Crazed SAS pics (finally) - Page 4 - Ford Bronco Forum
post #61 of 600 (permalink) Old 03-14-2006, 02:35 PM
Bronco Info: '89 Xlt, '79 Custom
Originally Posted by Shadofax
did you ream out the pitman arm, or is that one coming off for a superduty one?
I havent touched the pitman arm, i have a f350 one and the 4" drop one, when we do the track bar we can figure out which arm to use and top or bottom.
Crazedatwork is offline
post #62 of 600 (permalink) Old 03-14-2006, 02:36 PM
Crusher Mike
1clean5.8's Avatar
Bronco Info: 1991 Eddie Bauer 5.8. Flowmaster exuast, SAS 35 mickeys 7" lift, 4.88s locked, Viar OBA
What is the length of the Tie rod and drag link ???
Originally Posted by MYXD40 View Post
okay so scrap the 1 ton and throw in a D60?
1clean5.8 is offline
post #63 of 600 (permalink) Old 03-14-2006, 02:38 PM
Originally Posted by 94_chickentaco
Did your axle have any type of original caster adjusters on the upper ball joint?
Also, while you have the reamer out are you planning to ream the TRE for the draglink? And a spare set too?
I saw no caster adjusters on the upper balljoints, just the threaded insets that came with the moog balljoints.
And yus, im gonna ream out that TRE on the drill press, i was getting the 2 on the knuckles in place so i can double check my measurements for the DOM
Spare set sounds like a good idea, nice to have the spare reamed up too.
post #64 of 600 (permalink) Old 03-14-2006, 03:06 PM
94_chickentaco
Guest
Posts: n/a
The threaded inserts is what im talking about. I pulled mine when i tore down the axle, and replaced with the new ones that came with the upper BJ's which are just straight through- no offset.
My caster was off and had me wondering. I found the threaded inserts i removed and sure as shizzle they were offset, one is a 6 and one is a 10.
DOH!
I put them in and tried my best to align it using caveman methods but i have given up and will be taking it down to get aligned.
post #65 of 600 (permalink) Old 03-14-2006, 04:22 PM
Ya those would be odd to use as you torque the adjuster thingie then the big nut...not sure how you would do it with one thats at an angle
post #66 of 600 (permalink) Old 03-14-2006, 04:56 PM
Owned 21 Years
Mine were straight through as well, but I'm going to go try and dig up some info. again on those guys. there must be instructions. I saw something not long ago that was showing various offsets, that much like the TTB adjustable upper bushings, as you turn it you can slightly change Caster and/or Camber.
I would think the torque spec on that can be moved somewhat Tim. Wasn't it only like 40ftlbs. so how much more of a turn do you get with a range, say of between 35 and 50ft lbs? I wonder? I mean, what are they really for up top? I'm thinking one of the purposes is to have a new fresh inner wall with which the balljoint will slide into. That plus the camber/caster adjustability.
post #67 of 600 (permalink) Old 03-14-2006, 05:00 PM
Owned 21 Years
Hmmm, interesting approach. I'm sure you havn't forgot what a bugger mine was to remove?
post #68 of 600 (permalink) Old 03-14-2006, 05:18 PM
94_chickentaco
Guest
Posts: n/a
Besides the upper camber adjusters there are camber shim plates available that are placed on the knuckle between the spindle and knuckle.
These seem to be so rare i cant find info on the net about them. However, i have seen them in person at dogonmuts place they do exist.
Wait, i take that back i found some:
http://www.ingallseng.com/parts/26126.htm
Seems car quest may also sell these.
post #69 of 600 (permalink) Old 03-14-2006, 06:08 PM Thread Starter
F.O.T.Y. 2003
Crazed's Avatar
How could i forget
Crazed is offline
post #70 of 600 (permalink) Old 03-14-2006, 07:51 PM
Owned 21 Years
How could i forget
That was a rather ominous start. That was definitely the most unpredicatable, and thusly hardest part of the whole operation.
I hope you are soaking.
post #71 of 600 (permalink) Old 03-14-2006, 10:26 PM
You broke that trying to get the pitman arm off? Howd you manage that?!
Got a torch?
reptillikus is offline
post #72 of 600 (permalink) Old 03-14-2006, 10:52 PM
Owned 21 Years
Got a torch?
yep, plus all those tools, including the nice 1/2" craftsman upper left. had soaked it several days prior, each day, for a torch we were heating the arm with one of those little green propane guys with brass nozel. The puller (and most of the other tools) broke while cranking with about a 3foot pipe on the wrenches for leverage. Not sure what the issue was. These things can be that way....tried lightly hammering as well.
plus Todd is strong.
needless to say the other pitman went on with anti-seize. If ever I pull it again, I hope it comes easier (pre-warning...keep the minds out of the gutter)
post #73 of 600 (permalink) Old 03-14-2006, 11:12 PM
rolling Rolling ROLLING....
Bronco Info: 93 Cherokee
I seen on some chevy gear boxes where the splines actually twist inside the pitman arm...not much but enough to make it a nightmare to get off.
Tim
Newest token Jeep owner....
Redwagon is offline
post #74 of 600 (permalink) Old 03-14-2006, 11:26 PM
Jeez, no wonder why...get rid of that child's toy and get yourself a real torch
Mine was a biatch the first time, but Acetylene works wonders
post #75 of 600 (permalink) Old 03-15-2006, 12:56 AM Thread Starter
F.O.T.Y. 2003
Crazed's Avatar
Pitman arm came off easily today
I also got the spring buckets bolted on
Crazed is offline
post #76 of 600 (permalink) Old 03-15-2006, 01:07 AM
Owned 21 Years
stock upper coil buckets then? JBG F*ed you? How does the forward movement look compared to stock 78-9? and compared to the JBG "replicas"?
post #77 of 600 (permalink) Old 03-15-2006, 01:10 AM Thread Starter
F.O.T.Y. 2003
Crazed's Avatar
I did get the JBG repos, but it just seemed like the stockers fit the truck better...Not sure why...I am pretty sure i have them about where we did on yours. I spent quite awhile making sure i am the same side to side.
Crazed is offline
post #78 of 600 (permalink) Old 03-16-2006, 01:07 AM Thread Starter
F.O.T.Y. 2003
Crazed's Avatar
Uncle Todd (TnTbronco) came over and made me work.
I still have to make a track bar mount, get my DOM tubing, and figure out shock mounts. wish i had a welder/bender, id like to do a tube shock mount
Crazed is offline
post #79 of 600 (permalink) Old 03-16-2006, 02:03 AM
All I got for X-Mas was a
Joes93Bronco's Avatar
are you gonna have the tubing threaded or use the weld in bungs?
i just got home tonight from a 5 day stay in Portland. My daughter had surgery at Casey Eye. Drove up sat. it was an emergency kinda thing. The Elks put us up in a hotel. It was elcheapo and they didnt have the interweb or i woulda posted and maybe hooked up with some of you guys. would have been sweet to see yer rig or Marks in person (and you guys too not just yer trucks).
Baby Girl
My SuperCrap Site
-Plato
Joes93Bronco is offline
post #80 of 600 (permalink) Old 03-16-2006, 06:02 AM
Bronco Info: 94 XLT, 5.8L, 8 lug HP D44, FF D60, work in progess
Looks good so far!!
zainyD is offline
