F150 Solid axle swap SAS - Ford Bronco Forum
  • 1 Post By JScatt
post #1 of 7 (permalink) Old 09-28-2016, 11:31 PM Thread Starter
Alright here goes nothin!
I've been filtering through threads on this topic for way too long now and can't seem to find my scenario, so here it is.
I have a 1994 f150, 2wd, and an assortment of 1978 f150 parts, including a solid Dana 44 I want to put in.
I'm looking to do as little fabricating and keep it low cost as it is my daily driver meaning it will never see boulders or be under stress. It doesn't need all the beefing up with extended radius arms and custom spring shims as I'm not getting outrageous springs. Daily driver also means this swap needs to be done in a weekend, so as much research and pre-prep is what I'm doing
First off I'm keeping the stock 96 spring buckets. The more I have to meddle the more room for human error, I'd like this primarily bolt on.
This is where I feel like the only one, but I'm not lifting it 5 feet in the air! I'm hoping this cuts down on a lot of complications I've been reading about. It will be lifted 2.5 inches(note I have read that keeping stock 96 spring pockets with this axle will also lift 2ish inches, giving 4 inch total correct??). I will be buying a 78 suspension lift,equipped with required c bushings,MY FIRST QUESTION:do I need radius arm drop brackets if it comes with c bushings? I'm asking because so many of these threads are dealing with 6+ inches of lift.
Steering is my next topic since all the other threads are dealing with outrageous lifts. I have read that the F350 steering rack ball joints and linkages will fit my truck and the axle, but have heard vague issues with it being too long, some clarification would be great. SECOND QUESTION:do I need a drop pitman arm for the size of lift I'm doing?
Final need for clarification is on the Trac bar since I'm not lifted 5 feet off the ground. I've seen there's a bracket I can get online, is it just a matter of bolt on and done?
Any other clarification or advice would be appreciated. Thanks guys
Greggor94 is offline
post #2 of 7 (permalink) Old 09-29-2016, 06:42 AM
JScatt's Avatar
So that others understand what you are doing.....You want to convert your 94 F150 2wd to 4wd.
If so I think you will need more than a weekend.
You didn't mention anything about the drivetrain such as transfer case, drive shafts etc..
dash_cam likes this.
-Archie Bunker
bron·co/ˈbräNGkō/
Noun:
JScatt is online now
post #3 of 7 (permalink) Old 09-29-2016, 06:52 AM Thread Starter
"I can do the rest later, I am aware what is necessary, I will need to do a clutch, so I've got a different tranny with a transfer case, it can all go together piece at a time and I'll slap the driveshafts in later. For now I just need the axle in since my ttb 2wd is shitting the bed.
post #4 of 7 (permalink) Old 09-29-2016, 07:57 AM
Resurection Ranch
379sinvb's Avatar
Have you looked at this one? As it is 90% of your scenario from what I've read. I also moved you to the SAS section. You will get more crediable answers there.
Vote me your Sept. FOTM!
Rick
My Projects- "Left for Dead"
Filly
379sinvb is offline
post #5 of 7 (permalink) Old 09-30-2016, 12:18 AM
muffinman944's Avatar
Bronco Info: 1990 Bronco Custom (parted out; cab/frame sold), 1995 Bronco XLT (Fummins)
Are you lifting 2.5 or 4"?
Either way a low lift SAS is a challenge, but I know its been done. I doubt you'll "need" a dropped pitman arm, but the main factor will be what you do with your steering and what angle your trac bar needs to be at. If you find a trac bar upper mount that's geared towards that height, I suppose you could use that and then figure out what pitman arm you need from there.
Good luck! A start to finish SAS in a weekend is no small task.
1990 Bronco...sold
1995 FSB: D60/AAM 11.5'', BTS E4OD/Atlas II, 6.7 Cummins conversion in progress
2017 Silverado 1500 Custom: Daily Driver
SuperMotors Profile: http://www.supermotors.net/users/muffinman944
muffinman944 is offline
post #6 of 7 (permalink) Old 09-30-2016, 11:35 PM
Owned 21 Years
So if you are keeping the stock '96 towers that hold the spring up top, those are indeed about 1" shorter as I recall from all my research years ago. Then if you are using 78 suspension, the lower coil of course will be fine with the axle mount, and I believe the upper fits ok with a TTB tower as I know others have done this in the past.
Lift, you are buying a '78, 2.5" lift kit? That should net you about 3.5-4". If your C bushings have some correction (I'd guess 2*), I'd think you would not need drop brackets. The lift kit you plan to buy is not including these, correct?
Someone else will have to comment on Ford F350 linkages. I do recall some topics on this, but aftermarket DOM Tube and 1 ton chevy joints are cheap and simple as well, several manufactures offer complete kit's these days. May not need a dropped pitman either, but that can be dealt with after the fact if the steering angles are not to your liking. The upper track bar bracket is easy, you certainly can buy something online and bolt it on, no welding required. Can you post a pic or link of what you are looking at, not all upper attachments are the same, I've seen crap and I've seen lots of great stuff.
How is the condition of your D44....track bar attachment, not too much rust, inside the axles, have you pulled it all apart for cleaning?
post #7 of 7 (permalink) Old 10-28-2016, 09:30 AM
IIVIIoonshiner's Avatar
might wanna look at my build thread.. I started with low lift springs but had to go to 4" springs so that road bumps wouldn't slap the pumpkin on the crossmember
it would have saved me alot of heartache to do it once instead of twice.
btw I tried to go really low (custom crossmember and all) but really low is logistically pretty tough on these trucks because of where the motor sits
as a side note though: Although my truck sits on 35's i have it low enough that 33's would look great (that's pretty low)
Slightly Modified
IIVIIoonshiner is offline
