Convert a Dually Dana 60 Front Axle - Ford Bronco Forum
post #1 of 22 (permalink) Old 09-06-2008, 03:02 PM Thread Starter
Retired Staff
bossind's Avatar
Convert a Dually Dana 60 to regular hubs.
This is from a 1997 F350 Diesel Turbo Dually
The Dually Hub we need to remove.
Start be removing the 2 larger bolts on back this will allow the calipers and bracket to be removed in one piece
Pry off the caliper
Next remove the hub screws
Pop out the retaining ring
Pull out the hub body
Using a special socket remove the locking nut
Fish out the lock ring
After you remove the retaining nut you should have 3 items
Now the hub and rotor will slide right off
before we do the conversion we will clean up the housing and paint it.
Stay Tuned.
bossind is offline
post #2 of 22 (permalink) Old 09-06-2008, 03:30 PM
william_ace's Avatar
Bronco Info: 1996 f150 300 ci sas/ZF/10.25/8 lug 44 front 37" tire thingys
is this going in your bronco?
william_ace is offline
post #3 of 22 (permalink) Old 09-06-2008, 03:46 PM
Hopper's Avatar
Bronco Info: Stockish 93 5.8L, E4OD, BW1356; 79, 400/T-18/NP205, D44/9"
WTF? I think it's perfect the way it is
Hopper is offline
post #4 of 22 (permalink) Old 09-06-2008, 08:07 PM
Formerly vt89gtvert
bigbrownbear's Avatar
Bronco Info: Brown 88 XLT, 302, c6, 32 BFG's
I thought the "converstion" just new hubs and rotors. I thought the spindles inward was all the same?
Poster formally know as VT89gtvert
"Depression is merely anger without enthusiasm"
"The problem with the gene pool is that there are no lifeguards"
bigbrownbear is offline
post #5 of 22 (permalink) Old 09-08-2008, 01:34 AM
Dan90FSB's Avatar
Bronco Info: 1990, 351W, E4OD, 8 lug Dana 44 SAS, 14 Bolt, Lockers, 37" IROKS, 10 point cage, sliders, winch
x3 ?
Under Construction 4x4- www.uc4x4.com
Dan90FSB is offline
post #6 of 22 (permalink) Old 09-08-2008, 01:53 PM
InfoFord's Avatar
Bronco Info: Picador 4 door bronco EFI 460 E4OD electric shift 1356 Tcase 3.55 10.25 rear, 3.54 Dana 44 front
spindle and in ward is the same he stated he was cleaning up the stuff
InfoFord is offline
post #7 of 22 (permalink) Old 09-08-2008, 02:17 PM
XDAILY's Avatar
Bronco Info: 1990 5.0 Eddie Bauer
Neat. That hub and rotor must weight a few pounds.
SAS D44,D60,10"lift,42's,4.10's,AOD/E4OD internals,Custom Bumpers,Aussie,Lockrite,Home depot
snorkle,K&N,True Duals,Hedman headers,High Flow Cats,Cherry Bombs. Still going.
XDAILY is offline
post #8 of 22 (permalink) Old 09-08-2008, 03:25 PM
is hazardous to others
hav24wheel's Avatar
Bronco Info: Wagoneer, 351M, C6, upside down 205
are you going to modify the hubs? or just gettin a different set? on my dually axle i just used some 15 inch wheels with 7 inches of backspacing instead of changin the hubs..(cuz i needed new wheels anyways and the custom back spacing was only a couple $ extra)
hav24wheel is offline
post #9 of 22 (permalink) Old 09-12-2008, 07:55 AM
bew8484's Avatar
Bronco Info: 1996 bronco XLT, 6in ttb lift, 35in grabbers
going in the bronco?
Sasd 96 is gone.
New one is here. Starting over this time. Full small block rebuild and dana 60 swap.
bew8484 is offline
post #10 of 22 (permalink) Old 10-03-2008, 02:49 PM Thread Starter
Retired Staff
bossind's Avatar
Getting the time to work on and wating for parts to come has taken a lot more time than expected.
So we cleaned it up a bit (Pics from my black berry)
And installed the locker.
bossind is offline
post #11 of 22 (permalink) Old 10-03-2008, 04:49 PM
LS SWAP EVERYTHING!
Red91XLT's Avatar
Bronco Info: half a bronco
wOOt, Steve's got One Ton's!
'91 XLT-totaled
This is not a Democracy, it is a Broncocracy
You do realize that you just reported the new owner of FSB?
-James
Red91XLT is offline
post #12 of 22 (permalink) Old 10-03-2008, 05:17 PM
kaudbron's Avatar
Bronco Info: 1989 Bronco 351W
sweet I have this same axle sitting in my garage waiting on funds
kaudbron is offline
post #13 of 22 (permalink) Old 10-03-2008, 08:01 PM
BIGBRONC92's Avatar
Bronco Info: 1992 custom, (OJ special) I6 w/5spd manual
and just when i thought your truck couldnt get any better................
BIGBRONC92 is offline
post #14 of 22 (permalink) Old 10-03-2008, 10:25 PM
Owned 21 Years
Hmmmmm,
He never said it was going in his bronco.
This would require expensive outer parts still.
Plus he never showed the 8 lug rear he'd need.
Plus he never mentioned the 8 lug wheels and all new tires he'd need.
It's going in his Bronco?
post #15 of 22 (permalink) Old 10-04-2008, 12:50 AM
RaisedIIPerfection's Avatar
Nice write up!
Do you still have the old parts?
Im not sure if it will fit my kingpin axle,but i need to space out my tires because our backspacing is wrong on our f350...This might be the way to go for me...
11"Coils,3"Body lift,3.5"dropped towers,custom xmember and bumper made by davids78bronco,sky shackle flip
D70RR 4:88s,D448lug ,44s and some other stuff.
Click Here or on Image below for my Superford Page
[IMG] image too big for sig. please keep it under 150 pixels high[/IMG]]
Originally Posted by jackhart
i voted for the lift, because even if it don't run, it'll look cooler sitting in your driveway lifted.
RaisedIIPerfection is offline
post #16 of 22 (permalink) Old 10-04-2008, 07:23 AM Thread Starter
Retired Staff
bossind's Avatar
Hmmmmm,
he's right I never said that.
Sure I did, in the members section.
bossind is offline
post #17 of 22 (permalink) Old 10-04-2008, 12:16 PM
Crawdaddy's Avatar
Bronco Info: 82 Ford Bronco 302, stock, electrical horror show
This shaping up to be a sweet build. And those are some excellent pics coming off of a blackberry. One-tons are a long way away for me.
Crawdaddy
82 Bronco XLT, 302,C6,NP208, MileMarker hubs, otherwise stock
Wanna know every piece that went into the build of the space shuttle? Want the assembly instructions as well? It's likely right here at FSB
Crawdaddy is offline
post #18 of 22 (permalink) Old 10-04-2008, 01:22 PM Thread Starter
Retired Staff
bossind's Avatar
Major progress made today, soon you'll see what I'm up to - but that will be another thread as this one is just dealing with the conversion.
bossind is offline
post #19 of 22 (permalink) Old 10-04-2008, 01:50 PM
just keep adding onto this one and have the title changed
post #20 of 22 (permalink) Old 10-04-2008, 02:17 PM
scott 351 wins's Avatar
Bronco Info: 1985 xl 300/c6,f 250 tow rig,1946 rat rod ford truck
i also have a dana 60 from a (91) daully, are the daully hubs worth anything . i would like to sell them when i get new single hubs.what hubs are you going with? ive been looking at dynatracs.
Originally Posted by IronHorse! View Post
man somebody should be doing a product review on his mothers vagina hole it's popping out pure stupid
scott 351 wins is offline
