Rear Axle Guide - Page 2 - Ford Bronco Forum
post #21 of 217 (permalink) Old 08-09-2004, 01:36 PM
Master Bater
plug ugly's Avatar
well, I have been through a handful of trails with no probs yet. So its been maybe 8 months so far, but its not a DD
Stupid is as Stupid does
mostly a 94 Bronco
wt4wheeling
plug ugly is offline
post #22 of 217 (permalink) Old 09-26-2004, 02:14 PM
Originally Posted by TTBlows
60's and 70s under vans got the exciter ring
What's the pinion offset like on van rears?
ΜΟΛΩΝ ΛΑβΕ
BlueBronco is offline
post #23 of 217 (permalink) Old 11-07-2004, 12:45 AM
Bronco Info: Widetrac
Ive blown around 3-8.8 axles (Spider gears) and finally found a rear Dana 70-u from a 80ish f-350 2wd. Paid like 120 bucks for it. Rebuild it with new gears for around 350 bucks with brakes. It bolted right in. Great swap for rears. Stops on a dime too.
yodude is offline
post #24 of 217 (permalink) Old 01-16-2005, 02:15 PM
Bronco Info: 80 Bronco
Would a D70 from a duallie be too narrow for my 80 Bronco?
fatrhino is offline
post #25 of 217 (permalink) Old 02-25-2005, 05:41 PM
Bronco Info: 79 ranger xlt (southern rust free). "warmed over" 460. eagle alloys. detroit locker/trac loc/moser's
limited slip axle
hey guys, i have a 79 bronco and i have a limited slip rear end. i'm putting on a 4inch skyjacker lift kit with new rear springs. i plan to put a 460 some day (money permitting) but being in college right now kinda makes that hard. even when i'm working full time. anyways. i was thinking of putting a locker in the rear end, but i think i might just stick with the limited slip. i can get it rebuilt here. what do you guys think? what would be better for riding in the dunes up here in michigan? can the limited slip hold its one compared to the locker? i'm not a hardcore wheeler. i want to keep my bronco looking orginal but with big tires and lift of course! i'm just wondering what would be best for my rear axle. any info would help. thank you very much.
mike
thegriz is offline
post #26 of 217 (permalink) Old 02-06-2006, 01:24 AM
There is now an ARB available for the 14B rear. One more thing that the GM haters are loving right now.
Masterphil is offline
post #27 of 217 (permalink) Old 02-06-2006, 02:30 AM
stx4wheeler's Avatar
Bronco Info: 95bronco(dd) 78 bronco trail rig
also as i found out this weekend when swapping sterlings- going from 3.55 -4.10's i found out that the pinion yoke on a f-250 sterling is made for a smaller u-joint, than the f-350 one, which sucks cause now i gotta buy another expensize conversion u-joint.
its a jeep thing eh, your right i wouldnt understand!!
95 bronco (DD) light bar four pro comp 130's, true dual exhaust through hollowed cats, and flowmaster 40's
78 bronco 460/c-6/205/60 front/ sterling 10.25 rear/hydro assist steering,lincoln locked front/rear, cage to the frame, and a garage full of parts.
stx4wheeler is offline
post #28 of 217 (permalink) Old 02-06-2006, 10:39 AM
Originally Posted by SquattyD
Dana 60 Rear End
Pros
  • Some 35 spline
Cons
  • Some 16 Spline
  • 3/4 ton? 1 ton? Who the Hell Knows
I've a list of ALL published BOM's by Spicer, from 1967 to 2002 they have 717 different BOM's for Just "Ford Dana 60 rear" axles.
For FORD ONLY Semi Floating Dana 60 axles have 35 spline. (Edit: there are Semi Floating with 30 splines)
No Full Floater ever came with 35 spline in a Ford, and very few at that FF 35 spline 60's are out there (less than 1%)
Here are All the different axle shaft and spline counts:
Shaft RH Shaft LH Spline count Length Manufacturer Model Location
35887-1 35887-2 Not Documented ? Ford 60 Rear
30282 30282 16 Spline 33.7" +-2 Ford 60 Rear
35445-1 35445-1 16 Spline 33.25 Ford 60 Rear
35445-2 35445-2 16 Spline 34.56 Ford 60 Rear
24810X 24810X 30 Spline Semi-Float 29.53" Ford 60 Rear
25984-1X 25984-1X 30 Spline Semi-Float 29.53" Ford 60 Rear
35467-1 35467-2 30 Spline 31.12 / 40.12 Ford 60 Rear
35467-3 35467-3 30 Spline 34.56" Ford 60 Rear
35467-4 35467-5 30 Spline 35.95 / 44.57 Ford 60 Rear
35467-6 35467-6 30 Spline 33.25 Ford 60 Rear
43811-16 43811-17 32 Spline 34.92 / 37.64 Ford 60 Rear
70867-15X 70867-16X 35 Spline Semi-Float 30.66 / 33.2 Ford 60 Rear
70867-1X 70867-2X 35 Spline Semi-Float 30.65 / 33.19 Ford 60 Rear
70867-3X 70867-4X 35 Spline Semi-Float 31.42 / 34.14 Ford 60 Rear
70867-5X 70867-6X 35 Spline Semi-Float 30.66 / 33.20 Ford 60 Rear
75344-1X 75344-2X 35 Spline Semi-Float 30.41 / 34.13 Ford 60 Rear
Who knows? I know
Edit: if your looking for a No-Spin or high factory gears stick to 67-74 Dana 60's.
My notes on Dana 44 and other Dana axles -> http://77cj.littlekeylime.com/web_rs44.html
Mr.N is offline
post #29 of 217 (permalink) Old 02-06-2006, 04:24 PM
Originally Posted by Mr.N
I've a list of ALL published BOM's by Spicer, from 1967 to 2002 they have 717 different BOM's for Dana 60 axles.
No Full Floater ever came with 35 spline in a Ford, and very few at that (less than 1%)
But the after market offers a lot of carrier options for 35 spline axles.
Wasn't there some years that had the PowrLok option in the semiFloat D60s in the late 60s and early 70s?
ΜΟΛΩΝ ΛΑβΕ
post #30 of 217 (permalink) Old 02-06-2006, 08:36 PM
Yeah, maybe next year I'll try to figure which Dana 60's came with the larger spindle to fit the 35 splines. (Most need to be opened up and not a easy job)
Yep, Didn't include that above. (Fixed)
60's and 70's Semi floating 60's
http://77cj.littlekeylime.com/images...mifloating.gif
Mr.N is offline
post #31 of 217 (permalink) Old 02-07-2006, 02:52 AM Thread Starter
Cadillac of Men
SquattyD's Avatar
Bronco Info: 78 Bronco
Who knows? I know
good shit. thanks for adding that. just another reason not to get a dana 60.
SquattyD is offline
post #32 of 217 (permalink) Old 02-12-2006, 10:39 AM
is FSB'd out
johnski's Avatar
Bronco Info: Cannondale Trigger 29er
Been researching rears as I'm about to swap and found this ID guide for all makes of dana. Hope it helps others as it's helped me...
http://www.onandoffroad4wheeldrive.c...axle_ident.htm
Originally Posted by Bronco Rob View Post
And just so you know Johnski is like Chuck Norris, he'd just roundhouse kick your bumper and your vehicle would explode.
CarolinaBroncos
johnski is offline
post #33 of 217 (permalink) Old 02-25-2006, 05:48 PM
Owned 21 Years
yes, 'cept it's not complete. My D60 BOM was not listed there. I took my number to six states distributors who confirmed it was from a 1977.5 Ford F250 2WD
On another note, the item of interest with Mr. N's stuff, in my opinion, is not so much the spline count (if you want a D60 fullfloat, go find one with 30 splines, cuz other than that, all you're gonna find are D60 from older trucks...say before 1975 or thereabouts...that are 16 spline) but this:
That entry appears to be the length of my shafts, measured from the shaft bolt mounting surface to end of splines. Notice there is no left/right length. I only carry 1 spare shaft.
also on a side note, if folks are concerned with braking these shafts, a possible upgrade is to buy the alloy shafts. I've seen several places sellem for $175.
post #34 of 217 (permalink) Old 02-28-2006, 12:40 PM
Ok, after trying to find a way to figure out which Dana 60 axle came with the larger spindle (so 35 spline axle could be swapped in) I gave up. Spicer doesn't list the the part number to check in my spicer info.
However I've this list of what Dana full floating 60 axles are non-30-spline.
I searched all 1970-1999 Ford, Dodge, Chevy, and Jeep.
BOM axle shaft # . . . Spline . . Lenth Bolt circle Bolt #'s Make Year, Model - Dana 60 Full Floating non 30 spline.
603884 36453-1 . . . . . 35 . . . 39.69" 3.56 8 Chevy 78 G 300 Van w/ 164" Wheel base
603545 36453-1 . . . . . 35 . . . 39.69" 3.56 8 Chevy 1975 G 300 Van w/ 164" Wheel base
603702 36453-1 . . . . . 35 . . . 39.69" 3.56 8 Chevy 1976 G 300 Van w/ 164" Wheel base
603398 36453-1 . . . . . 35 . . . 39.69" 3.56 8 Chevy 1973 G 300 Van w/ 125" Wheel base
603475 36453-1 . . . . . 35 . . . 39.69" 3.56 8 Chevy 1974 G 300 Van w/ 125" Wheel base
603560 36453-1 . . . . . 35 . . . 39.69" 3.56 8 Chevy 1975 G 300 Van w/ 125" Wheel base
603705 36453-1 . . . . . 35 . . . 39.69" 3.56 8 Chevy 1976-78 G 300 Van w/ 125" Wheel base
All Vans 41100-1 . . . . . 35 . . . 39.69" 3.56 8 Chevy 1979-1991.5 All Chevy vans with Dana 60
__________________________________________________ ____________________________________
605685 43811-16 & 17 . 32 . . . 34.92 & 37.64 3.96 8 Ford 1995-96 E350 Van SRW -ABS (Not all Vans)
605843 43811-16 & 17 . 32 . . . 34.92 & 37.64 3.96 8 Ford 1996 E350 Van SRW -ABS (Not all Vans)
605935 43811-16 & 17 . 32 . . . 34.92 & 37.64 3.96 8 Ford 1996.5 E350 Van SRW -ABS (Not all Vans)
605948 43811-16 & 17 . 32 . . . 34.92 & 37.64 3.96 8 Ford 1997.5 E350 Van SRW -ABS (Not all Vans)
606162 43811-16 & 17 . 32 . . . 34.92 & 37.64 3.96 8 Ford 1998.5-99 E350 Van SRW -ABS (Not all Vans)
Not all Vans= Those years came with both 30 & 32 spline shaft, check the BOM. Note 1999 does list as only 32 spline but info might have been left out and correct next book by Spicer.
Note: Even though the SPicer list all Chevy Vans from1979-1991.5 with 35 spline, this could be a typo!
Mr.N is offline
post #35 of 217 (permalink) Old 03-14-2006, 03:04 PM
That chart only had 60's and 70's info.
Here is my new one from 1967-2002! (All Spicer info, nothing more nothing less)
Mr.N is offline
post #36 of 217 (permalink) Old 03-14-2006, 04:02 PM
Mr. N,
Out of curiosity, I see in the chart that the Ford semifloat 60s from 67-69 had 30 spline axles. Is that correct? I see reference to 16 spline ones from time to time.
ΜΟΛΩΝ ΛΑβΕ
post #37 of 217 (permalink) Old 03-14-2006, 08:39 PM
Mr. N,
Spicer is not always 100% correct... so...
However I've two source that say my info above is correct. (Minus the 67-68 Chevy stuff...) So I;d say yes, it's 30 spline. Pre 67 I'm sure there is, but I've no info on pre 67 Spicer...
Now the Full Floater had 16 splines up to 1975!
(Hint for you axle hunters, they were under the 2wd version more often.
BUT not all 2wd were 16 spline, and a few 4x4 version also had the 16 spline. There was even a No-SPin 16 spline from 73-75! But now I'm getting off topic...)
Mr.N is offline
post #38 of 217 (permalink) Old 03-16-2006, 08:20 PM
Bronco Info: 1992 with solid dana 60 & sterling 125, arb lockers w/37 mudders
Need a rear differential - or a front D44 or D60
Or just have questions
Call Jeremy at Custom Differentials 573 483 3343
See article in Four Wheeler June 2005 Tech article "Axle Examination" relating to Ford / Sterling 10.25 and 10.5
I just ordered a 10.25 - in addition to a total rebuild ARB etc - they do things like cut the low shock mounts & relocate at axle height and ensure at the same location as the 8.8 also cut and replace spring pad adjusting the yoke angle to compensate for spring/lift, to keep proper u-joint angle, transfer case & rear end - Jeremy is very helpful...
Edit - if you need the backing bracket that sits on top of the leaf spring - it is set up for 9/16 u bolts, although you could drill out for 5/8 bolts - Chevy part number 00334527 cost $15.00 each
woodydog is offline
post #39 of 217 (permalink) Old 04-07-2006, 08:28 PM
RIP Spring Creek Off Road
bigbroncojeff's Avatar
Bronco Info: '93 351 bronco thing
10.25 swap
for any one who has done the sterling swap for a 93 back sterling 10.25 ...does my driveshaft need to be shortened?? right now the truck has 6 inches of lift (so four in the back really) and a stock length driveshaft with the E4OD/BW1356 combo if that makes a difference
i read somewhere that 93back sterlings have a shorter pinion than the 94+ but haven't been able to verify much... i'm trying to find out so i can decide between a 1 ton axle or just replacing the ring and pinion
........springcreekoffroad.com........
bigbroncojeff is offline
post #40 of 217 (permalink) Old 04-18-2006, 10:24 AM
Thumbs up Sterling 10.25 and 10.5
Not all sterling rear ends are full float, they also come in semi float as well. The most expensive part of doing a sterling swap is having the drive line motified to fit, other wise it's a simple bolt in. I've had my Sterling 10.5" in my 89 Bronco for about a a year and a half and have had no problems. The only issue I can for see with it is gearing choices for the moment. If my memory serves me correctly 4.56 is the lowest so far. Happy swapping.
Bigstump is offline
