Mountain States Chapter Map - Page 3 - Ford Bronco Forum
post #41 of 361 (permalink) Old 03-29-2004, 09:28 AM
Pissin' into the wind
Bronco Info: I don't even own a Ford anymore...but I still luv you guys
Originally Posted by Miketnf150
I got your PM Burl Swift. I won't PM you back since I am replying here. I reposted the map. I don't know why it wasn't showing up. Could have been the wonderful SuperFord site. It's back on the first page though.
I don't have the maps here at home so I can't update them until back at work. I have quite a few new names to add to all the maps so please be patient.
Thanks fellas
Thanks for all the work Mike, we owe you a
...thoughts arrive like butterflys...
Burl Swift is offline
post #42 of 361 (permalink) Old 04-02-2004, 09:32 PM
Bronco Info: 1985 full size bronco
Florence Colorado 81226
85 Bronco XLT
32" Mud Kings
Dual shock front
Ranco shocks
351W 4 barrel
manual hubs
C6
White
always muddy
will get pics soon
Dana 44
This truck has been in 15 accidents...and hasn't lost one yet
dragonman780 is offline
post #43 of 361 (permalink) Old 04-03-2004, 02:37 PM
bucknbronc's Avatar
Bronco Info: 351w np435 swap 9" swap K+N FIPK 35's 4.11's 4" rancho flowmaster
Dammit, on the map my name is "bunknbronc" when my name is really bucknbronc. Thank you
NEVADA FULLSIZE
'89 eddie bauer ford bronco 351w np435 swap 9" swap w/mini spool 4" rancho stage I K&N intake flowmaster super40 35's 4.11's warn premiums
Originally Posted by Sixlitre
By the time I'm done the 86 will be lit up like a Nevada whore house.
Originally Posted by Streetgang
I loose sleep every night thinking about Broncos!
bucknbronc is offline
post #44 of 361 (permalink) Old 04-04-2004, 08:18 PM
Bronco Info: 1990 eddie baur 351w, e40d, limited slip in rear. Everything has been replaced atleast once.
South jordan Utah 84095
Justin's bronco is offline
post #45 of 361 (permalink) Old 04-08-2004, 02:49 PM
Bronco Info: 96 Bronco 302 Way too many miles
Morrison, CO 80465 Jefferson County
brettbo is offline
post #46 of 361 (permalink) Old 04-10-2004, 05:12 PM
Jou
Jou's Avatar
Powell WY 82435 Park County
The Broncador '78 bronco - 460 - c6 - 2" susp - 33" MT/Rs
Jou is offline
post #47 of 361 (permalink) Old 04-23-2004, 03:25 PM Thread Starter
Offical FSB Map Maker
Miketnf150's Avatar
Bronco Info: 95, 5.8L(351), Eddie Bauer green/tan, 6" Dick Cepek lift w/ extenede radius arms, 35" Pro Comp M/T's
Updated Map! 4/23/04
Also could someone make this thread a sticky please!
Thanks Mike
The Best Never Rest!
SAS Thread Winch Install
4x4grace.com
Miketnf150 is offline
post #48 of 361 (permalink) Old 04-23-2004, 04:04 PM
Thanks a ton Mike, we appreciate it.
post #49 of 361 (permalink) Old 04-23-2004, 10:29 PM
DWNHLLR's Avatar
Bronco Info: 1995 White Bronco Sport
Sweet!!! I'm on the map!!
Original Owner - '95 XLT Sport, 351, Progressive springs, Rancho 9000's, Posi, Warn Hubs, 32" BFG's, K&N, Skyler softop, keyless entry and start, bitch'n stereo and a fearless driver!
DWNHLLR is offline
post #50 of 361 (permalink) Old 04-24-2004, 01:58 AM
Bronco Info: 1981 bronco, 8in lift, front and rear lockers, 456 gears, 9in rear with moser axles, 205 tranfer cas
BOUNTIFUL, UTAH 84010
Monte is offline
post #51 of 361 (permalink) Old 04-24-2004, 05:49 PM
I'm no expert!
BigNorm's Avatar
Bronco Info: 1982 Toyota with the roof cut off. 351W, D60 welded, 14bolt, 5.13s, on 39.5 TSLs with beadlocks.
Wow! Thanx for putting my truck on there. I kind of miss it now seeing it that way. I can't wait to see it on 40's some time next year.
1982 Toy Chasis & Cab. 351W, C6, NP203/205, D60 welded, 14 bolt Detroit & 5.13s, running on 15" wheels and 40s.
BigNorm is offline
post #52 of 361 (permalink) Old 04-27-2004, 03:19 PM
JDApollo's Avatar
Bronco Info: 1985 Bronco XLT
Layton, Utah 84041
North Davis County
JDApollo is offline
post #53 of 361 (permalink) Old 04-27-2004, 03:45 PM
I'm no expert!
BigNorm's Avatar
I like bunkinbronc better.
BigNorm is offline
post #54 of 361 (permalink) Old 05-06-2004, 02:46 AM
so what does it take to get your name on the map????????
Monte is offline
post #55 of 361 (permalink) Old 05-06-2004, 03:23 AM
OldBlue's Avatar
beerman *jer* needs to be on there. he is in west valley Utah.
MY NAME IS BRAD! DAMNIT!
Originally Posted by ToddACimer
Usually if you pull out and then stick it back in there you can keep pumping without problems.
OldBlue is offline
post #56 of 361 (permalink) Old 05-06-2004, 08:16 AM Thread Starter
Miketnf150's Avatar
All I need is location with zip code. and I'll add when I do an update.
4x4grace.com
post #57 of 361 (permalink) Old 05-06-2004, 11:13 AM
Jer is in Kearns...Drew and I are the WV guys!
post #58 of 361 (permalink) Old 05-07-2004, 02:57 AM
Cool, I did that above, i just wait then, thanks.
Monte is offline
post #59 of 361 (permalink) Old 05-16-2004, 12:36 AM
rajncajn's Avatar
Bronco Info: '94 Bronco 5.8L - Fender Trim - 33" MTR's
didn't make the map on my last post. i'll try again.
salt lake city, ut 84116
rajncajn is offline
post #60 of 361 (permalink) Old 05-16-2004, 03:22 AM
Bronco Info: 1990 Bronco 351W 3" Flowmaster CatBack K&N Filter CAI 32" WildCountry TXR's
Hey mike, just put my name right below Burl's, since I literally just live right around the corner
Current Rig: 1994 Wrangler SE 3 speed Auto:Little bit of lift on 30x9.50's.
1990 Bronco-Gone but not forgotten.
351Bronco is offline
  Ford Bronco Forum > Wheeling > Mountain States Chapter
