Ford Bronco Forum - View Single Post - Rear Axle Guide
Thread: Rear Axle Guide
post #10 of (permalink) Old 06-21-2004, 08:32 AM
SMOOTH
Living in Obscurity
SMOOTH's Avatar
Bronco Info: 88 Eddie bauer 302 (Gt-40 heads, Ford Racing Short Headers, Comp Cam, Bootyfabbed FIPK) 6 inch Super
Originally Posted by cant afford it
But what is "VSS"?
I am looking to possibly swap out my rear 8.8 for a one ton & was checking out your list.
Very helpfull by the way.
I think I probably need that "VSS" I have a 1990 bronco.
So what one ton rear would be the easiest and best swap for me?
Thanks
This was explained in one of your other threads. VSS helps is on this board.
2 minute search found this which tells you that 92 and up Broncos have the VSS on the rear dif, hence needing a rear axles with the sensor, your 90 is not in jeopardy.
Also this gives a thorough explanation of what a VSS is and does.
88 bronco T-Top, 302. 6 inch suspension lift, 35's.
92 Centurion 7.3idi, Banks non-wastegated turbo, 35's.
82 E350 Cabriolet "Vanchero" 460/C6/4.11posi.
"Never underestimate the predictability of stupidity."
- Bullet-tooth Tony and his friend, Desert Eagle .50
SMOOTH is offline
