Crazed SAS pics (finally) - Page 30 - Ford Bronco Forum
post #581 of 600 (permalink) Old 01-14-2012, 10:32 AM
Owned 21 Years
There have been a couple threads on dual shocking Tim. Plus landshark just updated his SAS build....finally got his single bilstein's dialed in with a MUCH stiffer setting and he says it's now way more stable. I can tell you with my truck, the dual shocks were the answer, just no need for swaybar now.
post #582 of 600 (permalink) Old 01-14-2012, 11:56 AM Thread Starter
F.O.T.Y. 2003
Crazed's Avatar
My truck already has the dual duff shocks in a cage hoop, was wondering if some bilsteins would help. I have also been holsing on to a pair of superlift springs that have a much higher spring rate. I dont use the '89 for wheelin anymore, he is for some occasional sand, and just lookin good.
Crazed is offline
post #583 of 600 (permalink) Old 01-14-2012, 12:26 PM
Owned 21 Years
try pulling a shock and seeing how stiff it is with rebound and compression.
No more deep mud holes up at Wenatchee, eh?
post #584 of 600 (permalink) Old 01-14-2012, 01:45 PM Thread Starter
F.O.T.Y. 2003
Crazed's Avatar
Crazed is offline
post #585 of 600 (permalink) Old 01-17-2012, 11:54 PM
Too many broncos!
landshark99's Avatar
Bronco Info: 1969 and 1976 Broncos
Originally Posted by Crazed View Post
Think Im gonna need to add some swaybars to this thing. I moved up into Washougal, and I drive some pretty windy wooded roads and it just dosent feel that great.
Wondering if swaybars or better shocks would do it.
I pulled the shim stack on the 7100's - i had to increase the rebound.. i had sway above 60mph on the highway and it really made it interesting on curves...
Pulling the shim stack gave me 365/100 (Approx), if i had to reorder all over again i would get 365/110 but honestly its drives really nice now on the street and less bounce on the trail..
Not sure how much weight you have up front with that motor but i assume my truck is near 3200lbs on the front with the bumper, winch, battery etc.. but i only have a little 302..
hope it helps.. I know you have duals up front.. so sure you could just add one set and dial them in..
landshark99 is offline
post #586 of 600 (permalink) Old 01-18-2012, 08:48 PM
Shovel's Avatar
Bronco Info: 1990 BRONCO Custom | 347 | M5OD
Got some stuff cleaned up and its up on the stands
So, what jackstands are those?
Shovel is offline
post #587 of 600 (permalink) Old 01-19-2012, 08:36 AM Thread Starter
F.O.T.Y. 2003
Crazed's Avatar
THose were some I borrowed, ended up buying ones pretty much the same, found them at the big portland swapmeet.
Crazed is offline
post #588 of 600 (permalink) Old 01-19-2012, 12:23 PM
Shovel's Avatar
Sweet. BTW, excellent work on the SAS... and the 460!
Shovel is offline
post #589 of 600 (permalink) Old 01-19-2012, 04:23 PM Thread Starter
F.O.T.Y. 2003
Crazed's Avatar
ANyone know what the valving is in a james duff 70/30 shock? I have the 15" travel ones on there and am thinking of going to some Bilstiens
Crazed is offline
post #590 of 600 (permalink) Old 01-19-2012, 04:33 PM Thread Starter
F.O.T.Y. 2003
Crazed's Avatar
Either these for single
Brand Bilstein
Manufacturer's Part Number 25-101980
Part Type Shocks and Struts
Product Line Bilstein 5150 Series Shocks
Summit Racing Part Number BSN-25-101980
Internal Design Monotube
Adjustable No
Gas Charged Yes
Bushing Material Rubber
Bushing Color Black
Boot Included No
Extended Length (in) 34.900 in.
Collapsed Length (in) 20.370 in.
Upper Mount Eyelet
Lower Mount Eyelet
Quantity Sold individually.
Notes Fixed reservoir, 255/70 valving designed for dual shock setup. Platinum powdercoat finish. 20.37 in. travel.
or these for dual
Brand Bilstein
Manufacturer's Part Number 25-188349
Summit Racing Part Number BSN-25-188349
Adjustable No
Gas Charged Yes
Bushing Color Black
Boot Included No
Upper Mount Eyelet
Lower Mount Eyelet
Notes Fixed reservoir, 170/60 valving designed for dual shock setup. Platinum powdercoat finish. 20.37 in. travel.
Crazed is offline
post #591 of 600 (permalink) Old 01-19-2012, 04:39 PM Thread Starter
F.O.T.Y. 2003
Crazed's Avatar
HAd good luck with these on my ttb, these should be long enough
Brand Rancho
Manufacturer's Part Number RS999036
Product Line Rancho RS9000XL Shocks
Summit Racing Part Number RAN-RS999036
UPC 039703090360
Internal Design Triple-tube
Adjustable Yes
Gas Charged Yes
Bushing Material Polyurethane
Bushing Color Red
Boot Included Yes
Boot Color Red
Extended Length (in) 36.125 in.
Collapsed Length (in) 21.125 in.
Body Diameter (in) 2.750 in.
Upper Mount Eyelet
Lower Mount Eyelet
Crazed is offline
post #592 of 600 (permalink) Old 01-19-2012, 04:44 PM
Whats the valving on the Ranchos? I like the bilsteins because of how stiff they are, altho i dont have a set (yet) so i cant comment on how they perform.
reptillikus is online now
post #593 of 600 (permalink) Old 01-19-2012, 06:22 PM
Local # 40 Boilermakers
BRONCONUT's Avatar
Bronco Info: transforming...
I have dual 255/70 5150's up front and I think they handle fine on the road, I get a little body roll when I turn sharper turns at higher speeds. I tend to keep it a little slower now than when I had the ttb but all in all I like them. I think having singles up front might not be enough for what you are wanting it to cure.
UNION PRIDE
MY STUPIDMOTORS
BRONCONUT is offline
post #594 of 600 (permalink) Old 01-19-2012, 06:48 PM Thread Starter
F.O.T.Y. 2003
Crazed's Avatar
Ranchos are 9 positition adjustable
Crazed is offline
post #595 of 600 (permalink) Old 07-31-2015, 02:50 PM Thread Starter
F.O.T.Y. 2003
Crazed's Avatar
Diggin thru the old post, trying to find numbers for my tbird calipers
Crazed is offline
post #596 of 600 (permalink) Old 01-23-2017, 02:50 PM
I reamed out the knuckles for moving the tie rods to the top
Anyone know what tie rod end this is off of?
forrest411 is offline
post #597 of 600 (permalink) Old 01-23-2017, 03:29 PM
Owned 21 Years
Likely just a GM TRE:
ES2233LD or ES2233LU TIE ROD END, WITH TAPPERED HOLE
post #598 of 600 (permalink) Old 03-13-2017, 04:22 PM Thread Starter
F.O.T.Y. 2003
Crazed's Avatar
Yes, pretty sure that's it, 3/4 ton chevy stuff right?
Crazed is offline
post #599 of 600 (permalink) Old 03-13-2017, 04:52 PM
Owned 21 Years
Yep, worked plenty well all these years. You still have your 89 don't you Tim? Hope all is going well with you. I'm flying in next couple weeks, parents home in Salem is being sold and I'm moving them out here. My dad isn't doing well, Dementia that is getting bad.
post #600 of 600 (permalink) Old 03-13-2017, 05:07 PM Thread Starter
F.O.T.Y. 2003
Crazed's Avatar
Yes still have the '89, don't drive it much as my commute is like 70 miles a day and the brakes have been sticking on.
Also have the '78 and the '91
Sorry to hear about your dad, will be nice to have him close. I spent as much time as possible with mine in his last couple years.
Crazed is offline
