D44 SAS in 88 F-150 - Page 3 - Ford Bronco Forum
 7Likes
post #41 of 56 (permalink) Old 11-14-2016, 10:29 AM Thread Starter
I bought all of the parts for the rear axle swap.
-6" pro comp leafs
-5/8" ruff stuff U-bolts
-3/8" ruff stuff top plate
-ruff stuff lower shock mount
-Bronco graveyard extended brake line.
I hope to get started this week.
Vochy: '06 F-150, Black Supercab Short box, 5.4L 4x4 XLT, 1" Daystar Leveling Kit, 275 70 R17 BFG A/T KO's
88' F-150 Black Short Box, 302 4x4, true dual flowmater 2in exaust, Mustang equal length headers, 31X10.50 R15 BFG A/T KO's, New Doors and Fenders installed, MAF conversion, Six Liter Tune up, Saginaw Power Steering Pump upgrade, P&P GT40 Heads, 3G Alt Upgrade, D44 SAS and 9" rear in-process.
Vochy is offline
post #42 of 56 (permalink) Old 11-27-2016, 11:02 AM Thread Starter
I got the 8.8 pulled yesterday but I am still cutting the eyeballs out of the spring hangers, what PITA.
Vochy is offline
post #43 of 56 (permalink) Old 11-27-2016, 12:03 PM
67galax's Avatar
eyeballs?
you mean you're trying to get the old springs free of the hangers? I think when I did the red truck, i had to more/less cut the heads off the bolts and drive them out with a punch. At least you're getting new springs and won't have to re-bush some old ones. They're a chore to remove also.
67galax is offline
post #44 of 56 (permalink) Old 11-27-2016, 01:43 PM Thread Starter
lol, yes eye bolts. I torched the heads off and tried to drive them out with an air chisel but they did not budge. I completely torched one set out but had to burn all of the rubber out of the bushing. It seems like there should be an easier way.
Vochy is offline
post #45 of 56 (permalink) Old 12-07-2016, 12:58 PM Thread Starter
I got everything cut out and removed last week. I primed and painted the frame with John Deere Blitz Black and hung the new springs and shackles on Saturday. I also made the hard lines for the brakes on Saturday. Sunday I torqued all of the spring bolts down to 115 ft-lbs and got the axle slid under the truck. Its started to get cold so I haven't done anything since Sunday. I hope to get the axle hung from the springs this Saturday and see what she looks like on her own weight.
Vochy is offline
post #46 of 56 (permalink) Old 12-07-2016, 09:52 PM
67galax's Avatar
Did you get a new driveshaft for the rear? I know a 6" lift is about what most say the limit is for a stock length driveshaft (I'm still using mine). Just curious and if you did get a different one, where you got it and what you think of it so far.
67galax is offline
post #47 of 56 (permalink) Old 12-09-2016, 10:25 AM Thread Starter
The cold put a stop to my work. I got the 9" hanging from the leaf springs and the u bolts almost snugged up. I was having trouble with the alignment pins in the springs lining up with the axle perches and called it a night. My drive shaft situation will be different than yours because I am swapping in a 9" and I think the pinion is farther back than the 8.8. also because it is a truck the angle of the drive shaft will be less sever than a bronco. But never the less, if I need the drive shaft modified I will take it to Saddler powertrain in davenport.
Vochy is offline
post #48 of 56 (permalink) Old 12-30-2016, 04:33 PM Thread Starter
I got the u bolts snugged and the pins aligned and the brakes bled. I installed the front of the shaft in the slip joint but the caps on the U-joint seem too big for the 9". Does the yoke for the 9" take a smaller U-joint than the 8.8?
Vochy is offline
post #49 of 56 (permalink) Old 12-30-2016, 04:58 PM
Owned 21 Years
It likely is different. The 8.8 uses a 1330 cap, the 9 in many applications as I recall uses a 1310.
post #50 of 56 (permalink) Old 01-01-2017, 06:00 PM Thread Starter
You're right, I pulled some measurements today. The 9" has the 1310 style and my drive shaft is the 1330 style. I guess I have to decide if I want to go with a conversion U-joint or change the yoke on the 9". Anybody have any luck with the conversion U-joints?
Vochy is offline
post #51 of 56 (permalink) Old 01-31-2017, 08:18 PM Thread Starter
I got the rear all finished not long ago and took it for a test drive. Wow those gears with 31's gave it some giddy up!
I need some shocks. I know some guys like to remote reservoir $200 per a corner shock but my budget is more like $200-300 total. Does any body have any good suggestions for shocks that are in that price range?
Vochy is offline
post #52 of 56 (permalink) Old 02-01-2017, 07:15 PM
67galax's Avatar
Don't know about shocks, but does the truck still have the 5.0, or did you get the 5.8 built and installed?
67galax is offline
post #53 of 56 (permalink) Old 02-02-2017, 05:51 PM Thread Starter
Short block is built and sitting on an engine stand. I actually just got my edelbrock performer truck intake yesterday. I am waiting for the lower still.
Vochy is offline
post #54 of 56 (permalink) Old 02-03-2017, 05:51 PM Thread Starter
I'm looking at the Rancho RS9000 XL series. I like the 9 adjustment positions and run about $100 a piece. I figure 2 of those up front and maybe 2 5000 series for the rear.
Does anybody have experience with these?
Vochy is offline
post #55 of 56 (permalink) Old 03-11-2017, 01:05 PM Thread Starter
I decided not to cheap out on front shocks and got Bilstien 7100 with remote oil reservoirs. I got those installed on Wednesday night but haven't had a chance to drive it yet. I'm still trying to figure out what to do with the rears. I really want to cut off the axle end of the mounts and move them up to keep them safe. But if I do then I should make new upper mounts too.
Vochy is offline
post #56 of 56 (permalink) Old 03-11-2017, 09:30 PM
Owned 21 Years
yup
