Engine Tear Down Rack - need ideas - Ford Bronco Forum
post #1 of 29 (permalink) Old 08-04-2009, 10:04 AM Thread Starter
Retired Staff
bossind's Avatar
I've googled like crazy but I haven't had much luck finding a solution, so I'm turning to the power of FSB... please help me.
I Need a better way for the kids to tear down engines, presently they share metal tables to spread the parts out on. Not so bad for one engine but when you get a group of 20 kids on 10 engines... well they don't go back to gather with the same parts. And its messy as hell.
I know they make plastic trays for the valve train, but what about pistons, cranks, main/rod bearings?
I need some solutions I can either buy or make, to turn this into an effect learning experience. What do those tech course use for engine building?
bossind is offline
post #2 of 29 (permalink) Old 08-04-2009, 12:33 PM
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
http://www.pitpal.com/products/Pisto...V8-713-36.html
Let's Go Fishing.
jopes is offline
post #3 of 29 (permalink) Old 08-04-2009, 01:15 PM Thread Starter
Retired Staff
bossind's Avatar
I came across that in my travels, not a bad for the pistons but still.
bossind is offline
post #4 of 29 (permalink) Old 08-04-2009, 01:24 PM
gone fish'n
jopes's Avatar
build on it.
you have a basic idea to use. Now add something to hold the bearings.
Let's Go Fishing.
jopes is offline
post #5 of 29 (permalink) Old 08-04-2009, 01:27 PM
gone fish'n
jopes's Avatar
make it a little longer. maybe use some PVC pipe cut lenth wise for the bearings along side each piston on the botton rack.
labeled as such. maybe make a top tray which would hold the mains. since the mains are in before the block before the pistons, and are the last thing pulled out.
Let's Go Fishing.
jopes is offline
post #6 of 29 (permalink) Old 08-04-2009, 01:34 PM Thread Starter
Retired Staff
bossind's Avatar
The first one to build might be fun but the other 9 would suck. Rather find something more complete.
bossind is offline
post #7 of 29 (permalink) Old 08-04-2009, 02:09 PM
Some assembly required!
Dave's Bronc 90's Avatar
Bronco Info: 90 EB, 351W, E40D, D60 SAS, 10.25 rear, ARB's front & back, indellible Cheerwine stain in carpet
Did they take that pic with a cell phone? I've seen clearer pics of Big Foot.
Dave's Bronc 90 is offline
post #8 of 29 (permalink) Old 08-04-2009, 02:19 PM
gone fish'n
jopes's Avatar
sounds to me your going to turn this into a learning expierence and make the class make the other 9 trays.
Let's Go Fishing.
jopes is offline
post #9 of 29 (permalink) Old 08-04-2009, 08:11 PM
press ALT+F4
78bronco460's Avatar
rubbermaid totes and each motor has a different color can of spay paint to mark the parts with?
78bronco460 is offline
post #10 of 29 (permalink) Old 08-04-2009, 11:15 PM
Wrenching for a Livin'
magnumpi's Avatar
At my school we only have wood top work tables to put everything on. And we have to mark everything as it comes out, or mostly note the marks. Usually our teachers will screw with what we have laid out so we can't just put it back together in reverse of how we dissasembled it.
Actually in manual transmission class after we had the entire thing laying on a bench in pieces our teacher came around to each table, jumbled everything up and added extra parts. Then we left for the weekend. I learn A LOT it that class.
Basically what im saying....maybe its better if everything isn't exactly orderly, because it rarley ever is in a garage.
Altough a small stand to hold the crank would have been nice...and something to keep the pushrods in order.
My SuperFord
'85 Bronco......
magnumpi is offline
post #11 of 29 (permalink) Old 08-04-2009, 11:24 PM
Enjoy my
jmorriss's Avatar
Bronco Info: '01 F150
Would actually be a good learning experience-if you don't have the ideal tool, improvise for a better one.
If you want you could have that be a project in and of itself-give them basic materials and a list of goals (or not depending on the level of the class and pre requisites) and see what you could back. I am sure they could teach us a thing or two.
Originally Posted by Thomas Jefferson View Post
Those who hammer their guns into plows will plow for those who do not.
Please note that we have added a consequence for failure. Any contact with the chamber floor will result in an "unsatisfactory" mark on your official testing record, followed by death. Good luck!
jmorriss is offline
post #12 of 29 (permalink) Old 08-05-2009, 12:29 AM
Bronco Info: '78 Bronco - 466 - D60 Kingpin & 14-Bolt - 38.5" Boggers Double Beadlocked
I've never been in a mechanic's learning environment/classroom, but have taught Biology for 3 years and a lab tech for 3 years at Indiana University. We used carts. In my brother's garage, where I do most of my wrenching, we have quite a few carts and are working on quite a few projects at the same time and the carts keep everything seperate and organized... (Not 10 projects, but a 78 BKO 460 build, BKO II 22R Turbo build, rock crawler 472 30over build, S10 350 build, 89 351w build, Bayou build, and a go cart build. Kinda hard to keep the stuff seperated without the carts.)
I guess space for a bunch of carts would definately be a factor. Also, budget, there are quite a few nice work space carts on the market such as the SnapOn ones. All of ours were bought at different industrial auctions over the years and either used as is, or modified to fit our needs.
oldblackwater is offline
post #13 of 29 (permalink) Old 08-05-2009, 12:56 AM
shibby
Dustball's Avatar
How about buying these cheap 18x30 carts when they go on sale-
http://www.harborfreight.com/cpi/cta...temnumber=5107
Cut the top tray to be able to drop the pistons through.
Dustball is offline
post #14 of 29 (permalink) Old 08-05-2009, 01:06 AM
At 39.99 each, I might have to get a few more.
I have a couple of carts like this one. I did weld a frame of angle iron to them to take out the flimsiness, they work great and have held up. I also changed one of the carts like this one by swapping 2 of the castors with locking type and 2 with swivel type castors. Got a big box of castors at an auction a few years back and have definately got my money out of them.
post #15 of 29 (permalink) Old 08-05-2009, 03:03 AM
shibby
Dustball's Avatar
They're currently on sale in the stores at $34.99. Wait till the weekend and you can use a 20% off coupon on it and end up paying $28.
Dustball is offline
post #16 of 29 (permalink) Old 08-07-2009, 05:57 PM Thread Starter
Retired Staff
bossind's Avatar
Cart is the best idea thus far. Trying to also keep the mess to a control.
bossind is offline
post #17 of 29 (permalink) Old 08-07-2009, 06:01 PM
Lick my balls
waltman's Avatar
I would go with the carts. They can be easily marked for identification which could be assigned for each student for the year and they are on wheels so they can easily be moved around. You could also tack in some walls for various compartments if you wish, or add another shelf in there.
waltman is offline
post #18 of 29 (permalink) Old 08-08-2009, 02:53 AM
shibby
Dustball's Avatar
Could even use dry erase markers to write notes on the sides.
Dustball is offline
post #19 of 29 (permalink) Old 08-08-2009, 07:09 PM
MORTAL KOMBAAAAAAATTT!!!!
The Ric's Avatar
Bronco Info: 88 EB custom dents, and rust.
we used a work bench in my engines class...which the bottom half was metal, and the top was wooden. it had small drawers going across the top and two sliding doors on the bottom going from side to side. So pretty much 3 levels of storage.
boss, do you have these?
http://www.speedwaymotors.com/RS/SR/.../2514394_L.jpg
Not to sure what to put in my signature anymore.
1988 Ford Bronco EB - 2010 Chevy Malibu - 2009 Cannondale Six5 - 2013 FELT F75X
The Ric is offline
post #20 of 29 (permalink) Old 08-09-2009, 11:57 AM Thread Starter
Retired Staff
bossind's Avatar
Not yet, but will be getting some.
bossind is offline
