Rear Axle Guide - Page 3 - Ford Bronco Forum
post #41 of 217 (permalink) Old 04-18-2006, 10:34 AM
TxTaurus74's Avatar
Bronco Info: 95 Bronco 351W w/ D60 Front & Sterling Rear
Originally Posted by Bigstump
Not all sterling rear ends are full float, they also come in semi float as well. The most expensive part of doing a sterling swap is having the drive line motified to fit, other wise it's a simple bolt in. I've had my Sterling 10.5" in my 89 Bronco for about a a year and a half and have had no problems. The only issue I can for see with it is gearing choices for the moment. If my memory serves me correctly 4.56 is the lowest so far. Happy swapping.
And that a 10.5 is metric isnt it? Or is that a typo and you meant 10.25? In that case I have 5.13 gears in mine...so there are lower gears...
TxTaurus74 is offline
post #42 of 217 (permalink) Old 05-03-2006, 12:35 PM
So you picked up a rear Dana 60 with 16 splines. Most likely it was from a 70-75 Parcel Deliver van or a 73-75 F250 Camper Special or a 70-75 HD 4x2 Pick-up. It came with the same length axle shaft on both sides, Spicer part number 35445-2 with 16 Splines and 34.56” long.
You want to swap the 16 spline shafts for 30…
Below is the Spicer axle shaft part number that is the same length axle shaft but with 30 splines! (Hint don’t for get the spider gears when you pull the shafts, or if your really luckily you’ll find a No-Spin)
35467-3 30 Splines 34.56” Dana 60’s
1976-1979 F250 Crew Cab – Full float
1976 F250 ¾ Ton 4x2 Pickup – Full float
1975-78.5 F250 ¾ Ton HD 4x2 Pickup – Full float (Lots of BOM’s)
1975-78 F250 ¾ Ton Camper Special Pickup – Full float
1979 F250 4x4 – Full float
1979 F250 4x2 – Full float
35467-3 30 Splines 34.56” Dana 61’s
1974-1977 F250 ¾ Ton HD 4x2 Pickup – Full float
Not a good option, might work as the shaft is similar in length.
31494-1 30 Splines, 34.75”
1969-1972 C20 Truck Chassis w/Leaf Springs
1969-1972 C20 Truck Chassis w/Coil Springs
1968-1972 C25 Truck Chassis w/Standard Wheel base
1967 L1500 Station Wagon (Chevy)
1967 K1500 Pick-up
1968-1972 K25 Truck Chassis
NOTE: I’ve never done this swap, just looked up the info for renopowers.
My notes on Dana 44 and other Dana axles -> http://77cj.littlekeylime.com/web_rs44.html
Mr.N is offline
post #43 of 217 (permalink) Old 05-03-2006, 03:40 PM
renopowers's Avatar
Bronco Info: '86 302 - Moving to Stage 2 of the master plan
Top notch Mr.N. Top notch!
'86 5.0, 6" Rough Country, 35x12.5 X-Terain, 8.8, D44-TTB(phase 1)
renopowers is offline
post #44 of 217 (permalink) Old 05-11-2006, 11:05 PM
renopowers's Avatar
I cannot remember where I saw the information but I believe I saw that the 16 spline and the 30 were the same size around (1 5/16"). So if they are the same size what benefits do I get from the 30 spline? Is it just aftermarket availability or is there a strength difference?
If there is a strength advantage provided by the 30 spline can you explain how that works?
Thanks!
-R
post #45 of 217 (permalink) Old 05-12-2006, 05:29 AM Thread Starter
Cadillac of Men
SquattyD's Avatar
Bronco Info: 78 Bronco
Thanks!
-R
basically, more surface area. the finer the splines, the more material that is in contact between the axle shaft and carrier.
SquattyD is offline
post #46 of 217 (permalink) Old 05-12-2006, 10:53 AM
Its also important how the splines were made which will apply to aftermarket/custom axles more so than oem shafts.
ΜΟΛΩΝ ΛΑβΕ
BlueBronco is offline
post #47 of 217 (permalink) Old 05-12-2006, 12:24 PM
JKossarides's Avatar
Hope this is the right place, what gear oil should I use for my stock 86 FSB 4x4 front & rear Dif. I couldn't find it in my Haynes. I looked at the Autozone, 90wt or 145wt. Does my 86 have limited slip?
Thanks
JKossarides is offline
post #48 of 217 (permalink) Old 05-12-2006, 01:33 PM
1990 Bronco and F150, F250, F350 and F-Super Duty rear axle codes codes that will be on the door decal under Axle. open diff unless specified with weight rating in parentheses. If there is a 3rd digit which is a 2, the front is limited slip. Source is 1990 Ford Specification Book Truck volume 2.
Code - Ratio (weight rating)
18 - 3.08 (3800)
19 - 3.55 (3800)
H5 - 4.10 with limited slip diff (3800)
H8 - 3.08 with limited slip diff (3800)
25 - 4.10 (3800)
27 - 3.73 (5300) Note: no 4x4 has a 3.73 ratio
29 - 3.55 (5300)
B9 - 3.55 limited slip diff (5300)
35 - 4.10 (6250)
39 - 3.55 (6250)
C5 - 4.10 with limited slip diff (6250)
C9 - 3.55 with limited slip diff (6250)
45 - 4.10 (7400)
49 - 3.55 (7400)
D5 - 4.10 with limited slip (7400)
65 - 4.10 (8250)
69 - 3.55 (8250)
F5 - 4.10 with limited slip (8250)
72 - 4.63 (11,000)
73 - 5.13 (11,000)
This will hold true for 1990 and maybe 1987,1988, 1989 and 1991. 90 is the first year I have specs on F-SuperDuty.
3800 rated axle fis Ford 8.8
5300 rated axle was semifloat sterling
6250 rated axle was full float sterling 10.25 found in F250-HD and F350 with single rear wheel
7400 and 8250 were dual rear wheel full float found in F350 and F350 chasis cab
11000 was a dual rear wheel Dana 80 found in the F-Super Duty.
Edit: This does not include E-series vehicles. Also, prior to '87 the weight rating can't be used to determine the axle in F-250 and larger trucks because there were both Ford and Dana axles in use.
ΜΟΛΩΝ ΛΑβΕ
post #49 of 217 (permalink) Old 05-12-2006, 02:38 PM
Ford Rear axle codes used from 1981-1986
13- Ford 9" 2.75 ratio 1981-83
13- Ford 8.8 4.11 ratio 1985-86
H3- Ford 9" ls 2.75 ratio 1981-82
H3- Ford 8.8 axle 4.11 ratio with limited slip 1985-86 (3800 pound)
14- Ford 9" 3.00 1981-1986
H4- Ford 9" 3.00 Limited slip diff 1981-86
15- Ford 9" 3.25 1981-82 and 2.73 in 1983
H5-Ford 9" 3.25 limited slip 1981-82 and 2.73 in 1983
16- Ford 9" axle 3.50 ratio (3750 pound)verified
H6- Ford 9" axle 3.50 ratio with limited slip (3750 pound)verified
18- Ford axle 8.8 3.08 ratio (3800 pound) 1983-86verified
H8- Ford axle 8.8 3.08 ratio limited slip (3800 pound) 1983-86verified
19- Ford axle 8.8 3.55 ratio (3800 pound) 1983-86verified
H9- Ford axle 8.8 3.55 ratio with limited slip (3800 pound) 1983-86verified
23- Dana 60-3 axle 3.54 ratioverified
24- Dana 60-3 axle 3.73 ratio verified
29- Ford Semi Float Sterling 10.25, 3.55 ratio
B9- Ford semi Float Sterling 10.25, 3.55 ratio limited slip diff
B5-Ford semi Float Sterling 10.25, 4.10 ratio limited slip diff
39- Ford full float Sterling 10.25 3.55 (single rear wheel)
C9- Ford full float Sterling 10.25 3.55 (single rear wheel) with limited slip diff
35- Ford full float Sterling 10.25 4.10 (single rear wheel)
C5- Ford full float Sterling 10.25 4.10 (single rear wheel) with limed slip diff
33- Dana 61-1 3.54 ratioverified
C2- Dana 61-1 3.54 ratio with limited slip diffverified
C7-
Dana 60 with a 3.54:1 ratio used in F250 in 1981-83 verified
52- Dana 70-1 HD 4.10 ratio (8700 rating)verified
53- Dana 70-1 HD 3.54 ratio from 1983-86 (4.56 in 1982) (7400 rating)verified
E2- Dana 70-1 Hd 4.10 ratio with limited slip diffverified
49- Ford Sterling 10.25 dual rear wheel 3.55 ratio (7400 rating)verified
D5- Ford Sterling 10.25 dual rear wheel 4.10 with limited slip diff (7400 rating)
69- Ford Ford Sterling 10.25 dual rear wheel 3.55 ratio (8250 rating)
F5- Ford Ford Sterling 10.25 dual rear wheel 4.10 ratio limited slip (8250 rating)
Axle code 25 changed 4 times from 81 to 86 in 81 it was a Dana 60 with 3.32 ratio and in 82 it was a Dana 60 with 3.33 ratio. In 86 it was a Ford SemiFloat 10.25 sterling with a 3.55 ratio. This code suposedly wasn't used in 1983,1984, and 1985
Additonal Dana 70 codes
27- 4.10 ratio 1981 and 1982 (7400 rating)
28- 4.56 ratio in 1981 and 1982 (7400 rating)
42- 3.73 ratio in 1982 (6250 rating), 4.1 ratio 1983-85 (7400 rating)
43- 4.1 ratio in 1982 (6250 rating), 3.54 ratio 1983-85 (7400 rating)
44- 3.73 ratio in 1982 (6250)
51- 3.73 ratio (7400) 1982
52- 4.10 ratio (7400)1982-86verified
62- 4.10 ratio (8200) 1982-85
63- 3.54 ratio (8200 rating) 1985
65- 4.56 ratio 1982 & 1983 (8200 rating)
B7 4.1 ratio with limited slip 1982 (7400 rating)
D2-4.10 ratio limited slip 1983-85 (7400 rating)
D3- 3.54 ratio 1983-85 (7400 rating) code used for Dana 61 in 1982
D7-4.0 ratio limited slip 1982 (7400 rating)
E2 4.1 ratio 1982-86 (8200 rating) verified
E3- 4.56 ratio ls in 1982 3.54 in 1983-84 with limited slip (7400 rating) code
E4- 3.73 ratio limited slip 1983-85 (7400 rating)
F3- 4.10 limited slip 1985 (8250 rating)
This info is from official ford spec books and is therefore suspect. There were a lot of wierd ratios used in some of the Dana 60 and 61 2wd F and E series, for example 3.33, 3.25, 3.47, 2.73, 4.0, 2.75
26 is a mystery code. It is a rear axle with a 4050 pound rating and 3.55 ratio and was used in 183-85. 8-lug 8.8? B6 is limited slip version. B7 was a 4.1 limited slip version in 1984. B7- in 1984 this code was used on a 4050 rated axle with a 4.10 ratio limited slip. In 1986 is was used for Ford semiFloat Sterling with a 3.73 ratio limited slip diff (5300 rating).
Dana 61 codes (some of these need to be verified)
31- 3.07 ratio in 1983-85 (6250 rating) and 1983-86 with a (6340 rating)
32- 4.10 ratio in 1983 to 1986 with both a 6250 and 6340 pound rating
*Note: in 1982 this code was used for a Dana with 3.0 ratio
33- 3.54 ratio 1984-86 in 6250 and 6340 pound ratingsverified
34- 3.73 ratio in 1984 with a 6250 pound rating
36- 3.75 ratio in 1981 and 3.75 ratio in 82
41- 3.54 ratio in 1982 (6250)
G2- 4.10 limited slip 1984 & 1985 (6300 rating)
G3-3.54 limited slip 1984 & 1985 (6300 rating)
C2- 4.10 ratio limited slip 1983-86 (6250 & 6340 ratings) verified
*Note: C2 was used as a code in 1982 for a 3.0 Dana 60.
C3- 3.54 1983-85 with limited slip (6250 & 6340 rating)
C4- 3,73 limited slip 1983 & 1984 (6340 rating)
D1- 3.54 limited slip 1982 (6250 rating)
42- 3.73 ratio in 1982 (6250 rating), used for D70 4.1 ratio 1983-85 (7400 rating)
43- 4.1 ratio in 1982 (6250 rating), used for D70 3.54 ratio 1983-85 (7400 rating)
72- 4.10 ratio 1984 & 1985 (6300 rating)
73- 3.54 ratio 1984 & 1985 (6300 rating)
ΜΟΛΩΝ ΛΑβΕ
post #50 of 217 (permalink) Old 05-12-2006, 04:23 PM
Larston's Avatar
Bronco Info: Broncoless, but I got a 1987 F250 to make up for it
I see an omission in your 81-86 axle list. There were a couple versions of the Dana 70-1U available those years (I've found several of them and have one in my rig.) I believe they would have had 3.73 and 4.10 gear ratios. I wonder if it may fall into those mystery numbers?
Larston is offline
post #51 of 217 (permalink) Old 05-12-2006, 05:11 PM
The 81-86 is incomplete because that is all that I have notes or information From the appendix of the 1987 Ford Light Trucks Fact Book. There are a couple of pages in the back on Past Model Identifcation for axles sued from 1981-86. Do you have the axle code and year from the door decal? The "mystery" codes 26, B6 and B7 are only a 4040 pound rated axle so there is no way it is a d70 of any type.
Edit: Look again and see if the codes have been added.
ΜΟΛΩΝ ΛΑβΕ
post #52 of 217 (permalink) Old 06-15-2006, 11:42 AM
Not a dude
Calisa1969's Avatar
Bronco Info: 1986 XLT
Time to beef up the rear end here... and I now have my choice between a sterling 10.25 and a chevy 14 bolt. We picked them both up for little, and nothing. So if you had the choice which would you use? I will have to replace what I have in there now. 5.13's and ARB, and of we'd do a disc brake conversion while we were at it.
thanks
lisa
Calisa1969 is offline
post #53 of 217 (permalink) Old 06-18-2006, 03:03 PM Thread Starter
Cadillac of Men
SquattyD's Avatar
thanks
lisa
you dont need the vss, and 14b is cheaper to build, so i would do the 14b. then sell the sterling to someone here who needs vss, and you can pay for your gears or something.
SquattyD is offline
post #54 of 217 (permalink) Old 06-18-2006, 03:21 PM
Not a dude
Calisa1969's Avatar
plus, i'll have the 8.8 with the arb, and 5.13's to sell to help with the cost.
thanks
lisa
post #55 of 217 (permalink) Old 06-18-2006, 05:11 PM
MikE2's Avatar
I'd probably go with the 14 bolt too, unless you want an ARB, I seem to remember hearing ones not available for the 14 bolt? I really don't know, check for yourself nbefore you do anything.
If it were me I would take whatever axle I could get an ARB in
MikE2 is offline
post #56 of 217 (permalink) Old 06-18-2006, 06:55 PM
Not a dude
Calisa1969's Avatar
I believe that there are now ARB's available for the 14 bolt. I read that somewhere, but I'll check on it
post #57 of 217 (permalink) Old 10-03-2006, 10:58 PM
chambiec1's Avatar
Bronco Info: Chevy, dodge... No bronco
Let me try to get something straight... when looking for a 14B... it will be just that, 14 bolts on the diff cover, right? Also, what's the quickest way to find out whether it is full-float or semi-float?
Thanks.
-Casey
My Superford
[dougs89] 1:57 am: i was flipping through channels and saw an old man with wood
[chambiec1] 1:57 am: like dick wood?
[dougs89] 1:58 am: no like big piece of wood wood
-Just call me "Casey"
chambiec1 is offline
post #58 of 217 (permalink) Old 10-03-2006, 11:01 PM
JB
Dead Horse
JB's Avatar
Bronco Info: 95 XL
Thanks.
-Casey
IIRC, full float will have the external hubs
95 XL on 37's
99 Civic Ex w/ b18c swap
JB is offline
post #59 of 217 (permalink) Old 11-02-2006, 09:58 PM
terry's Avatar
Bronco Info: 93bronco
i put a 9 inch in my 93 bronco. now i do not have a speedometer. any suggestions
terry is offline
post #60 of 217 (permalink) Old 11-03-2006, 09:46 AM
You no longer have a tone ring in your diff which means you lost your VSS. There are some kits that you can get to add one to your t-case output. Do a search and you will find some threads. Another way is to adapt a D60 to vss or go with a Sterling that had vss from the factory.
ΜΟΛΩΝ ΛΑβΕ
