PM
aka: kemicalburns
i will be running 4.88 gears and 35" bfg mt's which are 34.8 tall and makes 598 revs/mile. what constant should i change my psom to?? thanks
post #98 of 300 (permalink) Old 10-01-2007, 02:38 AM Thread Starter
Steve83's Avatar
Originally Posted by biggies92bronco View Post
...is this a 92 only type deal or does it vary for all years?
Did you read the first post in this thread? Or djdan's post just before the one you quoted?
That's late in the model year, but it doesn't matter. It's the revision number.
post #99 of 300 (permalink) Old 10-09-2007, 09:46 AM
aka: kemicalburns
well with the 4.88 gears and my 35's my speedo is an easy 10mph off. the speedo shows me going slower then i actually am. I know how to change the constant but im not sure what constant to change it to.
anyone help??
post #100 of 300 (permalink) Old 10-09-2007, 11:00 AM Thread Starter
Steve83's Avatar
Read the FIRST post in this thread. Constant calculation is thoroughly covered.
