1997 F250 05+ superduty axle swap - Ford Bronco Forum
post #1 of 27 (permalink) Old 12-31-2014, 07:45 AM Thread Starter
chris_capps's Avatar
Bronco Info: 1988 Ford Bronco
So I bought a rolling chassis a couple years ago. It sat, and sat, and sat until I finally got off my butt. So anyway, u guys prob want pics.
Disclaimer. This is a way, not the way, some people on obs trucks did not like that I cut my coil buckets. Don't really care.
ogre20012001 likes this.
chris_capps is offline
post #2 of 27 (permalink) Old 12-31-2014, 08:39 AM Thread Starter
sorry, took a bit to get photos uploaded to photo bucket.
truck before
2006 rolling chasis on new 37 Kuhmos. guy parted out his truck after his 6.0 blew up.
post #3 of 27 (permalink) Old 12-31-2014, 08:47 AM Thread Starter
took some measurements on the frame, I placed my coil buckets 12.75 inches back from front body mount. I also trimmed about 2 inches off the bottom of the coil buckets. I didn't like the way they fit against the frame. Some people didn't like that because they think that lip is gonna hold the weight of the truck. (I don't think its a problem).
began stripping parts off the other frame?
once I was done, I cut the frame into pieces so I could take it to the scrap yard.
post #4 of 27 (permalink) Old 12-31-2014, 08:51 AM Thread Starter
the axles with nice 37 Kuhmos!!!
lift wouldn't pick the whole truck up. So I had to do one end at a time. I need to get this ram rebuilt.
post #5 of 27 (permalink) Old 12-31-2014, 08:54 AM Thread Starter
removing that bullshit TTB dana 50 crap... What the hell was Ford thinking?
post #6 of 27 (permalink) Old 12-31-2014, 08:58 AM Thread Starter
pic of cut coil bucket
Skyjacker 6" coil springs
Rancho Radius Arms
used go jacks to get axle under the truck.
my son helping!! (BEST PART)
post #7 of 27 (permalink) Old 12-31-2014, 09:01 AM
Peacemaker1994's Avatar
Bronco Info: Screw IFS... SAS in Progress
gorgeous truck man way worth the effort.
We do not live in America. America lives in us... And i'm proud to giver her a Home.
SAS thread http://www.fullsizebronco.com/forum/...d.php?t=227057
Peacemaker1994 is offline
post #8 of 27 (permalink) Old 12-31-2014, 09:02 AM Thread Starter
Wrote some notes to myself on the frame not to drill through wiring harness or brake lines. Also, kinda hard to see, but I used the front rivet hole to each rivet hole on radius arm bracket. I trimmed the front hole off the bracket, but you can see I used a 36" measurement and a 39" measurement.
post #9 of 27 (permalink) Old 12-31-2014, 09:06 AM Thread Starter
Ok, this is where the pics got ruined, mostly because it rained for 4 days in the middle of the swap.
post #10 of 27 (permalink) Old 12-31-2014, 09:13 AM Thread Starter
5.5" Zone lift blocks in the rear with 1" taller bump stops I had lying around.
I used 8" lift skyjacker shocks for the 2006. I ordered 6" skyjacker brake lines. The fronts were shorter than the stock 2006 lines. I just removed the metal brackets from the lines. re-installed the front end, tightened everything, built trac bar bracket and frame bracket with hime joints on both ends.
post #11 of 27 (permalink) Old 12-31-2014, 09:17 AM Thread Starter
pic of trac bar. I also fixed the parking brake. I cut the rivits on the 97 bracket, moved it up 3"
Due to the 2006 lines being diff lengths. there were hex pieces on both lines, that were close to the same length. I snipped the lines, drilled out the holes, and hooked it all up.
post #12 of 27 (permalink) Old 12-31-2014, 09:19 AM Thread Starter
a couple more random pics.
post #13 of 27 (permalink) Old 12-31-2014, 09:22 AM Thread Starter
so lastly, caster angle is pretty far off, I have drop brackets ill be installing this week. I am getting some death wobble at between 40-50 MPH. at 60+ rides smooth as hell. turning radius is awesome, turns around better than my single cab long bed. brakes are working great also. I already replaced front left caliper, right rear seems to be bad also. ill be getting to that this week also. I also have a dual shock steering stabilizer on the way.
post #14 of 27 (permalink) Old 12-31-2014, 10:18 AM
cstrike's Avatar
Bronco Info: 86 302/AOD on 8 lugs. 96 302/ZF5.
Yep, not that you are looking for confirmation but the coil buckets are fine. I really like the look and the Rancho arms are pretty beefy. Way nicer than what they make for the older trucks. Nice Job!
cstrike is offline
post #15 of 27 (permalink) Old 12-31-2014, 11:06 AM
aka: kemicalburns
TravisITGuy's Avatar
track bar angle is wrong and should match the drag link. they should be of similar length as well if I recall, this will cure your death wobble. Otherwise cool build, love that year truck
TravisITGuy is offline
post #16 of 27 (permalink) Old 12-31-2014, 01:09 PM Thread Starter
The length is actually very close, u just can't tell in the pic, angles are 5 degrees different. I think it's fine, right now I am at -1 degree castor, and it should be 3-5 positive. I think that will fix the death wobble. We will see.
post #17 of 27 (permalink) Old 01-02-2015, 12:04 AM
gadawgz71's Avatar
I'd be interested in your TTB hubs/rotors if you're interested in selling. I just need them for the 9/16-18 wheel studs. My 79 Dana 60 uses 1/2-20 studs.
1996 Wht Sport MAF/OBD II 466-1995 Blk XLT 351
SOLD
1996 PG EB 351-1996 Wht EB 351-1996 Wht Sport 351-1994 Wht Sport 351
1996 MB EB, KR Interior 302-1996 Wht EB 351, 3" BL, 33's-1996 PG EB 351
1996 Wht/Tan XLT 351w-1996 PG EB 351-1996 Black Sport 408w, SAS, 40's
1995 Blk EB 351-1996 MB EB 351, 6", 35's-1996 Wht Sport 351-1996 PG EB 351
1996 M EB, 302, SAS D44-1995 Blk Sport-1990 302, M5OD, 3" BL, 33s
1996 Wht EB 351-1993 G EB 357w-1978 XLT 351m-1971 Sport, 331w, 4.5", 35's
gadawgz71 is offline
post #18 of 27 (permalink) Old 01-27-2015, 06:48 PM
Bronco Info: 1995 Bronco
was this a Dana 60 and Sterling 10.5 from a 03 and up Super Duty?
summrs2 is offline
post #19 of 27 (permalink) Old 10-18-2016, 11:15 PM
Hey chris_capps I have a question about the rear. How did you do the rear swap did you just use 96 leaf springs or did you use the super duty ones?
Erickjm56 is offline
post #20 of 27 (permalink) Old 12-20-2016, 09:36 AM
Shovel's Avatar
Bronco Info: 1990 BRONCO Custom | 347 | M5OD
Caster change fix the death wobble?
Shovel is offline
