SoCal Junk Yard Reports - Page 5 - Ford Bronco Forum
post #81 of 478 (permalink) Old 02-15-2009, 01:43 PM
Bronco Info: 1995 5.8 E4OD. Rancho 4in.Ext. Radius Arms. 35x12.5 BFG Muds. Resi Shocks
Thanks for the heads up Too bad on the lift though, BrokenBronco on here may have some rims so I'm gonna hit him up.
BB33's is offline
post #82 of 478 (permalink) Old 02-15-2009, 03:37 PM
Cucamongan's Avatar
Bronco Info: '89 XLT Bronco 5.8 C6 35"
Originally Posted by Chris85xlt View Post
any ZF5 trans???
Chris, Yes, I saw a small block ZF5 4x4 trans in a white '92-96 Ford F-250, engine already gone, but BW1356 Transfer case still there
BUT the shifter was gone as well, not just the handle, but the assembly.
It might be worth it to go pull off the rear Trans cover to make a 2WD trans a 4X4 trans.
'89 Ford Bronco, Red & White, 5.8L C6, 35"s 186K Still Going Strong!
Contributor to the Skunk Workings of Stinky Le Pew (Project PePè)
Cucamongan is offline
post #83 of 478 (permalink) Old 02-21-2009, 06:26 PM
I see Broncos
Froggmann's Avatar
Bronco Info: 93 OJ Special 4" Lift 35s and a bunch of other junk.
Couple of finds at the Santa Fe Springs Ecology
81 Bronco mostly complete with the saught after factory BLACK interior it also has the factory roll bar in it.
96 Super Dukey. Diesel, has a ZF trans sitting next to it, Dual battery trays, 3g alt (I unbolted but decided to leave it.) Hydra-boost brake booster and for someone looking for a kick ass air compressor there is one sitting under the bed. That, the air tank sitting over the cab and a little engineering and you will have one awesome shop air compressor.
Bronco is in the southwest corner of the yard the SD is in the ileway at the west end of the yard, Bronco is black and the SD is silver body with a black flatbed.
PYP in both anaheim and stanton didn't really have much but a couple of exploders had some nice seats in them. Speaking of which the Stanton PYP had a V8 exploder in it. Supposededly those have the GT-40 heads.
Depositing random fluids around California, Nevada and Arizona since 1999.
Froggmann is online now
post #84 of 478 (permalink) Old 02-22-2009, 03:53 AM
Bronco Info: 1989 bronco xlt. 302, AOD. Dana 44 SAS. ruffstuff "y" steering deaver coils,
santa fe springs huh
4x4_mafia_jon is offline
post #85 of 478 (permalink) Old 02-22-2009, 09:33 AM
shaner17's Avatar
Bronco Info: 1984 Bronco pre-runner
I was at Brown Field Truck & Van Dismantling. (619) 263-3898 in Otay Mesa (south San Diego) they had about 20 broncos out there with lots of good parts to take. 6 of them were Border patrol broncos with Rancho lifts. It was the most broncos ive seen in one yard before.
Shane Relph
shaner17 is offline
post #86 of 478 (permalink) Old 02-22-2009, 03:14 PM
Spectre's Avatar
Bronco Info: 78 Bronco 400/C6
Man why does otay mesa have to be so far away?
Vic - W6VIC
1978 Ranger Bronco XLT 400/C6 with only 33's =(
2001 F250 - 6" SL. 37" tires Goliath
2007 Yamaha R1 Ricochet
Spectre is offline
post #87 of 478 (permalink) Old 02-22-2009, 03:15 PM
TCM GLX's Avatar
Bronco Info: 93 Bronco XLT 5.8
Damn!! 6 of them with the rancho lift!! Sounds to me like we should all go on a road trip!!! Otay is only 1.5 hours away Vic!!
PM me for Retrofit projectors headlights and LED tail lights!
TCM GLX is offline
post #88 of 478 (permalink) Old 02-22-2009, 03:24 PM
I see Broncos
Froggmann's Avatar
Ok just got back from ecology, since no one bit on that hydroboost I went and got it. Expect a writeup on it before Fab Fords. Jon I will be calling you as soon.
post #89 of 478 (permalink) Old 02-22-2009, 03:49 PM
cant wait hahahaha
yea i like the factory roll bar if i had some cash i would role down and pick it up..
post #90 of 478 (permalink) Old 02-22-2009, 04:30 PM Thread Starter
Maxson's Avatar
Bronco Info: 87 XLT, Rebuilt 302/AOD 6" DC Stage II TTB Lift
Oh hey, keep your eye out for the F-Series stock tow hooks... I'd like a set but wont pay retail.
Maxson is offline
post #91 of 478 (permalink) Old 03-12-2009, 01:33 AM
Jeff@PLC's Avatar
Bronco Info: 1993 F150
Any updates on what's available in or around the IE?
I'm looking for a transmission tunnel cover (transfer case cover) from an early 80's style Bronco / F150. I'm running an older linkage setup transferred from my 1983 to my 1993 and would like to find the factory tunnel cover with the transfer case shifter and boot. I'll make a cover plate for the new style linkage I tossed.
Also looking for a TFI remote mount heat sink and module from a pre-CCD vehicle.
Regarding Border Patrol Broncos... AJAX Auto out in Coachella used to have tons of them. John is an off-road racer and is pretty cool to guys that hint the parts are being used on a prerunner or race rig. I haven't been out there for a few years but it's closer to Riverside than Otay is. http://www.ajaxauto.com/
Aloha
Jeff@PLC is offline
post #92 of 478 (permalink) Old 03-12-2009, 09:52 AM
rolling Rolling ROLLING....
Bronco Info: 93 Cherokee
I was out at the Milliken pick a part last weekend...not a single bronco.
Tim
Newest token Jeep owner....
Redwagon is offline
post #93 of 478 (permalink) Old 03-12-2009, 11:15 AM
Spectre's Avatar
No bronco's at Miliken? wow... That doesn't happen very often.
Vic - W6VIC
Spectre is offline
post #94 of 478 (permalink) Old 03-12-2009, 02:48 PM
Jeff@PLC's Avatar
How about 4x4 F150's?
Aloha
Jeff@PLC is offline
post #95 of 478 (permalink) Old 03-12-2009, 02:59 PM
Spectre's Avatar
Depending on the year.. Their truck section is huge compared to what it was a couple years ago.
Vic - W6VIC
Spectre is offline
post #96 of 478 (permalink) Old 03-12-2009, 04:26 PM
oscar espinoza
EastLA78Bronco's Avatar
Bronco Info: 78 bronco, 460 mild built. D60 front 14 bolt rear. detroit lockeds. OBA. twin stick np205. built c6
n e 78 79 trucks
[SIZE="4"][FONT="Fixedsys"]78 bronco, 460 cid,true dual exhaust,c6 with a shift kit,NP205 twin stick,9"lift,shackle flip,14B/D60d, 410 gears, 40" boggers. croseovver stering r
EastLA78Bronco is offline
post #97 of 478 (permalink) Old 03-12-2009, 04:29 PM
Spectre's Avatar
I might head over this on Saturday..
Vic - W6VIC
Spectre is offline
post #98 of 478 (permalink) Old 03-12-2009, 04:49 PM
One 78-79 with most of the front axle still there, the outer hubs,knuckles and shafts were missing...basically the housing and arms/springs were still there.
Tim
Redwagon is offline
post #99 of 478 (permalink) Old 03-12-2009, 04:50 PM
What time Vic? I may head out there also...still looking for a couple of spare rims.
Tim
Redwagon is offline
post #100 of 478 (permalink) Old 03-12-2009, 05:45 PM
Spectre's Avatar
Um.. not sure.. When I hit up the yards I like to do it first thing.. So looking around 8:30 ish..
Spare rims? What size?
Vic - W6VIC
Spectre is offline
  Ford Bronco Forum > Wheeling > West Coast Chapter
