January 2016 F.O.T.M., VOTE HERE!!! - Page 3 - Ford Bronco Forum
View Poll Results: Who will be your January 2016 F.O.T.M.?
raleigh 28 32.94%
379sinvb 12 14.12%
ntahmisyan 27 31.76%
91FordGuy 13 15.29%
Sjeuck53 5 5.88%
Voters: 85. You may not vote on this poll
 64Likes
post #41 of 209 (permalink) Old 01-05-2016, 01:41 AM
ntahmisyan's Avatar
Bronco Info: 96 Bronco SAS 5.13s locked front and rear 40" iroks
okay lets power house this build!
here is the internals of the transmission, I was barely able to reuse the casing but got her done and in the truck
I pulled off the bumpers and started cutting the rear quarters, I also wire wheeled and undercoated the entire truck. Back then I was still trying to find a sense of direction and was mostly fooling around.
I started mocking up light bar and winch mounts neither of these I ended up running with but heres a picture anyway
Purchased a visor for $10 and painted her up
ntahmisyan is offline
post #42 of 209 (permalink) Old 01-05-2016, 01:52 AM
ntahmisyan's Avatar
A friend of mine needed my stock tires so then some how I ended up stock height on 36s, looked badass but wasnt practical. Im pretty sure I only drove the truck looking like this twice.
so thats how I ended up purchasing my 6" rough country lift(I know, I know dont worry eventually I come to my senses)
The visor found itself on the truck at some point and we started the lift, it ended up being split into two days when I realized I needed new shackles and hangers
Half way lifted!
couldnt tell you why, but I guess doing most of my work past midnight resulted in my loosing my rear axle shims, which I didnt end up replacing till WAY later.
Anyways on with the rest of my first lift:
we call this photo "Three morons at 3am"
My 6" roughcountry lift on stock axles was done:
post #43 of 209 (permalink) Old 01-05-2016, 01:59 AM
ntahmisyan's Avatar
I pulled the top off for the first time in this trucks life
pulled the plastics out and started painting this "rollbar" I ended up not running this bar because I wanted something more serious, but the pictures are still cool
and the following few days I rebuilt my ifs
I had to make my own hub nut tool for the 95-96
everything was smoked
and back on her feet again. lifted, rebuilt trans, rebuilt ifs and I thought ready to rumble....
post #44 of 209 (permalink) Old 01-05-2016, 07:29 AM Thread Starter
Beach bumming it ........
Saltlife's Avatar
Great show so far!! Keep it up!
Saltlife is offline
post #45 of 209 (permalink) Old 01-05-2016, 09:35 AM
Resurection Ranch
379sinvb's Avatar
The wheels on Filly when I purchased it were a bit modern imo.
So I started looking for a good tire I could wrap around my favorite wheels. Found some, 35/1250/15 mickey claws with 80% tread but a little dry rot (stay tuned). I picked them and the wagons they were on for $600.
Mounted and wheels scuffed for paint.
I used duplicolor textured with clear coat to finish it off. Then I took the fins back down to bare metal.
From there I moved to the interior. I wanted some carpet to keep out some heat and some noise.
At 6' tall I don't need the booster blocks under the seats.
Pulled the back seat and then the carpet in the rear. Still had the overlay in the rear.
Rollbar got cleaned and painted since it had to come out also.
New carpet going in.
I got a little carried away with the knife.
And a little help from the pit crew on re installing the roll bar.
Found this while pulling out the roll bar.
Loaded up to go to the Round Up.
Rick
My Projects- "Left for Dead"
Filly
379sinvb is offline
post #46 of 209 (permalink) Old 01-05-2016, 09:51 AM
91FordGuy's Avatar
Location: Grand Junction, Colorado/ Ventura, California
Bronco Info: 1981 4 inch lift w/35s. Built 300/T-19. Sliding Windows. Front&Rear Bumpers. Rock Sliders. Dual Batt
Just thought I'd show off these. I have been searching EVERYWHERE to find a donor truck for the gaskets and I've called just about glass shop within 100 miles of me. If anybody wants to help a FOTM contestant out... that would be great! haha
91FordGuy is offline
post #47 of 209 (permalink) Old 01-05-2016, 09:56 AM
Resurection Ranch
379sinvb's Avatar
CW swapped out a set of stockers for those a while back. Check with him.
CWbronco's build
There is also a right up for the 78/79 style but not certain that will work.
Rick
Filly
379sinvb is offline
post #48 of 209 (permalink) Old 01-05-2016, 10:02 AM
91FordGuy's Avatar
Awesome, thanks @379sinvb ! The 78/79 are different so looks like back to the junkyard search
post #49 of 209 (permalink) Old 01-05-2016, 03:40 PM
ntahmisyan's Avatar
I started wiring up some accessories, starting with dual electric fans out of an LT1 camaro
got some switches and an aux fuse box
I also welded up some real light bar mounts
and then the bought the donor truck for my solid axle swap... sterling 10.25 and a 44HD from another member
and here we go
post #50 of 209 (permalink) Old 01-05-2016, 05:16 PM
91FordGuy's Avatar
Alright here are my sliders. I am going to do the outer tube soon but for now they protect the rockers and I can jack up off of them.
This is a picture I sent to my Dad to rub it in since he just smashed his rocker panel on his ramcharger
post #51 of 209 (permalink) Old 01-05-2016, 05:17 PM
91FordGuy's Avatar
And here is just a cool picture I found of the rear end of the rig when I had to borrow a friends garage to take cover from a rainstorm when the top was off. (gives you a good idea of the ground clearance)
post #52 of 209 (permalink) Old 01-05-2016, 07:56 PM
SJeuck53's Avatar
Bronco Info: 79 bronco
my riding buddies
my first stuck its early stages had been posted earlier.
front was on a rock and rear was on a rock.
not the bronco but a sub par picture of our country.
me and my brother
more to come with builds and mods but get through some of the first year first.
vote FOTM
http://www.fullsizebronco.com/forum/...te-here-2.html
Sic semper tyrannis
dio vindice
SJeuck53 is offline
post #53 of 209 (permalink) Old 01-05-2016, 11:57 PM
91FordGuy's Avatar
Alright finally some trail shots! With me going to school in Colorado and my dad back in California, we do not get a lot of chances to wheel together. This past summer we did Miller Jeep Trail in Lockwood, CA. It is one of the more difficult trails around and I did not have to try an obstacle twice.
Here is a shot of my Dad completely ruining one of his wheels. We were about 1 mile from the top of the trail and the last 2 miles are supposed to be the most difficult. It began to rain and it was getting dark. He really pushed it to the top. (lets just say that a few guys that were camped at the top with $50,000 Jeeps said that they could not believe that a stock ramcharger made it up)
post #54 of 209 (permalink) Old 01-06-2016, 12:16 AM
raleigh's Avatar
Time for some old trail pics.
Before the rebuild started I wheeled the hell out of the Bronco, most of the trips I didn't get pics of.
This was a trail clean up project, we got about 30 rigs out that day, what a good time
This is a trail network called The Snakes, it was a very popular system. You could drive trails for days up there.
Dave
raleigh is offline
post #55 of 209 (permalink) Old 01-06-2016, 02:52 AM
91FordGuy's Avatar
Here's a video of when we did Miller Jeep Trail. You guys can watch other youtube videos of the trail to get an idea how technical the hard parts are and how our trucks handled it. Overall, it was a fun trail.
0:30-1:05 and 2:27-2:38 are just the Bronco. You guys can get an idea of what my 300 sounds like (efi exhaust manifolds to a single 2.5 pipe with a Flowmaster Super 44 muffler that dumps behind the rear tire)
post #56 of 209 (permalink) Old 01-06-2016, 09:31 AM
Resurection Ranch
379sinvb's Avatar
First time I took the top off.
And then the weekly car/truck show I attended that night.
Rick
Filly
379sinvb is offline
post #57 of 209 (permalink) Old 01-06-2016, 05:02 PM
Harley's & Bronco's FTW!
You guys gotta know... as a less than "mechanical" kinda guy, I love FOTM.
I get to learn so much and really enjoy the shots of the Bronco's being used or just looking so damn good.
I'll never understand why we don't get more votes on these things. There's just so much "WIN" to be seen here.
Folks really don't know what they're missing out on.
Anyway... thanks for putting on such a great show so far guys.
You're all winners in my book!
RAMPNT1, RAMPNT1, JGR and 3 others like this.
BikerPepe` is online now
post #58 of 209 (permalink) Old 01-06-2016, 07:28 PM
raleigh's Avatar
Thanks for the words Pepe, you are one of the biggest enthusiasts of this competition, thanks for helping to keep it alive man.
Now back to the goods!
Went out on one last trip before the tear down began, had a nice little dusting of snow, that made things interesting
Going up a hill with walls on both sides I got a little sideways and broke the adjustable track bar
This was before I decided to do a full resto so I fabbed a drop frame mount, the angles sucked anyhow!
About a month later the tear down began! Originally it was going to be a Bronco body on a 99 Superduty chassis but that fell through
This was the body I found
And the donor chassis
Well this was not to be so I went down a different road.
The beginning stages of the resto were lots of fun lol
BikerPepe` and Darth_ted_82 like this.
Dave
raleigh is offline
post #59 of 209 (permalink) Old 01-06-2016, 10:01 PM
Resurection Ranch
379sinvb's Avatar
Back on the rack for some gears. Judi packaged in some 4.10's in the selling price. So I took the opportunity to learn how to install my own gears. Not to hard now that I've done it.
New gears in
The rear has an Aussie limited slip that Bill (bmc69) had lighter springs put in. After wheeling it a few times that will be coming out and a locker will be going in. A limited slip just ain't enough.
Rick
Filly
379sinvb is offline
post #60 of 209 (permalink) Old 01-06-2016, 10:14 PM
raleigh's Avatar
I was going to say I was surprised you didn't take the opportunity to throw a locker in while you had it apart.
Now that I am running trails with mine (something I did not think I would be doing lol) I am considering taking out my LSD.
Although it did perform very well last weekend so I will take it out a few more time before deciding.
Dave
raleigh is offline
