SAS D44 COIL - 96 FULLSIZE - Page 3 - Ford Bronco Forum
post #41 of 41 (permalink) Old 02-24-2017, 10:12 AM
Owned 21 Years
Originally Posted by bwg96bronco View Post
they hook up to OBDII and verify that there are no codes thrown. Which does ABS have its own computer system not linked to the main system? If so i can just pull the bulb and inspection wont know. They do not physically check for sensors.
I have the ABS cutoff switch, i guess i can just see if codes come up when the fuse is cut...
But if the ABS does report to the ECM, i have to figure out how to make it think it is working
From this link, it looks like it does report codes for dignostic purposes and jumping these pins will eliminate that, although i do not know where this plug is
VSS speedo question
ABS Delete 94 Bronco
If you're talking about that thin rectangular plug the OP stated it's bolted to the 4WABS module.
