air compressor rusting from the inside out! - Ford Bronco Forum
post #1 of 22 (permalink) Old 12-15-2010, 04:07 AM Thread Starter
pfun41's Avatar
so the compressor i use is a 33 gallon 150 psi craftsman oilless direct drive unit. it is located in our garage which is fully enclosed. today i drained it for the first time in like 3-6 months. i got about 1.5 soup cans full of brown/rusty water. its gotta be the humidity. my main concern is the fact that its rusting. is there anything i can do to stop the rust. i was thinking something like wd40 inside or something.
pfun41 is offline
post #2 of 22 (permalink) Old 12-15-2010, 09:31 AM
FSB Vendor
An idea that might work is to use a gas tank sealer kit. Most kits come with multiple chemicals to slosh around in the tank and clean the rust off and etch the metal. The sealer then covers the inside surface and keeps the rust from coming back. If it works in a gas tank, I could bet it would work in a air tank.
I haven't tried this personally, but it's a thought!
Our gas tank sealer kit is found here: http://www.eastwood.com/gas-tank-sealer-kits.html
Hope that helps!
-Matt/EW
Eastwood Company is offline
post #3 of 22 (permalink) Old 12-15-2010, 10:18 AM
Robs79BBbronco's Avatar
drain your compressor at least once a week.more often if it gets used everyday.....yes, it's worse if you live in a high humidity area, and no there is nothing you can do about it except drain it.
Robs79BBbronco is offline
post #4 of 22 (permalink) Old 12-15-2010, 06:09 PM Thread Starter
pfun41's Avatar
i really wish these compressors had the drain valve closer to the front. its a pita to drain it. i also wish i had a screw type one. itd be nice to hear myself think.
pfun41 is offline
post #5 of 22 (permalink) Old 12-15-2010, 08:15 PM
2nd mouse gets the cheese
broodu's Avatar
Bronco Info: 89 bronco frame 460 4 speed lifted 39.5 boggers 94 standard cab with flat bed
i drain mine every time i use it and i dont have your humidity i rarely get water out of mine. doesnt really help with your situation but just sayin.
my build [jfritts] 6:23 pm: [RebelRider2010] 8:21 pm: I now know why intelligent conversations never happen with you.
[wfritts911]8:36 thats right i love sucking dick
[wfritts911] 8:36 pm: its my favorite thing in the whole world
broodu is offline
post #6 of 22 (permalink) Old 12-15-2010, 09:50 PM
JohnMcD348's Avatar
I saw a thing over on GarageJournal.com I think where a guy built an off set bleeder by fitting a 90* piece and a length of pipe onto a ball valve. I have a similar problem but I always drain my tank after I use it. I still get a little brown water when I do it.
JTMcD.
JohnMcD348 is offline
post #7 of 22 (permalink) Old 12-15-2010, 10:01 PM
Need a Bumper?
Hefty's Avatar
Bronco Info: 93 Bronco 7in SAS 38's 4.56 and rear detroit front e-locker, 72 bronco under construction
I drain mine about once a week. The rust thing is normal. The compressor will create condensation even in the driest climates. With our 80 gallon we get a cup of water out of it every week....but it runs all the time.
Hefty is offline
post #8 of 22 (permalink) Old 12-16-2010, 02:51 AM
Howdy howdy howdy!
liltimmy08's Avatar
Bronco Info: 1996 XL 302, Rebuilt E4OD, Transgo shift kit, 32" BFG's
Ive got the same POS compressor. Go to home depot and get a simple check valve, 90* piece, etc. Took about a minute to remove the factory drain and install the new one.
Tim AKA Stick Boy. "Tougher then you!"
96 Ford Bronco, 302, The weekend warrior.
96 F-250 Powerstroke. 4 tons of tire shredding, coal rollin' fun.
liltimmy08 is offline
post #9 of 22 (permalink) Old 12-16-2010, 02:53 AM
rhauf's Avatar
put oil in the tank. that helps stop it from rusting.
-Ryan
rhauf is offline
post #10 of 22 (permalink) Old 12-16-2010, 02:14 PM
Mud God - R.I.P.
Rockford514's Avatar
Bronco Info: 66,79,79,87
I got tired of crawling under mine
I drain it daily
Buddy
Rockford514 is offline
post #11 of 22 (permalink) Old 12-18-2010, 12:54 AM
1995f1504x4's Avatar
Bronco Info: 1995 F-150 XL Single Cab Short Bed with a 302 and 4R70W tranny. The ALMOST Bronco.
wait for it to rust through and JB weld it!! haha
do not do that. bad idea. i'd say just drain it everytime you use it as broodu said.
Pride In Ownership
1995f1504x4 is offline
post #12 of 22 (permalink) Old 12-24-2010, 12:30 AM
OUT OF BUSINESS / M.I.A.
Fireguy50's Avatar
Bronco Info: rusty
Thatís great!
I have an automatic drain. It has a ball float inside and once the water gets up high enough it lets it out.
Ryan McCormick
Fuel Injection Technical Library
Parts replacement is not auto repair, if you canít diagnose, donít open the hood!
Fireguy50 is offline
post #13 of 22 (permalink) Old 12-24-2010, 07:33 AM
Mud God - R.I.P.
"automatic drain" That sounds COOL. I may look in to those
Buddy
post #14 of 22 (permalink) Old 12-24-2010, 01:01 PM
ToughBronco's Avatar
Bronco Info: Sold
I drain it daily
yup, thats how a lot of commerical air compressors are.
1997 Ford F250 Heavy Duty XLT 4x4
7.3L PSD CCSB, E4OD, D50 TTB, 10.25 FF LS, 3.55's
2001 Ford E350 Super Duty Work Van
5.4L V8
ToughBronco is offline
post #15 of 22 (permalink) Old 12-24-2010, 04:54 PM
Lick my balls
waltman's Avatar
I drain mine every day or two.
waltman is offline
post #16 of 22 (permalink) Old 12-24-2010, 05:42 PM Thread Starter
pfun41's Avatar
i found this:
http://www.paragoncode.com/shop/compressor/
thats pretty cool. too bad mines a portable unit and theres not enough space. i actually had the crap drain break the other day. i couldnt find what i wanted ( a short brass elbow and valve) to put in its place so i just stuck a 1/4 plug in it for now. i really like the auto drain thing. when you guys drain your tanks do you empty the whole ting of air and then drain it or just open the valve until moisture stops coming out while theres still pressure?
i might just get something like this:
i want to be able to hook a peice of tubing to the drain so i dont have water sitting on the floor. although i guess if i just open it for a sec or 2 after i use it there wont be any liquid huh?
pfun41 is offline
post #17 of 22 (permalink) Old 12-24-2010, 07:30 PM
Mud God - R.I.P.
I barely crack mine open,then close after the water stops
Buddy
post #18 of 22 (permalink) Old 12-24-2010, 11:44 PM
Lick my balls
waltman's Avatar
Just drain it until the water stops coming out and another 20 seconds or so will be enough. If I'm getting a lot of moisture in the tank, I will even do it several times in one day, especially when I'm getting closer to painting.
waltman is offline
post #19 of 22 (permalink) Old 12-25-2010, 04:53 AM
Roller rockers are gay
TheUnforgiven's Avatar
wow, this is going to make me go and check the drain on my uncles compressor. which he has had for 10 years and never drained, yet he is the most anal-retentive guy i know.
New nuts are in the plan.
TheUnforgiven is offline
post #20 of 22 (permalink) Old 12-27-2010, 06:13 AM
Fireguy50's Avatar
Bronco Info: rusty
cost around $45, it has an 1/8in output to plumb the water outside
Ryan McCormick
