IIVIIoonshiner's Low Lift SAS - Page 9 - Ford Bronco Forum
 16Likes
post #161 of 179 (permalink) Old 04-29-2016, 10:26 PM
Getting There's Avatar
That looks sweet!! Great job getting it done so fast You should try to post a video of the awesome sound. It will give all of us turbo diesel wannabes something to drool over.
Getting There is offline
post #162 of 179 (permalink) Old 05-10-2016, 01:08 AM
Absolutely fantastic build. So clean all around.
1990 F150XLTLariat. 300I6. ZF. BDS. 36x16.5x15 FC.
SAS under construction
Russo2 is offline
post #163 of 179 (permalink) Old 05-14-2016, 08:55 PM Thread Starter
IIVIIoonshiner's Avatar
Thanks very much! I'm loving her!
I appreciate it brother! I'll try to get a video before I pull the bed (I'm chasing a fuel tank leak)
IIVIIoonshiner is offline
post #164 of 179 (permalink) Old 05-17-2016, 03:55 AM
pinkunr's Avatar
Bronco Info: 1990 FSB 351W, 6" Lift *SOLD* 1995 F150 351W C6 9" D44 Locked F/R 4:10s 6" lift
Great build, thanks for sharing!
pinkunr is offline
post #165 of 179 (permalink) Old 06-25-2016, 08:22 PM Thread Starter
Belle has some new shoes
35 12.50 r17 BFGoodrich at ta ko2 (real world measurement 34")
17x9 -12 bs American Racing Baja in matte black
no rubbing except for a bit at the bumper but I'm planning on trimming until I can build my custom bumpers. I like the look of black on tan
enjoy!
and yes videos soon (but i don't have the fuel turned up so don't expect coal rolling just yet lol)
Slightly Modified
post #166 of 179 (permalink) Old 06-25-2016, 08:59 PM
helirich's Avatar
Looks fantastic! The bumper does look a little close. Saws all or cut off wheel will make quick work of that.
helirich is online now
post #167 of 179 (permalink) Old 06-25-2016, 11:51 PM
Nice, looks mean.
post #168 of 179 (permalink) Old 06-26-2016, 09:00 AM Thread Starter
thanks gents! I must say that it's physically impossible to drive her without smiling!
Slightly Modified
post #169 of 179 (permalink) Old 08-06-2016, 08:01 AM
BrandonMag's Avatar
Bronco Info: 1990 Eddie Bauer
Update needed.
...and he who knows most, knows best how little he knows. Thomas Jefferson
1990 Eddie Bauer 4BT-E4OD-D60-10.25
lots o' goodies, work in progress
BrandonMag is offline
post #170 of 179 (permalink) Old 10-03-2016, 09:16 AM Thread Starter
working on some things
like any project that you think is "finished" it never seems to be the case... I took out the battery tray to paint it and found that my passenger core support needed replaced... which led to wanting to replace every body mount.... which led to pulling up the floor... which led to fixing some rust... and painting it with implement paint... and re-installing sound deadener...
anyways I bought a Mazda cx5 so that I can take my time and get my baby right! here are some pictures!
more to come...
Slightly Modified
post #171 of 179 (permalink) Old 10-25-2016, 10:51 AM Thread Starter
I'm editing this post to say that Bronco Graveyard came through for me this time.
I was able to get a core support sleeve and was able to get the rubber off and replace it with the polyurethane version from my kit. (I'm sure that rubber would isolate Diesel motor vibrations nicely but I A. don't ever want to have to do this crappy job again, and B. couldn't find oem replacement body mounts in rubber)
the cab and core support are remounted and everything under the hood is back together and working in sync
I am putting a new floor in from LMC truck next and cleaning out the cowl (also re-sealing, re-weatherstripping, and re-painting to avoid rust and leak issues) Once I have this done I will be in daily driver mode for a while
Slightly Modified
post #172 of 179 (permalink) Old 02-21-2017, 10:13 PM Thread Starter
building bumpers
Upon coming into some spare money... I decided to spend a bit and buy a broncoair front winch bumper.
but I had some grand schemes for building my own rear bumper. I had a local shop shear me out some 1/8" and 1/4" plates and ordered some trinkets like shackles and led license plate lights etc... here are the results
Slightly Modified
post #173 of 179 (permalink) Old 02-22-2017, 07:00 AM
helirich's Avatar
Pretty cool. I'm not sure if I like the "off center" winch. I do think it will be more useful that way. My preference is useally function over form, so I guess I would get use to it. Nice job!
post #174 of 179 (permalink) Old 02-22-2017, 08:07 AM Thread Starter
yes it was a necessity since I'm cramming 11 lbs of poo in a 10 lb sack... There is a reason that not many folks have rear winch bumpers. There is very little room inbetween the frame rails/behind the fuel tank/ under the tailgate.
It could be centered if I had made the bumper deeper than 7" but then the bumper would hang down much lower and look clunkier. Also that would offset my license tag outside of the clevis' and the outside of the bumper would not be able to flare up or in as fast.
here are some pictures of how much junk is in that center hole. ( and I still have to figure out my trailer wiring in there as well
'89Bronco302, TJSmoot and Dman94X like this.
Slightly Modified
post #175 of 179 (permalink) Old 02-22-2017, 03:36 PM
helirich's Avatar
I could see where the off center could be good. Like if You had a trailer like mine, you could run the cable down the side of the tongue and tow something up on the trailer.
post #176 of 179 (permalink) Old 02-25-2017, 05:59 PM Thread Starter
i also installed the front bumper.... next is copious amounts of wiring
TJSmoot and biggum like this.
Slightly Modified
post #177 of 179 (permalink) Old 02-25-2017, 06:25 PM
biggum's Avatar
Sweet rig MS! Love it
biggum is online now
post #178 of 179 (permalink) Old 04-04-2017, 02:09 PM
chris_capps's Avatar
Bronco Info: 1988 Ford Bronco
MAN!!! I just read this entire build thread, and I gotta say, I love this truck. Only thing I would have liked better is a black grille with black trim and mirrors. but sweet truck, and great build thread.
chris_capps is offline
post #179 of 179 (permalink) Old 04-11-2017, 06:35 PM
marshallnoise's Avatar
Bronco Info: '79 Custom
Beautiful job man.
1995 BMW 540i
'79 SHTF Daily Build
1997 Toyota 4Runner (locked)
marshallnoise is offline
