Ford Bronco Forum - View Single Post - Rear Axle Guide
Thread: Rear Axle Guide
post #14 of (permalink) Old 06-22-2004, 05:55 PM
Andy351
negative creep
Andy351's Avatar
Originally Posted by SMOOTH
tells you that 92 and up Broncos have the VSS on the rear dif, hence needing a rear axles with the sensor, your 90 is not in jeopardy.
the VSS for the pre '92 is in the t-case yes, but the '91 and earlier still has a tone ring in back if it had RABS. its the same tone ring and the same connector as the VSS that reads for the various computers.
Andy351 is offline
